Experimental Letter
Old July 16th 18, 01:34 AM posted to rec.aviation.soaring
Default Experimental Letter
My Ventus 2cxM has been flying in the Experimental Category since new (2003), and each year I've been faithfully updating the Experimental Letter (I just change the date) and mailing it to my FSDO. I've been told that the wording of the standard Experimental Letter is different now, and if I request it, I could have a Letter with the new wording issued. Does anyone have any comments about this?
Old July 16th 18, 02:44 AM posted to rec.aviation.soaring
My DG-200 (1979) Operating Limits said nothing about a Program letter. (FS, see Wings and Wheels) The same for my Ventus 2 (the OL say no geographical limits and again nothing about a letter) so I haven't been sending a letter to the FSDO.
Old July 16th 18, 05:49 AM posted to rec.aviation.soaring
I think the correct name for the letter is 'Program Letter' (not experimental letter).
Old July 16th 18, 02:27 PM posted to rec.aviation.soaring
SF
It's a program letter, and it goes to the "line Manager" at your local FSDO.. I would call your local FSDO ask to speak with the line manager, and get him to tell you, want he wants to see from you. I have a sneaking suspicion that it is filed in an unknown location, and never looked at by anyone for any reason, But it is also vitally important that it be filed.
SF
Old July 16th 18, 02:40 PM posted to rec.aviation.soaring
Dan Marotta
And, as I recall, I kept a copy in the glider, as well.
On 7/16/2018 7:27 AM, SF wrote:
It's a program letter, and it goes to the "line Manager" at your local FSDO. I would call your local FSDO ask to speak with the line manager, and get him to tell you, want he wants to see from you. I have a sneaking suspicion that it is filed in an unknown location, and never looked at by anyone for any reason, But it is also vitally important that it be filed.
SF
Dan, 5J
Papa3[_2_]
SF
Old July 16th 18, 02:47 PM posted to rec.aviation.soaring
A copy of the program letter as well as a copy of your operating limitations that were issued with your experimental certificate must be in the aircraft.
Old July 16th 18, 02:52 PM posted to rec.aviation.soaring
Tom (TK)
The form changed with 2130.2G revision.
Here is a copy for word:
https://drive.google.com/file/d/0B0k...ew?usp=sharing
Old July 16th 18, 04:06 PM posted to rec.aviation.soaring
Frank Whiteley
My FSDO issued an example that basically matches that. It should have been named 8130.2(now J) as FAA Order 8130.2 is the defining document, which no longer discusses the pre-/post- moratorium issues. You'll need to refer to earlier versions for that discussion.
See appendix C-2 here https://www.faa.gov/documentLibrary/...er_8130.2J.pdf
and
https://www.gpo.gov/fdsys/pkg/CFR-20...-sec21-193.xml
As a result of some engagement of SSA volunteers with the Type Club Coalition, there were some efforts to seek permanent program letters for gliders a few years ago, but nothing materialized as a specific request. It was to be based on operating at known soaring venues. Deviations, like soarfaris from unlisted sites, would have required notice to the base FSDO, but as long as the pilot operated from a defined national list of soaring sites, it would have been fine.
As far as the FSDO having a copy on file. It's the type of thing that probably only comes to the attention of the FAA is the aircraft comes to the attention of the FAA for some reason. Some of you may recall, that several years ago, the FAA wanted the FSDO's to perform a 100% hands on check of all experimental aircraft. Of course, the FAA does not have that sort of manpower, nor would such an effort have been a positive. However, it is clear that some glider owner/operators over the years were not in compliance nor did they understand the process. Neither of the two prior owners of one of my gliders ever complete Phase I or enter Phase II, nor did they file program letters with their FSDO's. As a result I had to hire a DAR to complete new operating limitations and fly off Phase I, just like it was a new import and air worthy.
I suspect more than one buyer has discovered the same thing.
Frank Whiteley
Old July 16th 18, 04:58 PM posted to rec.aviation.soaring
JS[_5_]
Thanks, Tom.
However, I'll use the one already sent to the FSDO for the rest of the year.
Letter to the FAA Walt Connelly Soaring 201 May 9th 19 05:27 AM
from latest news letter on vulcan, hope it is of intrest to some of you if you dont get the news letter PAUL H Aviation Photos 0 January 27th 13 11:21 AM
A LETTER OF THANKS minimoa Soaring 0 September 14th 10 12:06 AM
Letter from TSA? Emily Piloting 14 August 14th 06 11:33 PM
Letter from TSA Rosspilot Piloting 2 November 20th 03 01:12 AM
