I'm curious to know what sorts of experiences others have had in
getting parts and service for their LS gliders since DG has assumed ownership. I am trying to buy an LS-3-17 from a fellow pilot at our field. The airframe has 3000 hours, and therefore requires a major inspection in accordance with procedures specified by LS. Among the squawks identefied were brass spar bushings being out of tolerance, and worn needle bearings in the aileron and flap hinges. The needle bearings have been discontinued and DG recommends replacing them with nylon ones used on LS-8s. DG has charged the inspector up to 100 euros per question to clarify the inspection procedure or to FAX needed diagrams (the running total is about 300 to 400 euros). The inspector is unable to get DG to respond to his parts order, but was able to get parts for another LS-3 in September. He has enlisted the help of the US distributor for DG in the U.S. to get the bushings and bearings but the distributor has been met with no response as well. Even if the bushings are not in stock, the nylon bushings should be available from the LS-8s. Has anyone else been delayed in getting parts or a response from DG for their LS gliders? I have also not heard of other glider mfg's charging money to answer questions. This does not seem to be a customer friendly practice, especially in light of DG's promises to stand behind the LS line. |
Looks like it might not be just you.
I have a LS1F ,currently with 6000hrs, (max certified life) i have been trying to find out if there will be a extension up to 12000hrs along with other LS1 models, I have contacted DG on several occasions for find out timescale, but never had a answer... Hopefully discussion on here might spur them into action At 19:48 11 November 2004, James wrote: I'm curious to know what sorts of experiences others have had in getting parts and service for their LS gliders since DG has assumed ownership. I am trying to buy an LS-3-17 from a fellow pilot at our field. The airframe has 3000 hours, and therefore requires a major inspection in accordance with procedures specified by LS. Among the squawks identefied were brass spar bushings being out of tolerance, and worn needle bearings in the aileron and flap hinges. The needle bearings have been discontinued and DG recommends replacing them with nylon ones used on LS-8s. DG has charged the inspector up to 100 euros per question to clarify the inspection procedure or to FAX needed diagrams (the running total is about 300 to 400 euros). The inspector is unable to get DG to respond to his parts order, but was able to get parts for another LS-3 in September. He has enlisted the help of the US distributor for DG in the U.S. to get the bushings and bearings but the distributor has been met with no response as well. Even if the bushings are not in stock, the nylon bushings should be available from the LS-8s. Has anyone else been delayed in getting parts or a response from DG for their LS gliders? I have also not heard of other glider mfg's charging money to answer questions. This does not seem to be a customer friendly practice, especially in light of DG's promises to stand behind the LS line. |
I have had great service from DG!! I bought a LS-6a a year ago and
hade many questions about my glider. I spent contless hours on the internet or researching thing and when I didn't have an answer I contacted DG / Gunter Schapka and he had answers back to me quickly. I have been very happy with my experiences with DG. Sincerely, Jerz Rossignol wrote in message ... Looks like it might not be just you. I have a LS1F ,currently with 6000hrs, (max certified life) i have been trying to find out if there will be a extension up to 12000hrs along with other LS1 models, I have contacted DG on several occasions for find out timescale, but never had a answer... Hopefully discussion on here might spur them into action At 19:48 11 November 2004, James wrote: I'm curious to know what sorts of experiences others have had in getting parts and service for their LS gliders since DG has assumed ownership. I am trying to buy an LS-3-17 from a fellow pilot at our field. The airframe has 3000 hours, and therefore requires a major inspection in accordance with procedures specified by LS. Among the squawks identefied were brass spar bushings being out of tolerance, and worn needle bearings in the aileron and flap hinges. The needle bearings have been discontinued and DG recommends replacing them with nylon ones used on LS-8s. DG has charged the inspector up to 100 euros per question to clarify the inspection procedure or to FAX needed diagrams (the running total is about 300 to 400 euros). The inspector is unable to get DG to respond to his parts order, but was able to get parts for another LS-3 in September. He has enlisted the help of the US distributor for DG in the U.S. to get the bushings and bearings but the distributor has been met with no response as well. Even if the bushings are not in stock, the nylon bushings should be available from the LS-8s. Has anyone else been delayed in getting parts or a response from DG for their LS gliders? I have also not heard of other glider mfg's charging money to answer questions. This does not seem to be a customer friendly practice, especially in light of DG's promises to stand behind the LS line. |
I asked DG, followed by Solaire Canada a question several weeks ago. I
still have no answer. Frank Whiteley "Jerz Rossignol" wrote in message om... I have had great service from DG!! I bought a LS-6a a year ago and hade many questions about my glider. I spent contless hours on the internet or researching thing and when I didn't have an answer I contacted DG / Gunter Schapka and he had answers back to me quickly. I have been very happy with my experiences with DG. Sincerely, Jerz Rossignol wrote in message ... Looks like it might not be just you. I have a LS1F ,currently with 6000hrs, (max certified life) i have been trying to find out if there will be a extension up to 12000hrs along with other LS1 models, I have contacted DG on several occasions for find out timescale, but never had a answer... Hopefully discussion on here might spur them into action At 19:48 11 November 2004, James wrote: I'm curious to know what sorts of experiences others have had in getting parts and service for their LS gliders since DG has assumed ownership. I am trying to buy an LS-3-17 from a fellow pilot at our field. The airframe has 3000 hours, and therefore requires a major inspection in accordance with procedures specified by LS. Among the squawks identefied were brass spar bushings being out of tolerance, and worn needle bearings in the aileron and flap hinges. The needle bearings have been discontinued and DG recommends replacing them with nylon ones used on LS-8s. DG has charged the inspector up to 100 euros per question to clarify the inspection procedure or to FAX needed diagrams (the running total is about 300 to 400 euros). The inspector is unable to get DG to respond to his parts order, but was able to get parts for another LS-3 in September. He has enlisted the help of the US distributor for DG in the U.S. to get the bushings and bearings but the distributor has been met with no response as well. Even if the bushings are not in stock, the nylon bushings should be available from the LS-8s. Has anyone else been delayed in getting parts or a response from DG for their LS gliders? I have also not heard of other glider mfg's charging money to answer questions. This does not seem to be a customer friendly practice, especially in light of DG's promises to stand behind the LS line. |
Użytkownik "Sleigh" napisał w wiadomości ... Looks like it might not be just you. I have a LS1F ,currently with 6000hrs, (max certified life) i have been trying to find out if there will be a extension up to 12000hrs along with other LS1 models, I have contacted DG on several occasions for find out timescale, but never had a answer... Is this what we call a perfect customer service? Germans are said to be world's master... ![]() Regards from Poland, -- Janusz Kesik Poland to reply put my name.surname[at]gazeta.pl ------------------------------------- See Wroclaw (Breslau) in photography, The XIX Century, the Festung Breslau, and photos taken today. http://www.wroclaw.dolny.slask.pl |
Janusz Kesik wrote:
Is this what we call a perfect customer service? Germans are said to be world's master... ![]() Regards from Poland, Janusz, don't always make fun of our German friends. By the way, congratulations for Poland who has saved us Europeans from stupid software patents. -- Michel TALON |
Użytkownik "Michel Talon" napisał w wiadomości ... Janusz, don't always make fun of our German friends. By the way, congratulations for Poland who has saved us Europeans from stupid software patents. Michael, I am not making fun at Germans, I am laughing at these people who always laugh at "Polnische Wirtschaft" and mumble somethins about "German artisans". Well we see that nobody's perfect. ![]() Regards, -- Janusz Kesik Poland to reply put my name.surname[at]gazeta.pl ------------------------------------- See Wroclaw (Breslau) in photography, The XIX Century, the Festung Breslau, and photos taken today. http://www.wroclaw.dolny.slask.pl |
This story is not true.
We never have charged anything for answering any question. True is that a procedure for life extension is not for free, because DG never had the chance to sell this old glider. The extension of life is a service of the manufacturer of the gliders and DG was not the manufacturer. But to be honest: The native manufacturer Rolladen-Schneider did not make anything for the extension of the life of their gliders. Was this better? Now all owners come to us. True is another thing too: Gunter Schapka is very busy with answering for hundreds of enquiries. Rolladen-Schneider simply did not answer to anybody. We do answer (for free!) but it may take a little time. That`s it! Friedel Weber --------------------- James schrieb: I'm curious to know what sorts of experiences others have had in getting parts and service for their LS gliders since DG has assumed ownership. I am trying to buy an LS-3-17 from a fellow pilot at our field. The airframe has 3000 hours, and therefore requires a major inspection in accordance with procedures specified by LS. Among the squawks identefied were brass spar bushings being out of tolerance, and worn needle bearings in the aileron and flap hinges. The needle bearings have been discontinued and DG recommends replacing them with nylon ones used on LS-8s. DG has charged the inspector up to 100 euros per question to clarify the inspection procedure or to FAX needed diagrams (the running total is about 300 to 400 euros). The inspector is unable to get DG to respond to his parts order, but was able to get parts for another LS-3 in September. He has enlisted the help of the US distributor for DG in the U.S. to get the bushings and bearings but the distributor has been met with no response as well. Even if the bushings are not in stock, the nylon bushings should be available from the LS-8s. Has anyone else been delayed in getting parts or a response from DG for their LS gliders? I have also not heard of other glider mfg's charging money to answer questions. This does not seem to be a customer friendly practice, especially in light of DG's promises to stand behind the LS line. |
| Thread Tools | |
| Display Modes | |
| Which Military Service is best? | ArtKramr | Military Aviation | 33 | September 19th 04 05:12 PM |
| Air Force Chief Sounds Off as Service Birthday Approaches | Otis Willie | Military Aviation | 0 | September 18th 04 04:54 AM |
| bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 05:26 PM |
| Service Bulletins, Service Letters, Service Spares Letters | O. Sami Saydjari | Owning | 5 | December 26th 03 06:36 AM |
| Underwater Gliders | Burt Compton | Soaring | 6 | November 25th 03 05:43 AM |
