Longest wearing 5.50 tires
Old August 13th 04, 10:32 AM
Doug
Default Longest wearing 5.50 tires
I need some 5.50 tires and I want Loooong wearing, as the labor is
high. Don't care much about price of the tire. Any suggestions?
Old August 13th 04, 01:45 PM
Al Marzo
Michelin
On 13 Aug 2004 02:32:31 -0700, (Doug)
Old August 13th 04, 02:04 PM
rip
You might contact Desser Tire about retreads. A retread generally has
thicker treads, and can use a harder rubber compound. Cheaper, too.
Old September 8th 04, 04:19 AM
Bruce A. Frank
BUT, though I like retreads the sidewalls have already received a
lifetimes worth of UV exposure. On planes that sit a lot the natural
sidewall checking gets worse and worse and can eventually crack through
the cord. If you fly a lot and go through a pair of tires in a year it
can be a good investment. If the plane wears tires out every 5 years the
retread might not be a good investment.
Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL
Homebuilt Aircraft Newsletter"
| Publishing interesting material|
| on all aspects of alternative |
| engines and homebuilt aircraft.|
Old August 13th 04, 03:45 PM
Mike Rapoport
I have found the longest wearing tires to be Desser's retreads. They are
the cheapest too.
Mike
MU-2
Helio Courier
"Doug" wrote in message
om...
Old August 15th 04, 02:17 PM
Lou Parker
"Mike Rapoport" wrote in message hlink.net...
the cheapest too.
Mike
MU-2
Helio Courier
om...
How long is long?
Old August 15th 04, 05:11 PM
Mike Rapoport
YMMV but longer than anything else.
Mike
MU-2
"Lou Parker" wrote in message
om...
hlink.net...
are
the cheapest too.
Mike
MU-2
Helio Courier
om...
How long is long?
Old August 15th 04, 07:01 PM
Jim Weir
A. Agreed, and if you can have somebody save some parTICularly nice casings,
they will retread YOUR casing rather than a random casing. I'm waiting until
the local flight school goes through one more Michelin and I'll have a full set
of Michelin casings to send down for retread. Then when I get them back, the
Goodyear Flight Customs that I've got on there now will go down.
B. Watch CAREFULLY if you use them on a retractible gear aircraft. The rubber
is just enough thicker that them may jam in the well if it is a particularly
tight fit.
"Mike Rapoport"
-YMMV but longer than anything else.
http://www.rst-engr.com
Time to change the air in your tires Rich S. Home Built 18 March 22nd 04 06:47 PM
