Replacing a multi-probe socket
Old March 9th 19, 03:48 AM posted to rec.aviation.soaring
JS[_5_]
Default Replacing a multi-probe socket
Is there a 3-circuit socket which is more easily serviced when the total pressure (pitot) O-ring fails?
Old March 9th 19, 11:50 AM posted to rec.aviation.soaring
Andrzej Kobus
Jim, it is possible to replace the last o-ring (4mm) on a multi-probe. I did it once. I must admit a lot of bad words came out of my mouth over a period of half a day, but it was done. You would need to manufacture your own tooling to do this and have incredible amount of patience, but I am certain you will succeed.
Old March 11th 19, 12:41 AM posted to rec.aviation.soaring
Darryl Ramm
Yep done the outer, dental pick tool, and a Delrin rod to seat the new O-ring in place. Done outside on the ramp at an airport, and yes lots of swearing...
Old March 11th 19, 01:11 AM posted to rec.aviation.soaring
JS[_5_]
There's a kit labeled "TE Probe" at home. Came with one of the 27s.
Also a spare UN socket which by now could need new O-rings.
The kit is like what you describe. Not thrilled about using it without better currency at swearing in German. Perhaps time to practice on the spare one.
For a replacement... Is there a difference in serviceability between type UN, UNG and SUN sockets?
This is for a friend's DG.
There's always the possibility that any leak is the probe itself. I've seen two triple probes and a standard TE probe that didn't seal, when other probes used in the same socket did.
Thanks,
Old March 11th 19, 04:56 PM posted to rec.aviation.soaring
Dan Marotta
Not being a mechanical engineer, could anyone enlighten me as to why the
o-rings are installed internally in the socket rather than externally on
the probe?Â* In either case the o-rings are getting rubbed each
installation/removal cycle and it seems light lubrication, like the skin
oil from one's nose, would work nicely. That's how I lube the probe on
my Stemme.
And, BTW, the o-rings would be oh so much easier to replace...
Thanks,
Dan, 5J
Old March 11th 19, 05:15 PM posted to rec.aviation.soaring
my Stemme.
In ESA probes the UN sockets (eg for triple probes) have the O-rings in the socket and the ST sockets (eg for TE/Static double probes) have the O-rings on the aluminium probe fitting but those ones are more prone to fractures of the fitting on older probes - at the O-ring groove of course.
Old March 12th 19, 01:52 AM posted to rec.aviation.soaring
Roy B.
Dan:
For some reason the O-Rings on my South African glider get really dry & stiff. We use a very light coat of silicone "plumbers grease" on the probe about twice a year to fix that (petroleum based grease attacks the O-Ring). My US glider in Massachusetts doesn't have the problem.
ROY
Old March 12th 19, 03:55 PM posted to rec.aviation.soaring
Dan Marotta
Humidity difference?
On 3/11/2019 7:52 PM, Roy B. wrote:
Dan:
ROY
Dan, 5J
Old March 12th 19, 09:13 PM posted to rec.aviation.soaring
Tango Eight
On Monday, March 11, 2019 at 9:52:53 PM UTC-4, Roy B. wrote:
Dan:
ROY
If everyone used this, we'd have fewer problems: https://www.amazon.com/Dow-Corning-V.../dp/B001UHMNW0
What I use on the o-rings I rely on in my day job, as well as my triple probe socket.
T8
Old March 13th 19, 03:00 AM posted to rec.aviation.soaring
Yup,
Great stuff. Probably one of the most important things that I learned about in college.
Also works great on water ballast valves. Has not melted on the ground at AirSailing or frozen in wave at 24,800 ft.
P9
Proper Way to Insert Multi-Probe Dan Marotta Soaring 18 February 19th 18 01:31 AM
Prandtl multi probe receptacle used for TE only? Matt Herron Jr. Soaring 12 February 15th 18 08:32 PM
castellated socket Stuart & Kathryn Fields Home Built 1 June 3rd 08 12:37 PM
Replacing innertubes without replacing tires? Ben Jackson Owning 28 November 6th 06 04:54 PM
Multi - probe KP Soaring 1 March 7th 05 06:03 PM
