We all talk about "oh poop planning" usually relating to near theground....another view...
Old February 21st 19, 11:22 PM posted to rec.aviation.soaring
Default We all talk about "oh poop planning" usually relating to near theground....another view...
Keep in mind, among the worst sailplanes are 20:1 or higher.
Best jets.....I have no clue, guess high single numbers?
What about a current fighter jet?!?!
Here is a nice discussion from AOPA (I am a glider pilot with some power time, but mostly joined for the lobbyist's for GA and the CFI-G insurance), but this just popped up on a newsletter....
https://pilot-protection-services.ao...t-650-part-two
Old February 22nd 19, 04:50 PM posted to rec.aviation.soaring
Clay[_5_]
As someone about to transition to a self-launcher, this is very timely. But great stuff for anyone. Thanks Charlie
Old February 22nd 19, 05:09 PM posted to rec.aviation.soaring
NP...hope it helps all of us.
Old February 22nd 19, 05:36 PM posted to rec.aviation.soaring
Dan Marotta
That was great reading, but not really useful for self-launch gliders.Â*
In multi-engined aircraft, following an engine failure, the pilot has
the option of returning to land, ejecting (if so equipped), continuing
to a maintenance facility (if the aircraft has the performance), or
motoring along to the site of the crash.Â* I don't know of any production
self-launching glider with more than one engine so an engine failure is
simply the same as a failure of a tow, except for the drag of the
engine/prop (except in a Stemme).
If you're new to self launch gliders, consider this advice:Â* Plan and be
prepared to have an engine failure as you would plan for an air or
ground launch failure, only consider the added altitude required to
return to the runway due to increased drag over a pure glider.Â* You
likely won't be able to return to the runway with an engine hanging up
in the air stream.
Dan, 5J
Old February 22nd 19, 07:12 PM posted to rec.aviation.soaring
waremark
Anyone transitioning to a self launcher should study Eric Greenwells excellent guide. https://sites.google.com/site/motorg...ad-the-guide-1
Old February 22nd 19, 09:25 PM posted to rec.aviation.soaring
Dave Walsh[_2_]
gliders.Â*
pilot has
continuing
performance), or
any production
engine failure is
of the
Plan and be
air or
required to
glider.Â* You
hanging up
in the air stream.
very timely.
Dan, 5J
Stemme aside I am pretty sure all manufactures quote the
glide angle with the engine out (erected) and a wind-milling
prop. If I recall correctly a DG400 (17m) was about 12:1, a
DG808 (18m) about 14:1, the Antares 20E is about 30:1 so
depending on where the engine fails a return to the airfield
may well be feasible. The important thing is to have a mind
set during the launch that assumes the engine WILL fail,
because eventually these engines will fail.
Dave Walsh
Old February 23rd 19, 12:46 AM posted to rec.aviation.soaring
Dan Marotta
Yes, even the Stemme's engine (a Rotax 914 turbocharged 4-stroke engine)
can fail but, if it does, the glide ratio is...Â* 50:1.Â* Of course, if a
Stemme catches fire, it's often fatal.Â* My plan is to jump (altitude
permitting) - simple as that.
gliders.Â
pilot has
continuing
performance), or
motoring along to the site of the crash.ÂÂ* I don't know of
any production
engine failure is
of the
Plan and be
air or
required to
glider.ÂÂ* You
hanging up
in the air stream.
very timely.
Dan, 5J
Dave Walsh
Dan, 5J
Old February 22nd 19, 09:59 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Dan Marotta wrote on 2/22/2019 9:36 AM:
If you're new to self launch gliders, consider this advice:* Plan and be prepared
to have an engine failure as you would plan for an air or ground launch failure,
only consider the added altitude required to return to the runway due to increased
drag over a pure glider.* You likely won't be able to return to the runway with an
engine hanging up in the air stream.
Good advice, but the drag of the extended mast varies significantly between
gliders. My ASH 26E losing power is about like Blanik with a rope break at the
same altitude; ie, 200' AGL is "normally" enough. It's something you can try at
altitude safely, and review your logger file later (set it to 1/sec logging rate).
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
Old February 24th 19, 12:05 PM posted to rec.aviation.soaring
Dave Walsh[_2_]
Pylon self-launchers fall into 2 groups:
(i) DG400/PIK20E/DG800A/DG600M types where both the engine
and the prop and mast are sticking out into the airstream.
(ii) ASH26E/DG800B/DG808C types where just the prop and mast
If I recall correctly the DG400 certification required that DG
demonstrate an engine stopped and erected plus full air brake
landing. W Dirks (the D in DG) performed this but suffered some
minor back injury. (Well this is what I was told 30 years ago when
I first flew a DG400, I can't vouch for its accuracy).
So the advice was always to have NO air brake extended during
the round out: the sink rate with extended stopped engine is
pretty substantial. The other advice was to very aware of
turbulence from the stopped engine masking elevator feel.
Dave Walsh
Old February 24th 19, 04:49 PM posted to rec.aviation.soaring
JS[_5_]
Dave Walsh
While the normsl stall characteristics of the ASH26E are benign, stalling it with the prop up and not turning can be less predictable, as Dave suggests.
I'd suspect this to be true with any "Klappi".
Dayton Museum [260/270] - "DSC_4054 Mezzanine view.jpg" yEnc (1/1) Gramps[_2_] Aviation Photos 0 May 8th 17 01:01 AM
Anyone planning to talk about Condor at U.S. SSA convention? Frank[_12_] Soaring 1 November 17th 09 12:48 PM
Talk: “GA Planning Battles . . .” on April 17th, London, UK Chris Nicholas[_2_] Soaring 0 March 26th 09 01:00 PM
Apollo 13 pix, batch one - "Apllo 13 view of earth AS13-60-8591.jpg" yEnc (1/1) [68K] hielan' laddie Aviation Photos 0 September 9th 08 04:42 PM
Friday 072707 in Oshkosh Pt 1 - the Raptor [12/30] - "F22 another top view.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 29th 07 06:37 AM
