Taildragger Technique for Gliders
Old December 28th 18, 12:43 AM posted to rec.aviation.soaring
Papa3[_2_]
Default Taildragger Technique for Gliders
Is anyone aware of a glider textbook or manual which teaches the details of taildragger takeoffs and landings in gliders? I have lots of examples that I've used personally with students based on my power training a Champ and dozens of available texts oriented at the power taildragger training.
Looking back through RAS, I found a couple of old threads but not what I was looking for. I just want to re-use someone else's diagrams and text. Failing that, I'll end up formally writing up my own notes along with those from a couple of other club CFIGs.
Not necessarily looking for a new thread on "why learning in Schweizers sucks" or "how come Americans don't know how to land." But it's Winter in the northern hemisphere, so I can probably predict where this will end up.
Erik Mann (P3)
Old December 28th 18, 01:13 AM posted to rec.aviation.soaring
Erik Mann (P3)
Wolfgang Langewiesche had it all figured out in the late 30's of the last century. His book "Stick and Rudder" is unsurpassed in clarity and insights. All you ever wanted to how on how to control a glider or airplane.
Herb, J7
Old December 28th 18, 10:43 AM posted to rec.aviation.soaring
Martin Gregorie[_6_]
airplane.
Herb, J7
+1
Martin | martin at
Gregorie | gregorie dot org
Old December 28th 18, 01:48 AM posted to rec.aviation.soaring
6PK
Erik Mann (P3)
Not much different than an airplane; two point touchdown in a glider as in a full stall landing in an airplane in calm conditions and medium to high energy mainwheel touchdown/approach in a glider as in a wheel landing in an airplane.
Old December 28th 18, 01:53 AM posted to rec.aviation.soaring
6PK
Not necessarily looking for a new thread on "why learning in Schweizers sucks" or "how come Americans don't know how to land." But it's Winter in the northern hemisphere, so I can probably predict where this will end up..
Erik Mann (P3)
To correct,I should have;"and medium to high energy mainwheel touchdown/approach in a glider as in a wheel landing in an airplane"- in windy/gusty conditions.
Cookie
Oh boy...here comes all the arguments "for" and "against" the various techniques! I already have 4 disagreements with the last two posts! LOL...but not in the mood for arguing...so you guys have at it!
To Erik's point...lots of training stuff on the "net" for soaring...but nobody seems to go into the concept of taildragger gliders specifically, as they do in airplanes...hence the so many bad landings we seem to see.
Cookie
Old December 28th 18, 03:28 PM posted to rec.aviation.soaring
kirk.stant
So, Cookie, please be so kind as to educate us on your taildragger techniques (in gliders, of course).
66
Old December 28th 18, 03:48 PM posted to rec.aviation.soaring
Before Cookie starts, Ill add one, I thought, very insightful lesson I had from a instructor I had when learning tail wheel in a J3 cub. I already had 5k hours in sailplanes at this point and he said: "realize that you have to change from normal control to cross control once on the ground, just like you already do in your sailplane!" That was the ahaaa, moment for me. I had already been doing it in my Ventus now just make it happen in the cub, 140 and now the 170B hardest part is using a yoke instead of a stick Flame shields on!
CH
Old December 28th 18, 04:33 PM posted to rec.aviation.soaring
6PK
I will be shocked if there is too much difference of opinion at least on this subject....
Old December 28th 18, 05:28 PM posted to rec.aviation.soaring
Mike C
I had to land my RS-15 on its main wheel and continue to "fly" it on the ground, while still on its main, until I used the effective wheel brake to slow and stop. As soon as the tail wheel would touch the ground there would be very little aileron control. Landing that sailplane in a conventional two point landing would cause a wing drop soon after touchdown resulting in a trip off the edge of the runway. Reworking the flap/aileron mixing cam helped but did not solve the problem. Other RS-15's had the same behavior. My Mini Nimbus was fine with two point landings as well as main wheel landings.
Mike
Aerotow Technique Flapped gliders Don Johnstone[_4_] Soaring 0 December 15th 16 11:00 PM
There's No Taildragger Like A Texas Taildragger - TT3.jpg (1/1) Mitchell Holman[_4_] Aviation Photos 0 June 6th 09 02:00 PM
There's No Taildragger Like A Texas Taildragger - TT1.jpg (1/1) Mitchell Holman[_4_] Aviation Photos 0 June 6th 09 02:00 PM
There's No Taildragger Like A Texas Taildragger - 001index.jpg (0/1) Mitchell Holman[_4_] Aviation Photos 0 June 6th 09 02:00 PM
There's No Taildragger Like A Texas Taildragger - 001index.jpg (1/1) Mitchell Holman[_4_] Aviation Photos 0 June 6th 09 02:00 PM
