Motorgliders and TE Probes
Old November 23rd 04, 05:34 PM
Paul Remde
Default Motorgliders and TE Probes
Hi,
I have a question for motorglider owners. I sell variometers and TE probes
but I'm still learning. A customer is building a Europa motorglider and he
is wondering if he can mount a TE probe on the fin and connect it to the
variometer, or will the propwash cause problems. Is it necessary to use
some sort of pneumatic switch to switch between TE and static input for the
variometer?
His pitot and static ports are on a boom that is mounted to the wing.
Thank you,
Paul Remde
Cumulus Soaring, Inc.
Old November 23rd 04, 05:38 PM
Stefan
The vario will not be too accurate in the propwash, but who needs an
accurate vario when the prop is turning?
variometer?
Not necessary, but recommended.
Stefan
Old November 23rd 04, 07:15 PM
Paul Remde
Hi,
I received a few very nice e-mails from reputable sources recommending the
use of a pneumatic switch to switch between TE and Static input for a
motorglider. That is good information. This newsgroup is fantastic!
It was suggested that the switch could be made to be automatic. That sounds
great. It is my understanding that even very small leaks can cause large
inaccuracies in TE functionality - so we must be careful about that of
course. Does anyone have any recommendations for manual or automatic
pneumatic switches? It would be great to get feedback from someone who has
done this already.
Thank you,
Paul Remde
"Paul Remde" wrote in message
news:NwKod.141170$R05.69144@attbi_s53...
Hi,
probes
he
variometer?
Thank you,
Paul Remde
Old November 23rd 04, 07:34 PM
Raphael Warshaw
Paul:
I got a nice manual pneumatic switch for use in my oxygen system from
Mountain High a few years ago. You might check with them.
Ray Warshaw
news:f%Lod.141383$R05.121337@attbi_s53...
Hi,
sounds
has
done this already.
Thank you,
Paul Remde
Hi,
probes
he
variometer?
Thank you,
Paul Remde
Old November 23rd 04, 10:49 PM
Tim Mara
Clippard Industries in Cincinnati Ohio makes several types of Pneumatic
switches.....
these were commonly used years ago back when sailplane pilots used to have
to make their own and a few variometer manufacturers like Richard Ball made
alternative Pneumatic inputs for Netto's and Speed to Fly variometers from
normal TE variometers
tim
Hi,
sounds
has
done this already.
Thank you,
Paul Remde
Hi,
probes
he
variometer?
Thank you,
Paul Remde
Old November 23rd 04, 10:31 PM
John Giddy
switches.....
tim
Hi,
sounds
has
done this already.
Thank you,
Paul Remde
Hi,
probes
he
variometer?
Thank you,
Paul Remde
I mounted a vertical TE Probe on the top of the fin on our SF25C FALKE
motorglider, connected to a dedicated vario (Borgelt B40). The
aircraft already had a Winter vario connected directly to the static
ports which acts more like a VSI.
The TE probe seems to work very well. The sensing holes near the tip
of the probe would be (from memory) about 10 inces above the top of
the fin.
Regarding switches to change from static to TE, many GA aircraft use
such switches to give an alternative static source for the instruments
in case the primary static ports become blocked. Maybe one of the
aircraft supply houses would have them.
Cheers, John G.
Old November 25th 04, 05:30 AM
Bob Gibbons
I use a Clippard MJTV-5 pneumatic valve to switch out the TE probe on
my Ventus cT. This is a 5 port, 4 way valve. My notes from the install
indicate you connect the input to port 1, and the ouput is toggled
between ports 2 and 4, depending on the lever position. The exhaust
ports vent the non-operational port to ambient (or whatever you
connect to these ports). Cost is approx. $15 US.
For details, see,
http://www.clippard.com/store/displa...asp?sku=MJTV-5
For additonal info on pneumatic valves, see,
http://www.clippard.com/downloads/ge...Pneumatics.pdf
Bob
On Tue, 23 Nov 2004 19:15:23 GMT, "Paul Remde" wrote:
Hi,
done this already.
Thank you,
Paul Remde
Hi,
probes
he
variometer?
Thank you,
Paul Remde
Old November 23rd 04, 07:19 PM
Steve Hill
I think most of the newer variometer systems can electronically calculate
total energy, without the need for any TE probe...I have tried this and
while I haven't met with great success in comparison to using an actual TE
probe on my DG-400, I would speculate that the Europa is not going to be
high enough performing to know the difference in the very minor differences
between a probe and what the vario system will electronically compensate. I
will say that when I tried the electronic setup in my DG, there was a gust
filter the previous owner had installed, which I didn't know about until
later...after removing that filter, my TE probe was much more accurate, but
my guess is that electronically I could have compensated the system fairly
accurately.
Steve.
Old November 23rd 04, 07:48 PM
Eric Greenwell
Paul Remde wrote:
Hi,
The reading will bounce around, but usable except when trying to center
weak lift while under power.
variometer?
It would likely help.
Since he is building it, I suggest he consider a TE tube on the wing,
clear of the prop wash. That should be easy, since he is already doing
that with the pitot and static. Or, use a vario with electronic TE and
just use the pitot/static.
Eric Greenwell
Washington State
USA
Old November 23rd 04, 10:05 PM
Brian Case
My Guess on the Europa is that with the front mounted Propeller and
the rather High Vertical Tail, He could just mount it has High as
possible on the Vertical fin and have little problem with the TE Prob.
I suspect that most of the prop wash would miss the TE prob anyway.
Brian
Lambada vs Sinus motorgliders Andre van Niekekerk Soaring 2 June 9th 04 11:28 AM
Motorgliders (long) JJ Sinclair Soaring 98 October 9th 03 10:11 PM
Motorgliders (long) M B Soaring 1 September 23rd 03 09:15 PM
Latest Newsletter Pipistrel Motorgliders Michael Coates Home Built 18 September 19th 03 01:25 AM
Latest Newsletter Pipistrel Motorgliders Michael Coates Soaring 20 September 19th 03 01:25 AM
