Any recommendations or vendors who stock them in North America?
I bought a bag of 50 from Walmart for around $9.00.Â* I use them on the
l'Hotlier connectors for the ailerons in my Stemme and for my seat track stops in my Cessna.Â* My IA approved their use. On 1/14/2019 4:03 PM, George Haeh wrote: Any recommendations or vendors who stock them in North America? -- Dan, 5J |
This was a couple of years ago.Â* I measured one of the pins that came
with my ship and looked for that specific size.Â* Here's an example: https://www.walmart.com/ip/1-5mm-x-3...-Pcs/168313573 Be sure to get the size you need. On 1/14/2019 4:36 PM, Dan Marotta wrote: I bought a bag of 50 from Walmart for around $9.00.Â* I use them on the l'Hotlier connectors for the ailerons in my Stemme and for my seat track stops in my Cessna.Â* My IA approved their use. On 1/14/2019 4:03 PM, George Haeh wrote: Any recommendations or vendors who stock them in North America? -- Dan, 5J |
On Monday, January 14, 2019 at 3:03:51 PM UTC-8, George Haeh wrote:
Any recommendations or vendors who stock them in North America? A piece of twisted locking wire is just as good or better. I've known the manufacturer-supplied safety pins to come off of the hotelier connections on a K21. |
Page 5, Figure 4. https://www.alexander-schleicher.de/...93-001-3_E.pdf
Buy 'em from Schempp Hirth dealer. All other solutions are inferior. T8 |
On Monday, January 14, 2019 at 5:18:34 PM UTC-8, Tango Eight wrote:
Page 5, Figure 4. https://www.alexander-schleicher.de/...93-001-3_E.pdf Buy 'em from Schempp Hirth dealer. All other solutions are inferior. T8 If you can get those they work great. A fellow club member bought an ASW-19 equipped with them and I think they're brilliant. My ASW-15 came over from Germany in the late 90's with AN safety pins tethered to the control rods. You can get them from Aircraft Spruce. They work and because the 15's connections are right near the hatch and easy to access and see, I haven't bothered changing them for something easier. |
T8 is correct. Fit correctly and easy to use.
I think I had those on my '19 and they could be locked in the blind.
The Walmart pins were cheap, about $0.16 each, do the job, and in two years not one has come out in service.Â* They're attached to the aileron control rod by a length of waxed string.Â* YMMV.Â* Of course the Stemme clips are visible during installation, no reaching through a hole to install them.Â* I use a hemostat as a tool to help my clumsy fingers get the pin installed. On 1/14/2019 8:32 PM, wrote: T8 is correct. Fit correctly and easy to use. -- Dan, 5J |
On Tuesday, January 15, 2019 at 7:47:50 AM UTC-8, Dan Marotta wrote:
I think I had those on my '19 and they could be locked in the blind. The Walmart pins were cheap, about $0.16 each, do the job, and in two years not one has come out in service.Â* They're attached to the aileron control rod by a length of waxed string.Â* YMMV.Â* Of course the Stemme clips are visible during installation, no reaching through a hole to install them.Â* I use a hemostat as a tool to help my clumsy fingers get the pin installed. On 1/14/2019 8:32 PM, wrote: T8 is correct. Fit correctly and easy to use. -- Dan, 5J But of course any random metal "thingy" purchased from the great American institution Walmart should be considered flight worthy without question or test. Call me about some ocean front property I have for sale ![]() |
On Monday, January 14, 2019 at 6:03:51 PM UTC-5, George Haeh wrote:
Any recommendations or vendors who stock them in North America? Ok let me be a little clearer. These pins from Schempp or Schiecher are made in such a way that when installed on the Hotelier can't come off, can't be dropped They are installed on many ASW 19/20, Std Cirrus and can be easily connected blind. Not sure if you can go to the Yahoo site to see a picture unless you are a member but here ya go: group.https://groups.yahoo.com/neo/groups/...oFilte r=ALL# For a source in north America you can try Eastern Sailplane, Williams Soaring or M&H Soaring. Colin |
Do L'Hotellier Ball Fittings Wear? | Casey[_2_] | Soaring | 32 | April 15th 16 08:04 AM |
Source of L'Hotellier Fittings? | Six-Seven Romeo | Soaring | 2 | September 1st 15 05:33 PM |
l'Hotellier on EB28 | rlovinggood | Soaring | 5 | January 27th 08 11:32 AM |
L'Hotellier | [email protected] | Soaring | 5 | September 9th 05 04:21 PM |
Hotellier connections | Mike | Soaring | 38 | September 28th 04 04:30 PM |
