Greetings!
It's the beginning of our soaring season here in Australia - and thought I'd start a checklist for setting a Pocket-PC before (and after) use with navigation. During the week my Pocket-PC is an invaluable work tool - but some of it's 'features' are nuisances in flight! Anyone out there checklist orientated and already been here-done-that?? Power, and Display are two I am constantly grappling with . . . the thing often seems to have a mind of it's own . . . Also: What is the best way to handle reminders during navigation program use? The reminders that pop-up are bad news whilst flying (or driving). I have discovered a setting in: Settings.personal.sounds¬if- ications.notifications.select an event: 'reminders' (scroll right to the bottom) UNTICK: "display message on screen". . . But I am left wondering how do I ever see what those reminders were now that I have switched off the pop-ups to the display? There is often a series of reminder icons along the bottom of the screen - but touching them simply makes them vanish. Anyone know - or can comment? Thanks and best regards, Jim Kelly. (My Pocket-PC is currently an iPaq H5550 with 'Windows 2003'). |
Power, and Display are two I am constantly grappling with . . . the thing often seems to have a mind of it's own . . . What navigation software? and do you use ship power (I hope) or internal battery only? Using ship power, set the Power (untick) 'Turn off device..... x minutes' If battery only, you should untick this as well in flight, but realize it will drain right down if you forget to turn it off. Careful with the unit between flights, pressing ANY button powers it up, and if you have unticked the 'power off' setting you drain the battery. On external battery you can set backlight to full on and not to turn off. Also: What is the best way to handle reminders during navigation program use? The reminders that pop-up are bad news whilst flying (or driving). Turn off display of reminders as you have discovered. You can keep or turn off a sound warning. The icons appear as a reminder so it assumes you will check manually later using the calendar (#2?) button. but why are you scheduling things for a flying day anyway?? -) Other .. get an SD card (512MB SD cards are low cost now, in Canada anyway) or CF card and put all your flight files, profiles, waypoiints, tasks, on it. One day you may lose all your data and have to reset the device to 'empty of user data' to recover. On my SD card I have everything, including Mobile SeeYou executables so I could borrow any pda and go flying. Buy a spare unit one day. If you use your logger GPS, consider a CF GPS as backup. You mentioned driving so I am guessing you have a GPS for it now. Have a spare cable set around. Unless you have a local supply. Check that your 5V power converter is high efficiency and will not drain down your ship battery. Consider a separate battery just for PDA power. Or at least separate from your other nav units. Terrible to lose everything at once. Backup to the SD card before and after any major software change. This lets you restore a unit when it has to be hard reset and you do not have your desktop or laptop with you. Take backup to the desktop regularly, maybe Friday nights before a flying weekend. Winter is coming here, I envy you!! Have fun! Bob |
Thanks for the great advice Bob.
To address your questions: What navigation software? WinPilot for gliding, CoPilot for driving. do you use ship power Whenever possible - but we all need solutions for those times when in another 'vehicle'. Careful with the unit between flights, pressing ANY button powers it up Reminder popups turn the unit on too! (precipitating my main question). check manually later using the calendar (#2?) button Mmm - I tend to often set reminders for longer than a day ("Fred's renewal proposal due in 10 days"). I have a feeling that if such a warning occurs when the message displays are turned off then the silly thing dismisses my reminder altogether . . . Although I could expect to see it on the desktop - I worry that the synch process will dismiss it there too if I don't remember to look carefully before synching!! get an SD card Great advice, along with learning to use the backup program (easy once you release what it is doing and DO send the backup to the 'storage-card' and not to the default location). so I could borrow any pda and go flying Nice benefit - I hadn't realised that! Obviously any licence codes would need consideration. Buy a spare unit one day Bliss! Here are the ways to reach the settings that I have determined need consideration: I have not been definitive as they need to be checked before and after flights. (for Windows Pocket PC 2003 - but not 2nd edition which may differ) Start.Settings.personal.sounds¬ifications.notif ications.select an event: 'reminders' (scroll right to the bottom) change "display message on screen"!! Settings.system.power.main: When on battery power: TURN OFF DEVICE if not used for [3] minutes. When on external power: TURN OFF DEVICE if not used for [30] Minutes. Start.Settings.system.power.USB CHARGING: Make sure tick is on [I use 'fast'] Start.Settings.system.backlight: When on battery power: TURN OFF BACKLIGHT if not used for [3] min. TURN ON BACKLIGHT if button pressed, etc. When on external power: TURN OFF BACKLIGHT if not used for [10]min TURN ON BACKLIGHT if button pressed, etc. Start.Settings.system.backlight.BRIGHTNESS . . . (brightness affects power consumption) Some of these settings need to be different when NOT flying/driving - so need changing frequently. Hope this helps. Are there any other points Bob and I have overlooked? Cheers, Jim Kelly |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP | vvcd | Rotorcraft | 0 | September 22nd 04 08:17 PM |
| x-43 Flight | Garrison Hilliard | Military Aviation | 0 | March 26th 04 01:42 PM |
| 100 years of flight - Special coverage by The Cincinnati Enquirer | Garrison Hilliard | Military Aviation | 1 | March 14th 04 03:42 PM |
| PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 01:14 PM |
