How to Make a Poor Man's Spar Alignment Tool
Old January 7th 19, 05:30 AM posted to rec.aviation.soaring
OHM Ω http://aviation.derosaweb.net
Default How to Make a Poor Man's Spar Alignment Tool
Hope you find this presentation useful for your winter project enjoyment.
http://aviation.derosaweb.net/presentations/#spartool
Regards, John OHM Ω
Old January 7th 19, 08:19 PM posted to rec.aviation.soaring
Or if you don't have the tools for a DIY tool see:
http://glidersource.com/cgi-bin/post.cgi?id=1306
On Sunday, January 6, 2019 at 8:30:23 PM UTC-8, OHM Ω http://aviation.derosaweb.net wrote:
Regards, John OHM Ω
Old January 7th 19, 10:27 PM posted to rec.aviation.soaring
Steve Bralla manufactured the "Z5" eccentric tool for several years before losing access to the machine tools needed for fabricating them. He kindly offered the rights to me a couple of years ago. I have been building them since then, and although they are not on my website (yet), I am still making and stocking them.
info (at) mmfabrication (dot) com
Old January 8th 19, 04:07 PM posted to rec.aviation.soaring
I've got one of the Z5 eccentric tools, and its a great help. But it can only be inserted when the wings are within about ¼" from closure. It would be even better if more eccentricity was present, to allow the tool to be inserted with the wings further from closure. I think the strength of the plastic tool could be maintained by putting a steel rod down the center.
Old January 8th 19, 04:44 PM posted to rec.aviation.soaring
Depending on the major diameter of the pin, I try to make the smaller eccentric stub as small as I reasonably can without compromising strength. Generally, a pin of 32-36 mm has a stub of around 22 mm, for about 10-14 mm advantage. I have made some pins with a smaller diameter stub, and incorporated a stainless steel reinforcing pin through the center of the stub into the main body. Naturally, this option will cost more. I also have the capability to mill a 1/2 inch square socket in the end for a 1/2 inch drive ratchet in case the handle holes (at 45 degree spacing) aren't sufficient for handle clearance inside the fuselage.
Old January 8th 19, 07:47 PM posted to rec.aviation.soaring
I have updated my simple presentation to add a warning (and a paint scheme) about mistakenly leaving the wooden spar alignment tool in place after finishing rigging instead of replacing it with the proper steel pin. Many thanks to Lee Braith for pointing this flaw out to me.
- John OHM Ω
Old January 8th 19, 10:18 PM posted to rec.aviation.soaring
JS[_5_]
That would be the Cobra one, owned a few. May have one or two at home to sell. Think they're for ASW27/28/29 and Duo.
Old January 7th 19, 09:50 PM posted to rec.aviation.soaring
On Sunday, January 6, 2019 at 11:30:23 PM UTC-5, OHM Ω http://aviation.derosaweb.net wrote:
Regards, John OHM Ω
Thanks Ohm. Have you tried filing part of of the hardwood pin to actually make it "eccentric"? In my glider that part (built into the spar pin) makes a huge difference, as it pulls the two wing halves together as you twist it.
Old January 10th 19, 03:08 AM posted to rec.aviation.soaring
Nice DIY sheet.
Alignment tool for spar pins soartech[_2_] Soaring 5 September 6th 12 06:39 PM
Make yourself known by the market - Powerful marketing tool: MarketingTool Aviation Marketplace 0 December 13th 04 04:48 AM
INS Alignment at Sea Gary Watson Naval Aviation 5 November 9th 03 06:14 PM
INS Alignment at Sea Larry Naval Aviation 28 November 5th 03 01:58 PM
Seneca De-Ice Brush Alignment Tool John Owning 0 September 10th 03 12:03 AM
