Emailing contest flight log to scorer
Old July 18th 18, 03:45 PM posted to rec.aviation.soaring
Default Emailing contest flight log to scorer
From the cockpit, I want to transfer my flight log to my phone and email it to the contest scorer.
If your IGC approved logger is Bluetooth equipped and it is paired to your phone, is it just a simple matter of downloading log to phone and emailing the file?
Are there any "security" issues or 3rd party apps required?
Thanks for your input.
Old July 18th 18, 04:00 PM posted to rec.aviation.soaring
Shouldn't be any problem. The security is built into the file contents, and is thus carried along when you email it.
In the recent Region One contest I wanted to configure the IGCdroid app - which already runs on my phone, and was my backup logger as well as providing real-time tracking - to automatically email the log file to the scorer directly. Meeting some reluctance on the part of the management, I only had it email it to myself. Then I forwarded that email to the scorer. Turns out the log file *name* was not acceptable to Winscore (fixed that by renaming it manually). The naming issue has since been fixed in the app, so be sure to get version 1.19 (or later) if you plan to do that.
Old July 18th 18, 05:06 PM posted to rec.aviation.soaring
Tony[_5_]
LXNAV computers have this capability with their WiFi module
Old July 19th 18, 12:25 AM posted to rec.aviation.soaring
waremark
I used the WiFi bridge to email the file from my lx9000 to the scorer using my phone as a hotspot. It worked well. I could also have used the file from my Oudie IGC which I can upload to the phone and to SeèYou cloud by Bluetooth from the Oudie logbook, running Oudie Live on the phone. I believe all Nano loggers also offer this.
Old July 19th 18, 02:51 PM posted to rec.aviation.soaring
Winscore expects log file names to conform to section A2.5 of the FAI Technical Specification for GNSS flight recorders.
2018-04-22-CNI-21Q-01.IGC - Valid
JX_Smith_StdClass_Day1.IGC - Not valid
Old July 20th 18, 06:05 PM posted to rec.aviation.soaring
Right. Silly though, since those rules still do not guarantee that the file names are unique (two of them could be 2018-04-22-XCS-AAA-01.IGC). On the other hand much more info (such as pilot name) is present in the header lines of the file contents. Anyway, the latest version of IGCdroid does name the files to fit those rules.
Old July 21st 18, 03:10 AM posted to rec.aviation.soaring
Actually, the manufacture code and serial number in the file name should guarantee uniqueness.
Old July 21st 18, 05:29 AM posted to rec.aviation.soaring
SoaringXCellence
The example given is actually one generated by the XCSoar program (hence the XCS in the middle of the file name). The program allows the user to chose any three characters for the "unique code" (AAA in this case).
So it is possible for there to be two files from different competitors with the same file name.
Having been a contest scorer for the last 4 years I know that this can occur and use the practice day or the first contest day to sort out those kind of conflicts.
Mike
Old July 18th 18, 08:27 PM posted to rec.aviation.soaring
Craig Reinholt
If you have an iPhone, use a HooToo / lightning flash drive to download the file and then email it from your phone.
https://www.amazon.com/Lightning-Con...1941921&sr=8-5
Here is a RAS thread discussing it.
https://groups.google.com/forum/?fro...ng/pV1zSqL9T_4
Old August 2nd 18, 07:20 PM posted to rec.aviation.soaring
Mike Clarke
and email
paired to
and
emailing the file?
download the
https://www.amazon.com/Lightning-Con...oToo-External-
iPlugmate/dp/B019W8N4DU/ref=lp_2529574011_1_5/133-
2130488-2796502?
srs=2529574011&ie=UTF8&qid=1531941921&sr=8-5
fromgroups#!topicsearchin/rec.aviation.soaring/Hootoo;context-
place=searchin/rec.aviation.soaring/Hootoo%7Csort:date/rec.aviatio
n.soaring/pV1zSqL9T_4
I bought one to download flight logs from my LX907, but it is going
back as the LX doesn't recognise it. Neither does my Power Flarm.
MC
emailing your log file from an iPhone Dave Nadler Soaring 25 September 27th 16 06:17 AM
Mangling of U.S. Contest Flight Logs? [email protected] Soaring 10 April 10th 12 04:17 PM
Winter is here - RAS Flight Club Contest Tony[_5_] Soaring 5 December 3rd 09 06:05 PM
Dusk 'til Dawn Flight Simulator Screenshot Contest - Win $25! [email protected] Simulators 0 January 21st 07 03:49 AM
Dynamic Contest Flight Display Bob Soaring 0 August 8th 05 01:38 PM
