The remains of the Carat Motorglider have been placed
in its trailer and are awaiting the investigation by the NTSB at Minden Airport. I spoke to Larry Mansberger about the possibility of a wing failure similar to those experienced by the Duo Discus and the Discus CS a year or so ago. For those of you unfamiliar to the Schempp-Hirth problems I will give you a little history. The wings were manufactured in Eastern Europe and because of quality assurance problems it was discovered that, after a couple of wings disintegrated in the air, the glue used was too thin and the parts that were expected to be glued together had large voids where there should have been joined. This weakened the wings causing in the air failures. Larry showed me, using a boroscope, such defects in a Duo Discus wing he was inspecting after the LBA and the FAA grounded certain models of the Discus single and dual place gliders. The Carat uses a modified std Discus wing. No problems have ever been reported in the Carat wing. Larry helped transport Alan's Carat back to the airport after the accident and carefully checked to see if there were any similar problems to those seen in the Duo's wings. There were non. Mike More flew a Grob 103 with a student at the same time Alan was in the air. They were also north of the airport. They were flying above 14,000 feet, spoke of moderate turbulence, but more importantly of the closure of layers of cloud below them. Mike said to me that he had to be vigilant of the forming and dissolving cloud layers and position himself so that there was always a blue hole to get himself down in. A less experienced pilot might not have been so aware of the dangers of getting trapped in cloud. Lets get the most out of this tragic accident. Lets learn and in so doing become wiser. The wave can be a monster in more than one sense. It can cause extreme rotor - read turbulence - it can produce extreme lift greater than 1500 ft per minute; how do you get down? You had better have a plan! Cloud layers can form almost instantly - a big blue hole might disappear in seconds. Most of the time wave is enjoyable and reasonably safe, but it can so quickly turn into a monster. When it does look out. Have a plan. Copied below is an initial accident review from the US Carat distributor. Dave Bingham --------------------- Date: Thu, 28 Oct 2004 04:23:53 -0000 Dear Saddened Carat Fans; After a through investigation of the accident by AMS Flight d.o.o., Schempp-Hirth GmbH, Mansberger Aviation and AMS-USA it has been determined that inflight structural failure was not the cause of this accident. On this flight, N418AP, went through an in flight envelope of aproximately, a 15-20 positive G load, and an airspeed of 200+ knots. The likely cause of the accident was a combination of high altitude hypoxia and flying in IMC conditions, which lead to loss of control of the aircraft and it exceeding its design limitations. Oliver Dyer-Bennet AMS-USA |
Were the G numbers and speed found on a flight recorder?
Brian |
Unfortunately Alan did not have a flight recorder.
Dave Brian Iten wrote in message ... Were the G numbers and speed found on a flight recorder? Brian |
At 20:06 29 October 2004, Nafod40 wrote:
Todd Pattist wrote: I had my doubts about using this technique in a slippery glass ship, but I found it to work fairly well, except I use trim back. I have tried this in my Ventus C, once for a total of 10,000' descent, once for 8,000' descent and once for 5,000' (a real waste of altitude, but each was after a wave flight and I was cold). I found that trim back (thermal setting), flaps at -1 (one notch negative - zero and positive flap settings are limited to 80 knots), wheel out and brakes full open worked best. The 10,000' and 5,000' descents were entered level, became a gentle stable turn and remained fairly stable with some phugoid speed oscillation. The turn would sometimes steepen, sometimes shallow or even reverse. When flying in the military, we used to play games and see what we could fail and still fly the plane IMC. I found I could get by with a turn needle, an AOA gauge, a balance ball (or a balance string) and an ASI. The turn needle coupled with the balance string could be used to maintain wings level. Basically use rudder to keep the turn needle centered, and wing to balance flight. The AOA with the airspeed, oddly enough, worked fine for pitch once you got used to it. The AOA responded instantly to pitch inputs, and let you immediately correct them. From a controls standpoint, it gave great derivative information. The airspeed then let you dampen the slow pitch deviations. It was a great integrator. One could replicate an AOA indicator by a string on the side of a cockpit. I could fly a PAR to mins using this technique. Tiring, but doable. So the turn needle is the only thing seriously lacking in a glider. Speak for yourself, I have a turn and slip AND a horizon in my panel and consider them minimum equipment for wave soaring on cloudy days in a slippery glider. |
kernel.dll has caused a general protection fault, please
wait while your instrument panel reboots, would you like to send a fault report to Microsoft? Spinning gyro's might be passe but they don't rely on Bill Gates flaky operating systems. I personally don't trust Billy Boy for final glide or navigation (I have two backups for both) never mind saving my neck descending through cloud. At 21:12 29 October 2004, Bill Daniels wrote: 'nafod40' wrote in message ... Bill Daniels wrote: You can fly with just the turn needle and ASI if you learn to control airspeed trends. I'm being flip here a little bit, but I wonder if you couldn't manufacture an 'emergency gyro' that would be spun up like a top by battery, and would spin for enough minutes to hold an attitude. Clamp it onto the dash and start descending. Spinning gyros are passe. Look at: http://www.pcflightsystems.com/egyro.html or: http://www.icarusinstruments.com/microEFIS.html Bill Daniels |
At 15:54 02 November 2004, Stefan wrote:
There is no such thing as 'trapped' by a layer if you act as you should. Sounds like you haven't done much cross country wave flying. If you do enough cross country wave flying you will, sooner of later, get trapped above cloud. Sometimes you are forced to fly part of your task above 8/8 where we fly. Other times the cloud can close quickly and you get caught. We were trained to position approx 1km downwind of a known landing point using GPS (depending on terrain), set the glider up in a stable position and open the airbrakes at 70kts. Not desirable by any stretch of the imagination but sometimes a required technique. |
Ben Flewett wrote:
If you do enough cross country wave flying you will, sooner of later, get trapped above cloud. I do not agree. Know the weather. Allow yourself enough time to build experience. Keep sharp on the development of the weather. Never, never, never fly above a lenticularis. Keep your föhn gap in sight. Be sure your glider can penetrate against the wind. And if in doubt, don't go. But you knew all this before. If you insist that getting trapped by cloud can't be avoided, then, by all means, install at least a needle and get some training on it. You simply can't control a slippery glass glider in cloud without a gyro. Stefan |
![]() "Ben Flewett" wrote in message ... At 15:54 02 November 2004, Stefan wrote: There is no such thing as 'trapped' by a layer if you act as you should. Sounds like you haven't done much cross country wave flying. If you do enough cross country wave flying you will, sooner of later, get trapped above cloud. Sometimes you are forced to fly part of your task above 8/8 where we fly. Other times the cloud can close quickly and you get caught. We were trained to position approx 1km downwind of a known landing point using GPS (depending on terrain), set the glider up in a stable position and open the airbrakes at 70kts. Not desirable by any stretch of the imagination but sometimes a required technique. I have to agree with Ben. I got caught above a cloud deck in wave once. It wasn't that the deck 'moved in" below me, it just formed very quickly. One moment there was a scattered lenticular deck at 22,000 and the next there was a solid deck below me at 12,000. There was never an option to escape VFR. Having neither radio nor gyros, I was in no hurry to try a descent either by benign spiral or in a stable spin so I just sat there and maintained my position in the wave. The cloud tops marked the wave nicely. After about an hour, the patch of moisture moved off downwind and a foehn gap appeared in the cloud deck below. Descending through the gap meant fighting my way down through the strong lift with full spoilers in a dive. It took almost an hour. I'm a believer. Sooner or later, you'll need the ability to make a blind descent. Bill Daniels |
Ben Flewett wrote:
At 15:54 02 November 2004, Stefan wrote: There is no such thing as 'trapped' by a layer if you act as you should. Sounds like you haven't done much cross country wave flying. If you do enough cross country wave flying you will, sooner of later, get trapped above cloud. Sometimes you are forced to fly part of your task above 8/8 where we fly. Other times the cloud can close quickly and you get caught. We were trained to position approx 1km downwind of a known landing point using GPS (depending on terrain), set the glider up in a stable position and open the airbrakes at 70kts. Not desirable by any stretch of the imagination but sometimes a required technique. Why downwind? |
Shawn wrote in message ...
Ben Flewett wrote: At 15:54 02 November 2004, Stefan wrote: There is no such thing as 'trapped' by a layer if you act as you should. Sounds like you haven't done much cross country wave flying. If you do enough cross country wave flying you will, sooner of later, get trapped above cloud. Sometimes you are forced to fly part of your task above 8/8 where we fly. Other times the cloud can close quickly and you get caught. We were trained to position approx 1km downwind of a known landing point using GPS (depending on terrain), set the glider up in a stable position and open the airbrakes at 70kts. Not desirable by any stretch of the imagination but sometimes a required technique. Why downwind? Am I missing something here? If I were caught above a cloud layer, I would go to into a spin before trying a "benign spiral". A spin is a controlled maneuver where a spiral seems more likely to get out of control. |
Minden Waypoints | Carl Buehler | Soaring | 2 | August 14th 04 06:22 PM |
8th Anniversary : Kiwi Aircraft Images Update | Phillip Treweek | Military Aviation | 0 | August 13th 04 01:45 AM |
Minden In Two Weeks | ADP | Soaring | 3 | August 10th 04 01:51 AM |
Anyone know how to update an old Loran database? | Tom Jackson | Owning | 12 | December 5th 03 06:03 PM |
Anyone know how to update an old Loran database? | Tom Jackson | Piloting | 6 | December 3rd 03 02:15 AM |
