18m here http://wgc2018.onglide.com/current-d...?class=18meter
Anyone know how the live tracking speeds are calculated? I see guys flying together with speeds that don't correlate with start times. Go 70!! Go 5E!! Go XG! (CA import tariff cost you one exclamation, sorry :-)) Evan Ludeman / T8 |
On 29/07/2018 14:40, Tango Eight wrote:
18m here http://wgc2018.onglide.com/current-d...?class=18meter Anyone know how the live tracking speeds are calculated? I see guys flying together with speeds that don't correlate with start times. Go 70!! Go 5E!! Go XG! (CA import tariff cost you one exclamation, sorry :-)) Evan Ludeman / T8 As far as I know it uses the same method of calulating distance as a scoring program. Start time, rounding TPs and current location come from monitoring the flarm position. Given distance done and time from start gives the speed. The onglide software is however at the mercy of the quality of flarm coverage so if a particular glider has poor coverage near the start or TPs then it can miss the location at some critical times. This leads to cases where the software doesn't register that a glider has started or rounded a TP. Clicking on the flag for a contestant will bring up the details and you can see what it thinks is the next target. What is normally the case for the situation you describe is that for a glider showing a much slower speed it has 1)Missed the correct start time i.e. the last crossing of the start line so it is using an earlier start time from a previous crossing of the start line whilst milling around waiting to start. or 2) Missed the fix for rounding a TP so their scoring distance for the calculation doesn't increase leading to their speed dropping off from that point onwards. Remember that you can click on the different icons multiple times to show different versions of the data. Clicking through to "Actuals" from "Handicapped" removes a few idiosyncrasies that show early on in the flight which is an artifact of scoring UK handicapped comps even though in this comp there is no handicapping.. Clicking on the height icon also changes to height above ground which can be more informative as the they start with a ground level of ~1600ft at Hosin. -- Nick Hill |
TIANGONG 1 Live tracking | Byker | Aviation Photos | 1 | April 1st 18 05:01 PM |
Live tracking and media done well | [email protected] | Soaring | 0 | July 2nd 17 11:08 PM |
Improved live tracking for the SSA membership? | Sean Fidler | Soaring | 83 | April 22nd 17 05:31 AM |
Live tracking available now (and for the next 13 days!) | Sean F (F2) | Soaring | 2 | January 7th 13 12:30 AM |
UK Grand Prix Live tracking.... | Nick Farrell | Soaring | 0 | August 31st 08 06:54 PM |
