https://www.avweb.com/avwebflash/new...-231613-1.html
FAA Approves Ultralight VTOL By Russ Niles | September 30, 2018 Hoversurf says the FAA has signed off on the first eVTOL https://www.hoversurf.com/news/manag...your-live-site to be approved for general use in the U.S. and orders are now being taken for the Scorpion 3 from the Watsonville, California, company. It costs $150,000 and the first one has been sold to the Dubai Police. The single-seat quadcopter has been accepted as an ultralight by the FAA, which means no pilot certificate is required. The device is said to be able to go up to 60 MPH with about 20 minutes of endurance. While the aircraft is limited in both performance and market appeal, its approval is considered significant by industry watchers. TransportUp, a newsletter that follows the eVTOL industry, said the FAA approval, which was granted Sept. 10, should make it easier for others, including more complex and capable designs, to follow. “HoverSurf sets the stage for step by step certification of larger and more advanced aircraft,” the newsletter said. “This step means that the FAA is ready to begin certification hardware and software technology for flying cars.” Titan Top List prepared the following video. view on YouTube: https://www.youtube.com/watch?v=9Fthyu3k-CY Comments (2) Motorcycle gear is completely useless when falling from 10 stories (or falling just one foot into the whirling blades of a Cuisinart blender). This thing will have such a high death to miles traveled ratio that no one will be able to afford the insurance. Posted by: Mark Fraser | October 1, 2018 8:31 AM Report this comment Ref: the3 above comment... There is no way this is a finished product. WAY to much liability for the company. Most likely, the finished product will prove to have blade/pilot protection, etc. The biker gear though, that's kinda special, lol. I can see protection from some things if it's an open cockpit, but yeah, not gonna help in crash from anything above 2' AGL LOL! Posted by: K Mart | October 1, 2018 9:06 AM Report this comment ----------------------------------- https://www.hoversurf.com/news/manag...your-live-site What is this? You have witnessed the birth of a new era of human evolution. Due to the evolution of drone technologies, personal drones have appeared in the world. This phenomenon is called eVTOL. It means “electrical vertical take-off and landing”. We design and create products for this new market. What you see now is a single personal drone - the Hoverbike S3 2019. This drone is officially approved by the United States FAA. Our hoverbike falls under Ultralight Aircraft, which means no pilot license or certification of the device is needed for use. We give you the freedom of flight. AIR MAP, a mobile application helps you navigate in the air while not interfering with others or in restricted flight zones. HOVERBIKE* Hoverbike frame is: a supporting power platform, made in the form of a spatial carbon monocoque. The overlap of the cross forming is reinforced and fixed by power plates from below and from above. On the end sections of the power platform, independently working sensored engines with propellers are mounted on the beams. Above the center structure of the supporting power platform a module containing our control means, on-board flight computer, sensors, battery and generator are all housed. *patented 180KG Payload https://youtu.be/OfsVjc7Dbo0 https://youtu.be/K4Fr9P3PJng CARBON FIBER BODY We have designed a monocoque frame created using different types of carbon fiber technology. The whole frame is made by a single element, which gives the stiffness of the structure all while reducing the weight by a factor of 2 compared to our previous aluminum model. The new ergonomics of the pilot's seat allows a person to sit comfortably at any height. In this model, stability is improved by spacing the axes by 5 cm (1.9 in). In this case, the dimensions of the hoverbike allow it to be rolled in a standard doorway while also having ability to take-off and land from an ordinary parking space. The weight of the hoverbike is 114 kg (253 pounds) limited by law, but by reducing the weight of the frame it allowed us to install a more capacious battery. Our safe flight altitude is 5 meters above the ground (16 feet), but the pilot himself can adjust the limit to their comfortability. The maximum speed is limited to 96 km / h (60 mph or 52 knots) according to the requirements of the law. SAFETY Hoversurf's new flight computer consisting of 3 separate blocks connected by CAN bus with its own processor in each unit, an external information display, a tuning system, and an updated firmware V.1085 which is designed specifically for a hoverbike S3. Auto-take-off (AT), auto-landing (AL), Alt Hold, Manual, and RC control are also available. Anatomical arm-adjustable joysticks with covers made of genuine leather, dashboard convenient for glove use, laser all-weather LiDAR. The S3 model also includes, the triple security system: electronic (emergency landing, sound and visual warning system, anti-interference screening), mechanical (kill switch) and passive (embedded deformation zones, power fences, and protective elements for the pilot from carbon with reinforcement). POWER LiNiMnCoO2 - Lithium manganese nickel. This chemistry adds nickel to the IMR chemistry above, making it a "hybrid" chemistry. It combines the safety and low resistance of manganese and the high energy of nickel. The resulting battery chemistry gives you a reasonably high capacity and a high discharge current. The chemistry is very stable, meaning that you don't need expensive built-in protective circuits. There is extensive innovation within this chemistry as well. Hoverbike S3 2019 contains this hybrid type battery with a capacity of 12.3 kWh, which allows you to fly up to 40 minutes in the drone mode. The actual flight time with the pilot is between 10 to 25 minutes dependent on weight and weather conditions. A new portable home charging pack allows quick charging in as little as 2.5 hours without removing the batteries. A passive cooling system, which operates due to the difference in air pressure above and below the propellers is now built into body. New engines with increased power to 33 kW each. New 3-bladed carbon propellers are quieter by 10% than double-bladed propellers, smaller in diameter by 5 cm and give a total thrust of 364 kg (802 pounds). Hoverbike S3 2019 limited edition $150.000 Net price S3 2019 requires a $10,000 reservation deposit. Reserve your hoverbike today for delivery in 2 to 6 months. Reservation Holder Update S3 2019 deliveries are beginning in the US based on when you made your reservation. Reservation holders will receive an email when it’s time to place their order. -------------------------------------- |
| Thread Tools | |
| Display Modes | |
| City Of Santa Monica Approves Runway Shortening | Larry Dighera | Piloting | 1 | August 17th 17 02:59 AM |
| FAA approves AMOC for Grob 109 AD 2012-10-11 | Frank Whiteley | Soaring | 0 | October 6th 12 02:07 AM |
| Hawk Sport Ultralight - Sun N Fun 2010 - Hawk Sport Ultralight Sun n Fun 2010 (Custom) (2).jpg | Glen in Orlando | Aviation Photos | 0 | April 14th 10 07:11 PM |
| Senate Committee on Commerce, Science and Transportation Approves User Fee Legislation | Larry Dighera | Piloting | 0 | May 23rd 07 07:05 PM |
| FAA approves O'Hare expansion plan | Hilton | Piloting | 19 | October 7th 05 01:23 AM |
