I'm one of the few people who still prints maps with Glideplan for contests, importing Cup files and colorizing.
After setting everything up the way I like for the Std Nats at TSA... the function SET PRINT AREA, necessary to print out multiple sheets is broken. Tested on my Desktop PC Win7, a Lenovo X220 notebook Win7 and a Dell XPS 13 on Win10. Same behavior on all three. Last time used was one year ago. God and Microsoft only knows what changed in the last year... email sent to Matt Herron, the developer. Walt Rogers WX |
I can print maps, but it's not easy. There's no Print Preview so you have to guess at the map size. Last time I used 150% which printed most of what I wanted on a single letter sized page. You use up a lot of paper trying to find the right size.
Glideplan is basically unsupported so you get what you get. Win 7 on a Dell desktop Mark |
On Sunday, July 22, 2018 at 5:48:51 PM UTC-7, wrote:
I can print maps, but it's not easy. There's no Print Preview so you have to guess at the map size. Last time I used 150% which printed most of what I wanted on a single letter sized page. You use up a lot of paper trying to find the right size. Glideplan is basically unsupported so you get what you get. Win 7 on a Dell desktop Mark I've always printed to PDF - saves ink and it's faster. I also save maps that way in case I want to print them again. I'm using the Mac version, so maybe that'a easier. Andy 9B |
The easy way to test print outs of Glideplan (when it works...), is to print to a pdf printer driver. When you finally get it right... correct magnification and number of pages, then send to a paper printer.
I usually take it to a Fedex print/shipping facility. Then I can use their paper cutters, tape, layout space to laminate (shelf paper) all in less than an hour. Walt WX |
Ah! Hadn't thought of printing to a pdf. Thanks, I'll try that.
Mark |
Yup. That's how I've been doing it as well. Takes a little fiddling, but once you have it as a PDF you can size to your needs. I generally do a zoomed in view for the home airport out to about 30 miles on one side of an 11x14 sheet and the other side zoomed out to cover the whole area. Makes it easy to manage in the cockpit and good enough for preflight task planning on the macro view.
P3 |
On Monday, July 23, 2018 at 6:56:21 AM UTC-7, Papa3 wrote:
Yup. That's how I've been doing it as well. Takes a little fiddling, but once you have it as a PDF you can size to your needs. I generally do a zoomed in view for the home airport out to about 30 miles on one side of an 11x14 sheet and the other side zoomed out to cover the whole area. Makes it easy to manage in the cockpit and good enough for preflight task planning on the macro view. P3 The demo version by design will not print maps. Maybe the version you have got locked out from printing. A brute force method to print what you see is using the Windows tool Snip. They can be stored as PNG, Giff or Jpeg . BG |
What I used to use was, "CutePDFwriter", it was free, worked decent on Windows XP, and did quite a few things.
If saving an image in Windows, I found a ".PNG" was MUCH smaller than a ".JPG" with similar resolution. Not a fix for this issue, just some suggested workarounds..... |
Works fine for me. Maybe a remove and reinstall is in order?
On Sunday, July 22, 2018 at 7:05:31 PM UTC-5, WaltWX wrote: I'm one of the few people who still prints maps with Glideplan for contests, importing Cup files and colorizing. After setting everything up the way I like for the Std Nats at TSA... the function SET PRINT AREA, necessary to print out multiple sheets is broken. Tested on my Desktop PC Win7, a Lenovo X220 notebook Win7 and a Dell XPS 13 on Win10. Same behavior on all three. Last time used was one year ago. God and Microsoft only knows what changed in the last year... email sent to Matt Herron, the developer. Walt Rogers WX |
Forgot to mention that I run it on both Win 7 and Win 10.
On Sunday, July 22, 2018 at 9:15:27 PM UTC-5, wrote: Works fine for me. Maybe a remove and reinstall is in order? On Sunday, July 22, 2018 at 7:05:31 PM UTC-5, WaltWX wrote: I'm one of the few people who still prints maps with Glideplan for contests, importing Cup files and colorizing. After setting everything up the way I like for the Std Nats at TSA... the function SET PRINT AREA, necessary to print out multiple sheets is broken. Tested on my Desktop PC Win7, a Lenovo X220 notebook Win7 and a Dell XPS 13 on Win10. Same behavior on all three. Last time used was one year ago. God and Microsoft only knows what changed in the last year... email sent to Matt Herron, the developer. Walt Rogers WX |
Custom maps for GlidePlan | 2KA | Soaring | 2 | December 28th 14 08:26 PM |
New SeeYou 6.1 - New vector maps and satellite image maps - very cool! | Paul Remde | Soaring | 9 | June 6th 14 04:58 AM |
Paper Maps - Glideplan alternative ? | Dave Nadler | Soaring | 5 | May 30th 12 05:29 PM |
More GlidePlan 2008 contest maps now available | Matt Herron Jr. | Soaring | 0 | June 30th 08 12:56 AM |
GlidePlan Experience | John Seaborn | Soaring | 5 | July 14th 07 06:53 AM |
