Hi,
I'm going to have a LX5000 FAI. The whole point of the following questions is to know whether I should keep my Volkslogger or not: I have an IPAQ with Winpilot. Can you correct me if I'm wrong, add your comments / experience on the subject: 1) From what I've read on the filser web site, you can get NMEA sentences out of the LX5000, which could then feed winpilot with GPS information. This is very basic and I guess should work as advertised. Any experience on that ? Couldn't find the wiring diagram on the website or online documentation though...Any idea where I can get it? or is it supposed to come with the unit ? 2) The LX5000 FAI has engine noise level sensor. This information can be turned on and stored in the IGC file. 3) Can Winpilot download/upload flights/turnpoints/info to and from the LX5000 ? I've seen that flyWithCE DownLoader could do that. Has anyone been using it ? If so, are you happy with it ? Thanks, Ludovic |
Can't answer most of your questions except the last one.
I'm using flyWithCE DownLoader with an LX1600 / Colibri combination.It works faultlessly 100% of the time. Best Euro 15 I've spent on my saoring so far! As to why to keep the Volkslogger in general. If you fly comps having a backup IGC logger could save you a days score one day. Ian |
go to the LX navigation website, www.lxnavigation.si, click on LX
Navigation and on downloads in the next window, then manuals on download menu. You can find a manual for all the products there in If you are concerned about having a backup system keep the VL. Otherwise, the 5000 will do everything you want and then some. I have a 7000 and can run any IPAQ nav program. The data stream output has to be set to winpilot. I believe the 5000 is virtually the same. Wings and Wheels also should have the manual on their website. Chip Fitzpatrick |
X-no-archive: yes
In article , Ludovic Launer writes Hi, I'm going to have a LX5000 FAI. The whole point of the following questions is to know whether I should keep my Volkslogger or not: I have an IPAQ with Winpilot. Can you correct me if I'm wrong, add your comments / experience on the subject: 1) From what I've read on the filser web site, you can get NMEA sentences out of the LX5000, which could then feed winpilot with GPS information. This is very basic and I guess should work as advertised. Any experience on that ? Couldn't find the wiring diagram on the website or online documentation though...Any idea where I can get it? or is it supposed to come with the unit ? ----snip---------- I would have expected it to come with the unit, but I have a wiring diagram (includes other LX recorders as well) which I will post at: http://www.spsys.demon.co.uk/temp/LX-wiring.pdf Best regards, Tim Newport-Peace "Indecision is the Key to Flexibility." |
Thanks a lot.
Where are NMEA sentences coming out from ? From the RS232C ? or from the PC-RS232C ? Or both maybe ? Is the BINDER 5pin male the round shape connector ? Regards, Ludovic I would have expected it to come with the unit, but I have a wiring diagram (includes other LX recorders as well) which I will post at: http://www.spsys.demon.co.uk/temp/LX-wiring.pdf |
X-no-archive: yes
In article , Ludovic Launer writes Thanks a lot. Where are NMEA sentences coming out from ? From the RS232C ? or from the PC-RS232C ? Or both maybe ? As I see it... The connector marked 'SUD25 Female' is on the back of the LX5000. The TXD output (pin 20) is common to the RS232C and PC-RS232C so you have a choice where you connect your PDA, but using the RS232C is probably better as then the wiring can be behind the panel. The PC-RS232C is primarily intended for connecting a PC for downloading IGC files. Is the BINDER 5pin male the round shape connector ? Yes. It is the same style of connector but the male variant of the female socket used on older Volksloggers, Tim Newport-Peace "Indecision is the Key to Flexibility." |
"Ludovic Launer" wrote in message ...
Thanks a lot. Where are NMEA sentences coming out from ? From the RS232C ? or from the PC-RS232C ? Or both maybe ? Is the BINDER 5pin male the round shape connector ? Regards, Ludovic I replaced the little 5-pin round connector with a std 9-pin plug for my LX 5000. This is used to download data from the unit as well as connecting to my PDA to get the NMEA sentences. Clinton LAK 12 |
I've been considering purchasing an LX 5000. I was thinking if I did
so I could do away with the PDA. Given the capabilities built into the LX unit itself, what does running WinPilot or other PDA based program give you? (Besides color moving map). (Clint) wrote in message . com... "Ludovic Launer" wrote in message ... Thanks a lot. Where are NMEA sentences coming out from ? From the RS232C ? or from the PC-RS232C ? Or both maybe ? Is the BINDER 5pin male the round shape connector ? Regards, Ludovic I replaced the little 5-pin round connector with a std 9-pin plug for my LX 5000. This is used to download data from the unit as well as connecting to my PDA to get the NMEA sentences. Clinton LAK 12 |
![]() LX unit itself, what does running WinPilot or other PDA based program give you? (Besides color moving map). "Belt and suspenders" as we say in French... It's usefull sometimes to have one unit with a turn point / col / airfield as the goto point, and another having a field as the goto point. I use that method very often. Plus, the Winpilot PDA brings color moving map + portable system to upload / downloaf flights. I haven't used a LX5000 yet, but I guess I'll be using both the LX and Winpilot. Which means I can do without the Volkslogger now... Anyone looking for a second-hand VL ? Regards, Ludovic |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
LX5000 help | Ted Wagner | Soaring | 1 | April 29th 04 03:27 AM |
iPaq and LX5000 connectivity question (hardware?) | Ted Wagner | Soaring | 1 | April 22nd 04 09:29 PM |
Any LX5000, SeeYou Mobile & Downloader users ... | Ted Wagner | Soaring | 2 | April 4th 04 05:48 PM |
