Hello everyone, this is my first post. I am new to soaring and have acquired a glider with an LXNAV 8000 already installed. I noticed yesterday that the outside temperature (OAT) is incorrect by about 20 degrees F. I placed the probe in a bath of ice water and it read 50 degrees F and responded to temperature changes. I have not found anything in the manual nor on the LXNAV website. Does anyone know where I should go to look for information on this issue? I don't know if the instrument is adjustable, programable or if the probe needs replacment, etc. Any ideas or thoughts would be appreciated. Thanks,
Deming |
At 18:25 07 December 2018, Deming Gray wrote:
Hello everyone, this is my first post. I am new to soaring and have acqui= red a glider with an LXNAV 8000 already installed. I noticed yesterday tha= t the outside temperature (OAT) is incorrect by about 20 degrees F. I plac= ed the probe in a bath of ice water and it read 50 degrees F and responded = to temperature changes. I have not found anything in the manual nor on the= LXNAV website. Does anyone know where I should go to look for information= on this issue? I don't know if the instrument is adjustable, programable = or if the probe needs replacment, etc. Any ideas or thoughts would be appr= eciated. Thanks, Deming Email your problem to |
Deming,
In the user manual for Ver 6.04, section 5.1.11.1 it explains how to adjust the temperature offset. Manuals can be downloaded from the LXNAV website he https://gliding.lxnav.com/lxdownloads/manuals/ I'm also not sure that putting the probe in water was a good thing as I believe there is a small current that runs through the probe and getting it wet may not be good. |
On Friday, December 7, 2018 at 2:13:56 PM UTC-8, Dave Springford wrote:
Deming, In the user manual for Ver 6.04, section 5.1.11.1 it explains how to adjust the temperature offset. Manuals can be downloaded from the LXNAV website he https://gliding.lxnav.com/lxdownloads/manuals/ I'm also not sure that putting the probe in water was a good thing as I believe there is a small current that runs through the probe and getting it wet may not be good. Getting the probe wet is not a problem and calibrating for 0C in an ice bath is a great diagnostic idea. |
Putting the probe in ice water is the best way to get a true 32 deg F
reading.Â* It won't hurt the probe. On 12/7/2018 3:13 PM, Dave Springford wrote: Deming, In the user manual for Ver 6.04, section 5.1.11.1 it explains how to adjust the temperature offset. Manuals can be downloaded from the LXNAV website he https://gliding.lxnav.com/lxdownloads/manuals/ I'm also not sure that putting the probe in water was a good thing as I believe there is a small current that runs through the probe and getting it wet may not be good. -- Dan, 5J |
On Friday, December 7, 2018 at 4:57:20 PM UTC-6, Dan Marotta wrote:
Putting the probe in ice water is the best way to get a true 32 deg F reading.Â* It won't hurt the probe. On 12/7/2018 3:13 PM, Dave Springford wrote: Deming, In the user manual for Ver 6.04, section 5.1.11.1 it explains how to adjust the temperature offset. Manuals can be downloaded from the LXNAV website he https://gliding.lxnav.com/lxdownloads/manuals/ I'm also not sure that putting the probe in water was a good thing as I believe there is a small current that runs through the probe and getting it wet may not be good. -- Dan, 5J Perfect, Dan! That's how you calibrate a temp probe. If we ditched the lousy Fahrenheit scale for Centigrade this would be known more widely. Melting ice and boiling water are the Standards (at sea level) to establish 0 deg C and 100 deg C. Congrats, you made an important step to seeing the superiority of the metric system. Now let's talk about how a 10x10x10 cm volume of water makes 1 liter and also weighs 1kg. It could all be so easy... Herb, J7 |
On Saturday, December 8, 2018 at 10:45:21 AM UTC-6, Dan Marotta wrote:
Sorry Herb, but that was Darryl who used the 0 deg C for the ice bath.Â* I was just musing the other day about why, when listening to our AWOS recordings they use inches of mercury for the altimeter setting, feet for cloud layers, knots for winds, and, phhhht... Celsius for the temperature. Why screw up a perfectly good recording with that metric crap?Â* My pink little body is comfortable at 72 deg F.Â* I just don't comprehend 22.22222 deg C, 295.3722 deg Kelvin, or 531.67 deg Rankin.Â* Real men don't need 10, 10, 10 to make their calculations easy.Â* We still can, but we just don't want to.Â* Can't we all just live together in peace?Â* Kum bi ya... :-D On 12/8/2018 7:10 AM, wrote: On Friday, December 7, 2018 at 4:57:20 PM UTC-6, Dan Marotta wrote: Putting the probe in ice water is the best way to get a true 32 deg F reading.Â* It won't hurt the probe. On 12/7/2018 3:13 PM, Dave Springford wrote: Deming, In the user manual for Ver 6.04, section 5.1.11.1 it explains how to adjust the temperature offset. Manuals can be downloaded from the LXNAV website he https://gliding.lxnav.com/lxdownloads/manuals/ I'm also not sure that putting the probe in water was a good thing as I believe there is a small current that runs through the probe and getting it wet may not be good. -- Dan, 5J Perfect, Dan! That's how you calibrate a temp probe. If we ditched the lousy Fahrenheit scale for Centigrade this would be known more widely. Melting ice and boiling water are the Standards (at sea level) to establish 0 deg C and 100 deg C. Congrats, you made an important step to seeing the superiority of the metric system. Now let's talk about how a 10x10x10 cm volume of water makes 1 liter and also weighs 1kg. It could all be so easy... Herb, J7 -- Dan, 5J Dan, background and personal history matter. If you had spent the first 35 years of your life around a highly rational (metric) system of measures - which the French came up with, hail to them - you'd feel different about the helter-skelter BS system we are using. Btw, if you work in most any industry these days in the US, you're on metric. Of course, the sciences have been forever. Has nothing to do with peaceful co-existence, all with sanity and rationality. Herb, J7 |
US 1986-08800 VC-25A as 82-8000.jpg | Joseph Testagrose | Aviation Photos | 0 | April 20th 15 12:46 PM |
LX 8000 problem | Philip van de Donk | Soaring | 0 | February 24th 14 11:03 AM |
Politically Incorrect, Historically Accurate Hymnals | Bill Kambic | Naval Aviation | 0 | November 10th 08 10:32 PM |
Warning: GPS data incorrect | Cheetah236 | Instrument Flight Rules | 17 | September 23rd 05 07:50 AM |
Incorrect Coastlines..Channel Islands....HELP !!!! | Derek | Simulators | 0 | March 23rd 05 11:50 PM |
