Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aerobatics
RV-6 Snap Rolls
Old February 2nd 05, 11:44 PM
Ted Timmons
Default RV-6 Snap Rolls
Van wrote an article in which he states "RV's are not well
suited for [snap rolls] because high G forces are needed to produce a
brisk snap roll."
When I do snap rolls in my Aerobat (perhaps that's an oxymoron) I do an
accelerated stall at 75kts which is well below my Va of 105 kts so there
is no possibility of over stressing the aircraft.
If the Va for the RV-6 is 120kts and I do an accelerated stall at 80
kts, the max load on the aircraft should only be 2.7 G's. Obviously
this is well below the 6 G limit so what am I missing?
Old February 2nd 05, 11:48 PM
ShawnD2112
You don't really put much of a g load on the airplane in that sense but you
put some strong bending moments on the airframe which wouldn't show up on
your g-meter. Snap rolls are easily controlled but could be classed as a
violent maneuver. One Pitts pilot I talked to complained that his airplane
seemed to take a semi-permanent "set" after snap rolls, assuming a slight
left roll after left snaps and a slight right roll after right snaps. I
also noticed that the paint on my Pitts started to crack on the tail only
after I started learning how to do snaps. If the fuselage isn't stressed
for those bending and torsional loads, it probably isn't a good idea to snap
it. Which is a shame because snaps are a blast!
Shawn
"Ted Timmons" wrote in message
brisk snap roll."
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 January 1st 05 08:29 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 May 1st 04 09:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 April 1st 04 09:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 March 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 December 1st 03 07:27 AM
