see also
http://www.businessinsider.com/cirru...ictures-2018-5 https://en.wikipedia.org/wiki/Cirrus_Vision_SF50 The Cirrus Vision SF50, also called the "Vision Jet", is a single-engine, low-wing, seven-seat, very light jet aircraft designed and produced by Cirrus Aircraft. It is the first civilian single-engine jet to achieve certification with the FAA. This makes it the smallest and least expensive certified jet currently on the market. It is also equipped with the company's Cirrus Airframe Parachute System (CAPS) (which deploys from the nose of the aircraft), making it the first jet of any kind to come with a whole-aircraft ballistic parachute. The aircraft was initially developed under the project name "The Jet", but Cirrus announced the marketing name of "Vision SJ50" on 9 July 2008. In March 2009, the aircraft was redesignated the "Vision SF50". Since its market introduction in 2016, it is often referred to simply as the "Vision Jet". The prototype aircraft was first shown publicly at the annual Cirrus Migration on 26 June 2008 and first flown on 3 July 2008. The SF50 is intended to be a step-up aircraft for pilots who have flown the Cirrus SR20, SR22 and other high-performance light aircraft. The aircraft was Federal Aviation Administration type-certified on 28 October 2016, after a ten-year development process, marked by aircraft technical and company financial challenges. The Vision SF50 is made entirely of composite material (another first in the production jet industry) and is a low-wing cantilever monoplane powered by a single Williams FJ33 turbofan mounted above the rear fuselage. It has a v-tail and a retractable tricycle landing gear. The enclosed cabin is 5.1 ft (1.56 m) wide and is 4.1 ft (1.24 m) high with room for seven. Access to the cabin is through a clamshell door on the left hand side. The SF50 is designed for 12,000 flight hours. In April 2017, Cirrus stated that it plans to deliver between 25 and 50 aircraft in 2017 and between 75 and 125 in 2018. The company was awarded a production certificate on 2 May 2017, which allows aircraft production without FAA inspection of each individual aircraft and thus allows the company to produce a larger number of aircraft more quickly. As 15% of its 600 orders are intended for the European market, Cirrus received EASA certification at the May 2017 EBACE. By July 2017, seven had been delivered and one per week were being produced. Role Very light jet Manufacturer Cirrus Aircraft First flight First prototype: 3 July 2008 Conforming prototype: 24 March 2014 First production: 5 May 2016 Status In production Produced December 2016–present Number built 39, including prototypes (March 2018) Unit cost US$1.96 million (2016) AVweb describes the Vision Jet as both a great airplane and a significant one by how well the design resonates with the intended buyer. At FL270 and ISA +15 °C it cruises at 270 kn (500 km/h) and consumes 57 US gal/h (216 l/h). At the same FL270, ISA +15 °C, the Flightglobal review reported 59 US gal/h (223 l/h) at Mach 0.46 - 287 kn (532 km/h) and in 45 US gal/h (170 l/h) at Mach 0.38 - 235 kn (435 km/h) long-range cruise. Aviation Week & Space Technology notes Cirrus has succeeded in producing the “lowest, slowest and least expensive” jet. High-lift airfoils emphasize low-speed performance over top-end speed with a turboprop-like VMO of 250 kn (463 km/h) IAS or a 0.53 MMO, and a FL280 ceiling. It reported a 68 US gal (257 l)/h - 456 lb (207 kg)/h fuel burn at its 307 kn (569 km/h) TAS maximum cruise (at 5,575 lb (2,529 kg), FL280, ISA+6°C) and 49 US gal (185 l)/h fuel burn at 270 kn (500 km/h). Like an early 1970s Citation 500, aerodynamic drag prevents it to exceed VMO in 300–500 ft/min (1.5–2.5 m/s) descents for which it is kept at max continuous thrust unlike most current jets. In April 2018, the design was named the 2017 winner of the Robert J. Collier Trophy for the "greatest achievement in aeronautics or astronautics in America" in the past year. The trophy was awarded for "designing, certifying, and entering-into-service the Vision Jet — the world’s first single-engine general aviation personal jet aircraft with a whole airframe parachute system". Specifications (Vision SF50) General characteristics Crew: one Capacity: six passengers Length: 30 ft 11 in (9.42 m) Wingspan: 38 ft 8 in (11.79 m) Height: 10 ft 11 in (3.32 m) Empty weight: 3,572 lb (1,620 kg) Gross weight: 6,000 lb (2,722 kg) Fuel capacity: 2000 lb (907 kg) Powerplant: 1 × Williams FJ33-5A turbofan, 1,800 lbf (8.0 kN) thrust Performance Cruise speed: 300 kn (345 mph; 556 km/h) Stall speed: 67 kn (77 mph; 124 km/h) with flaps Range: 600 nmi (690 mi; 1,111 km) with 1,200 lb (544 kg) payload at max cruise speed of 300 kn or 1,200 nmi with 200 lb (91 kg) payload at economy cruise speed of 240 kn Service ceiling: 28,000 ft (8,500 m) Time to altitude: FL280 in 20 minutes Avionics Garmin G3000 based Cirrus Perspective Touch * |
Miloch wrote in
news ![]() see also http://www.businessinsider.com/cirru...ght-review-pic tures-2018-5 https://en.wikipedia.org/wiki/Cirrus_Vision_SF50 The Cirrus Vision SF50, also called the "Vision Jet", is a single-engine, low-wing, seven-seat, very light jet aircraft designed and produced by Cirrus Aircraft. It is the first civilian single-engine jet to achieve certification with the FAA. This makes it the smallest and least expensive certified jet currently on the market. I guess the BD 5J doesn't count because of it's official homebuilt status. It is definately cheaper tho........... |
On Sun, 20 May 2018 21:34:07 -0500, Mitchell Holman
wrote: Miloch wrote in news ![]() see also http://www.businessinsider.com/cirru...ght-review-pic tures-2018-5 https://en.wikipedia.org/wiki/Cirrus_Vision_SF50 The Cirrus Vision SF50, also called the "Vision Jet", is a single-engine, low-wing, seven-seat, very light jet aircraft designed and produced by Cirrus Aircraft. It is the first civilian single-engine jet to achieve certification with the FAA. This makes it the smallest and least expensive certified jet currently on the market. I guess the BD 5J doesn't count because of it's official homebuilt status. It is definately cheaper tho........... Or the Sonex SubSonex... https://en.wikipedia.org/wiki/Sonex_Aircraft_SubSonex |
Cirrus SR20 pics 2 [6/7] - Continental IO-360-ES fitted to a Cirrus SR20.jpg (1/1) | Miloch | Aviation Photos | 0 | October 12th 17 03:05 PM |
Cirrus SR20 pics 2 [3/7] - Cirrus-SR20_Interior-3.jpg (1/1) | Miloch | Aviation Photos | 0 | October 12th 17 03:05 PM |
Cirrus SR20 pics 1 [1/7] - A Cirrus SR20 belonging to Western Michigan University.jpg (1/1) | Miloch | Aviation Photos | 0 | October 12th 17 03:03 PM |
Paintjobs 8 - Cirrus Vision.jpg (1/1) | Mitchell Holman[_8_] | Aviation Photos | 0 | November 9th 14 12:50 PM |
Cirrus Vision SJ50 | Glenn[_2_] | Aviation Photos | 0 | April 24th 10 10:29 AM |
