Problem with Grob-103
Old February 7th 19, 11:47 PM posted to rec.aviation.soaring
Elena Malanushenko
Default Problem with Grob-103
Interesting video with the testing of plane
https://www.youtube.com/watch?v=vel-qoc0UY4
Old February 8th 19, 02:35 AM posted to rec.aviation.soaring
Bob Whelan[_3_]
Hmmm...it's been a while since I've looked at a spring-trimmed G-103
specifically, but - assuming no obvious W&B issues muddying the picture -
things I'd look hard at upon noting (in the same flight?!?): a) insufficient
forward trim effect at tow speeds, and b) repeatable step-function-uncommanded
forward trim/stick-inputs at some higher/arbitrary speed would be:
1) "something 'fixed-in-place' not right" in the trim system;
2) "something capable of slipping under tension" in the trim system;
3) the entire primary pitch control system.
Of course, my version of Occam's razor supposes these possibilities have
"long-ago been considered/inspected" (based upon calendar-info in the film
snippet), but inferring as to what - if any - actions have occurred, based
upon the commentary, raises more questions in my mind than it answers.
Me not "doing" YouTube Q&A, my curiosity cat be definitely interested in what
ultimately proves to be the culprit...
Bob W.
This email has been checked for viruses by AVG.
https://www.avg.com
Old February 8th 19, 02:43 AM posted to rec.aviation.soaring
Scott Williams
Bob W.
https://www.avg.com
Spring trimmer? our Club grob G 103 twin II has an aerodynamic elevator trim tab.
Scott
Old February 8th 19, 04:17 AM posted to rec.aviation.soaring
Elena Malanushenko
Thank you, Bob Whelan !
Old February 11th 19, 12:57 AM posted to rec.aviation.soaring
Scott Calvert[_4_]
I would check for loose seals.
Old February 11th 19, 06:23 AM posted to rec.aviation.soaring
Eric Munk
I have replaced loose seals after experiencing similar in flying one.
Problem never returned.
Old February 11th 19, 01:47 PM posted to rec.aviation.soaring
Scott has a good point.
I would suggest a few things.
1) Determine if weight and balance is as it is expected to be. A quick check is to level the glider and get the tail weight. Compare this to weight shown on the wt & balance being used. If different, investigate. Sensitive pitch on tow, especially nose up tendency, and pitch sensitivity in glide is consistent with an aft CG condition. Mid range weight in seats should not require full down trim.
2) Carefully look at all seals on the elevator, external and internal. A shifting seal at a particular air pressure, could easily cause pitch change.
3)If the elevator is trimmed with a tab verify smooth progressive function with no slop or binding.
Good luck
UH
Old February 11th 19, 01:38 PM posted to rec.aviation.soaring
Between the speedup and pitchdown, there's a growling noise.
Don't think it was the pilot.
I've heard vibrating mylars, but this pitch is too low.
Maybe a bi-stable one?
I wonder if you could get enough 75Knot air with a garden blower in the shop.
Old February 11th 19, 06:02 PM posted to rec.aviation.soaring
Early Twin-2’s had aerodynamic elevator trim (trim tab), but later models went with spring trim. The jumping back reminds me of a slipping trim bar where the desired trim position doesn’t hold its setting. Recommend you pull the front seat and see if there is any slipping of the desired trim position. Can’t remember exactly what the trim setup is on the Twin Two, but a look under the seat will reveal any malfunction.
Hope this helps,
JJ
Grob SB's Alan Garside Soaring 14 January 19th 19 02:26 PM
Grob Value? Charlie Papa[_2_] Soaring 5 March 19th 12 06:27 PM
Grob Value? Frank Whiteley Soaring 0 February 7th 12 04:43 AM
Grob Bob O'Rilley Soaring 3 April 29th 05 07:22 PM
GROB 102 Vorsanger1 Soaring 4 July 11th 03 11:34 PM
