Hi does anyone know the formula for excel so it will add the minutes after
the decimal and convert them to hours. Need to check my log book times and make a database off information types flown etc. EG 1.33 1.56 =2.89 Needs to say 60 mins is one hour so 1.33 1.56 =3.29 ??????????????? =SUM(E1:E23) =IF(A31000,TIMEVALUE(LEFT(A3,1)&":"&RIGHT(A3,2)),T IMEVALUE(LEFT(A3,2)&":"&RIGHT(A3,2))) The formatting of the cells in column B is HH:MM. Thanks Mal |
Mal wrote:
Hi does anyone know the formula for excel so it will add the minutes after the decimal and convert them to hours. Try a newsgroup dedicated to Excel... The fact that this is about adding up your logbook does not make it less off-topic. André |
![]() "André Somers" wrote in message ... Mal wrote: Hi does anyone know the formula for excel so it will add the minutes after the decimal and convert them to hours. Try a newsgroup dedicated to Excel... The fact that this is about adding up your logbook does not make it less off-topic. I respect your opinion André, but I must disagree. I have had exactly this problem for years, and have gotten around it in various (mostly unsatisfactory) ways. I therefore find the subject very interesting and topical. If we were talking about painting gliders would you consider that also something OT to be taken to some paint newsgroup? Vaughn André |
Mal wrote:
Hi does anyone know the formula for excel so it will add the minutes after the decimal and convert them to hours. I found it easier to do hours and minutes in separate Excel columns. Say J is the hours column and K is minutes for each entry. Then we sum up total hours, including decimal fractions of hours, in a hidden L column: L10=L9+J10+K10/60 (note: L9 was the previous total, before this entry) Then the total time in hours and minutes is represented in column M (hours) and N (minutes) respectively: M10=INTEGER(L10) N10=L10*60-M10*60 Cheers CV |
Why not format the cells to a time format thus-
Format - cells - time - 37:30:55 This will give time in hours minutes and seconds that can be added |
![]() "OscarCVox" wrote in message ... Why not format the cells to a time format thus- Format - cells - time - 37:30:55 This will give time in hours minutes and seconds that can be added Sorry excell dont work like that. If you try to enter say 1hr 30min as 1.5 it trys to use it as a date function and displays 12:00:00 and if you try to add times it treats them also as dates such that 12:00:00 + 12:00:00 = 0:00:00. I use two columns and add one mod 60 etc. Peter. |
sorry... excel does work like that... you have to format the time..
and don't use decimal to denote minutes.. 1.30 is not 1hr 30 min, 1.5 is one hour thirty minutes.. or format the cell to TIME, and 1hr 30 minutes is 1:30 BT "Peter Seddon" wrote in message ... "OscarCVox" wrote in message ... Why not format the cells to a time format thus- Format - cells - time - 37:30:55 This will give time in hours minutes and seconds that can be added Sorry excell dont work like that. If you try to enter say 1hr 30min as 1.5 it trys to use it as a date function and displays 12:00:00 and if you try to add times it treats them also as dates such that 12:00:00 + 12:00:00 = 0:00:00. I use two columns and add one mod 60 etc. Peter. |
Format - cells - time - 37:30:55 This will give time in hours minutes and seconds that can be added Sorry excell dont work like that. If you try to enter say 1hr 30min as 1.5 it trys to use it as a date function and displays 12:00:00 and if you try to add times it treats them also as dates such that 12:00:00 + 12:00:00 = 0:00:00. I use two columns and add one mod 60 etc. Peter. Excell does work like that! ie for a flight of 8hrs 57min you put 8:57 You have to use the format including seconds at the one for just hrs:min will give you a false reading at higher values. I have entered my logbook for over 600 flights using this method and it works for me. |
![]() "OscarCVox" wrote in message ... Why not format the cells to a time format thus- Format - cells - time - 37:30:55 This will give time in hours minutes and seconds that can be added Sorry excell dont work like that. If you try to enter say 1hr 30min as 1.5 it trys to use it as a date function and displays 12:00:00 and if you try to add times it treats them also as dates such that 12:00:00 + 12:00:00 = 0:00:00. I use two columns and add one mod 60 etc. Peter. Excell does work like that! ie for a flight of 8hrs 57min you put 8:57 You have to use the format including seconds at the one for just hrs:min will give you a false reading at higher values. I have entered my logbook for over 600 flights using this method and it works for me. OK try summing a few time that when added are greater than 24 hrs. Or put a time in of 45hrs 36mins and see what it does then. Peter |
Go to the menu item Format Cells
Select the Custom Category (at the bottom of the menu on the left) Type the following into the 'Type' box in the upper right of the dialog: [h]:mm;@ This will give you the standard flight log format - hhh:mm (no seconds) This works in Excel 2003 - but I don't think the formats have changed much if at all since Excel '97 9B At 19:00 13 December 2004, Marc Ramsey wrote: Wayne Paul wrote: Using the format Category of 'Time' and the Type '37:20:55' I entered 12:22, 14:38, 72:14 and the above mentioned 45:36. Summing this column gave an accurate total of 144:50:00. What version of Excel are you using? I tried this in Excel 97 (I'm too cheap to upgrade). The key seems to be using the '37:30:55' time format in the Format Cells dialog. If any other time format is used, the values are interpreted as time of day, and wrap around at 24 hours. Marc |
millionaire on the Internet... in weeks! | Malcolm Austin | Soaring | 0 | November 5th 04 11:14 PM |
Excel formula for logbook | Wizard of Draws | Instrument Flight Rules | 11 | August 30th 04 12:55 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 02:13 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
