Trailer Covers-will that eliminate condensation inside ?
Old January 26th 19, 05:34 PM posted to rec.aviation.soaring
Default Trailer Covers-will that eliminate condensation inside ?
I saw a Trailer cover offered. Seems to cover quite nicely a standard Cobra trailer. Color is white.
I wonder if this a solution to reduce or eliminate formation of condensation inside the trailer walls, especially metal ones.
I would assume that since the top and side walls are somewhat insulated they will cool down slow enough at night so that dew will not form on them.
What do you guys think ?
Dan
Old January 26th 19, 07:11 PM posted to rec.aviation.soaring
We have no clue......where are you?
What works in one geographic area may be poor in another.
So......where are you?!?!
Moon or Mars, you are likely OK.....on earth, may be good, may suck......
Old January 27th 19, 02:53 AM posted to rec.aviation.soaring
On Saturday, January 26, 2019 at 2:11:59 PM UTC-5, Charlie M. (UH & 002 owner/pilot) wrote:
I am located in Northeast of USA
Old January 27th 19, 04:03 AM posted to rec.aviation.soaring
Condensation may happen as a result of one of these two causes:
* the trailer is full of warm humid air (from a hazy humid summer day in the NE US) and then cools off at night to below the dewpoint of that air. A cover won't help with that at all.
* on a not-humid summer night in the NE US, the air in the trailer may not quite cool down to its dewpoint, but under a clear sky the trailer roof (especially if metal) cools further by radiation, causing condensation both above (not an issue) and below (inside the trailer). A cover may help with this - but only if it is thick enough to have a significant insulating effect.
Old January 27th 19, 02:52 PM posted to rec.aviation.soaring
Dan Daly[_2_]
I have an Avionic trailer. With the factory solar fan, air is exchanged, cooler (drier) air enters before dark and condensation is not a problem.
Old January 27th 19, 03:10 PM posted to rec.aviation.soaring
I thought those trailer covers were more to protect trailer GRP surface finish against UV and water degradation than to prevent internal condensation.
CAPA Trailer Covers [email protected] Soaring 3 February 8th 15 07:12 AM
Foam for inside of fiberglass trailer John[_27_] Soaring 9 April 4th 13 04:12 AM
condensation INSIDE of glider parts Brad[_2_] Soaring 2 January 12th 11 07:04 PM
Condensation in hangar karl gruber[_1_] Owning 7 September 19th 07 03:48 PM
