https://en.wikipedia.org/wiki/Vought_F-8_Crusader
The Vought F-8 Crusader (originally F8U) is a single-engine, supersonic, carrier-based air superiority jet aircraft built by Vought for the United States Navy and Marine Corps, replacing the Vought F7U Cutlass, and for the French Navy. The first F-8 prototype was ready for flight in February 1955. The F-8 served principally in the Vietnam War. The Crusader was the last American fighter with guns as the primary weapon, earning it the title "The Last of the Gunfighters". The RF-8 Crusader was a photo-reconnaissance development and operated longer in U.S. service than any of the fighter versions. RF-8s played a crucial role in the Cuban Missile Crisis, providing essential low-level photographs impossible to acquire by other means. U.S. Naval Reserve units continued to operate the RF-8 until 1987. The Crusader was powered by a Pratt and Whitney J57 turbojet engine. The engine was equipped with an afterburner that, unlike on later engines, was either fully lit, or off (i.e. it did not have "zones"). The engine produced 18,000 lb of thrust at full power, enough to allow the F-8 to climb straight up in clean configuration. The Crusader was the first jet fighter in US service to reach 1,000 mph; U.S. Navy pilot R.W. Windsor reached 1,015 mph on a flight in 1956. The most innovative aspect of the design was the variable-incidence wing which pivoted by 7° out of the fuselage on takeoff and landing (not to be confused with variable-sweep wing). This allowed a greater angle of attack, increasing lift without compromising forward visibility. This innovation helped the F-8's development team win the Collier Trophy in 1956. Simultaneously, the lift was augmented by leading-edge slats drooping by 25° and inboard flaps extending to 30°. The rest of the aircraft took advantage of contemporary aerodynamic innovations with area-ruled fuselage, all-moving stabilators, dog-tooth notching at the wing folds for improved yaw stability, and liberal use of titanium in the airframe. The armament, as specified by the Navy, consisted primarily of four 20 mm (.79 in) autocannon; the Crusader happened to be the last U.S. fighter designed with guns as its primary weapon. They were supplemented with a retractable tray with 32 unguided Mk 4/Mk 40 Folding-Fin Aerial Rocket (Mighty Mouse FFARs), and cheek pylons for two guided AIM-9 Sidewinder air-to-air missiles. Vought also presented a tactical reconnaissance version of the aircraft called the V-392. Role Fighter aircraft National origin United States Manufacturer Vought First flight 25 March 1955 Introduction March 1957 Retired 1976 (fighter, U.S. Navy) 29 March 1987 (photo reconnaissance, U.S. Naval Reserve) 1991 (Philippines) 19 December 1999 (fighter, France) Status Retired completely in 2000 Primary users United States Navy United States Marine Corps French Navy Philippine Air Force Number built 1,219 Developed into Vought XF8U-3 Crusader III LTV A-7 Corsair II The Crusader was not an easy aircraft to fly, and was often unforgiving in carrier landings, where it suffered from poor recovery from high sink rates, and the poorly designed, castoring nose undercarriage made it hard to steer on the deck. Safe landings required the carriers to steam at full speed to lower the relative landing speed for Crusader pilots. The stacks of the oil-burning carriers on which the Crusader served belched thick black smoke, sometimes obscuring the flight deck, forcing the Crusader's pilot to rely on the landing signal officer's radioed instructions. It earned a reputation as an "ensign eliminator" during its early service introduction. The nozzle and air intake were so low when the aircraft was on the ground or the flight deck that the crews called the aircraft "the Gator". Not surprisingly, the Crusader's mishap rate was relatively high compared to its contemporaries, the Douglas A-4 Skyhawk and the F-4 Phantom II. However, the aircraft did possess some amazing capabilities, as proved when several Crusader pilots took off with the wings folded. One of these episodes took place on 23 August 1960; a Crusader with the wings folded took off from Napoli Capodichino in full afterburner, climbed to 5,000 ft (1,500 m) and then returned to land successfully. The pilot, absentminded but evidently a good "stick man," complained that the control forces were higher than normal. The Crusader was capable of flying in this state, though the pilot would be required to reduce aircraft weight by ejecting stores and fuel before landing. In all, 1,261 Crusaders were built. By the time it was withdrawn from the fleet, 1,106 had been involved in mishaps. Only a handful of them were lost to enemy fire in Vietnam. Despite the "last gunfighter" moniker, the F-8s achieved only four victories with their cannon; the remainder were accomplished with AIM-9 Sidewinder missiles, partly due to the propensity of the 20 mm (.79 in) Colt Mk 12 cannons' feeding mechanism to jam under G-loading during high-speed dogfighting maneuvers. Between June and July 1966, during 12 engagements over North Vietnam, Crusaders claimed four MiG-17s for two losses. The Crusader would claim the best kill ratio of any American type in the Vietnam War, 19:3. Of the 19 aircraft claimed during aerial combat, 16 were MiG-17s and three were MiG-21s. U.S. records only indicate 3 F-8s lost in aerial combat, all to MiG-17 cannon fire in 1966, but the VPAF claimed 11 F-8s were shot down by MiGs. A total of 170 F-8 Crusaders would be lost to all causes – mostly ground fire and accidents -during the war. Specifications (F-8E) General characteristics Crew: 1 Payload: 5,000 lb (2,300 kg) of weapons Length: 54 ft 3 in (16.53 m) Wingspan: 35 ft 8 in (10.87 m) Height: 15 ft 9 in (4.80 m) Wing area: 375 ft² (34.8 m²) Airfoil: NACA 65A006 mod root, NACA 65A005 mod tip Aspect ratio: 3.4 Empty weight: 17,541 lb (7,956 kg) Loaded weight: 29,000 lb (13,000 kg) Max. takeoff weight: 34,000 lb (15,000 kg) Zero-lift drag coefficient: 0.0133 Drag area: 5.0 ft² (0.46 m²) Fuel capacity: 1,325 US gal (5,020 L) Powerplant: 1 × Pratt & Whitney J57-P-20A afterburning turbojet Dry thrust: 10,700 lbf (47.6 kN) Thrust with afterburner: 18,000 lbf (80.1 kN) Performance Maximum speed: Mach 1.86 (1,225 mph, 1,975 km/h) at 36,000 ft (11,000 m) Cruise speed: 495 kn (570 mph, 917 km/h) Combat radius: 450 mi (730 km) Ferry range: 1,735 mi (2792 km) () with external fuel Service ceiling: 58,000 ft (17,700 m) Rate of climb: 19,000 ft min (96.52 m/s) Wing loading: 77.3 lb/ft² (377.6 kg/m²) Thrust/weight: 0.62 Lift-to-drag ratio: 12.8 Armament Guns: 4× 20 mm (0.79 in) Colt Mk 12 cannons in lower fuselage, 125 rpg Hardpoints: 2× side fuselage mounted Y-pylons (for mounting AIM-9 Sidewinders and Zuni rockets) and 2× underwing pylon stations with a capacity of 4,000 lb (2,000 kg) and provisions to carry combinations of: Rockets: 2× LAU-10 rocket pods (each with 4× 5 inch (127mm) Zuni rockets) Missiles: 4× AIM-9 Sidewinder or Matra Magic (French Navy only) air-to-air missiles 2× AGM-12 Bullpup air-to-surface missiles Bombs: 12× 250 lb (113 kg) Mark 81 bombs or 8× 500 lb (227 kg) Mark 82 bombs or 4× 1,000 lb (454 kg) Mark 83 bombs or 2× 2,000 lb (907 kg) Mark 84 bombs * |
Vought O2U Corsair pics 2 [7/8] - vought-o2u-1m-mexico-1929-eyn6mn.jpg (1/1) | Miloch | Aviation Photos | 0 | July 24th 17 02:56 PM |
Udvar hazy Batch 7 [27/41] - Vought RF-8 Crusader DSC_3693.jpg (1/1) | Indrek[_6_] | Aviation Photos | 0 | November 24th 15 03:58 PM |
Ugly Airplanes, pt 9 - Vought F8U-3 Crusader-III.jpg (1/1) | Mitchell Holman | Aviation Photos | 9 | March 9th 08 05:13 AM |
Nothing but F-8s, Part 2 - Vought F8U-1T Crusader.jpg (1/1) [70K] | Netko | Aviation Photos | 1 | February 23rd 07 03:38 PM |
Nothing but F-8s, Part 2 - Vought F-8E(FN) Crusader.jpg (1/1) [185K] | Netko | Aviation Photos | 0 | February 23rd 07 02:22 PM |
