To the RAS knowledge base -
I had to strip some fabric liner from my cockpit (LAK17AT) to do some wiring. The original adhesive looks like a spray or brush product. It is no longer "sticky". I put the fabric back in place with double sided tape. That has failed. (Possibly due to our colder temps.) What is the best product to use for holding the fabric in place? Thanks in advance - Lou |
This worked great when I redid the interior of my Cessna
https://www.amazon.com/3M-38808-Head...gateway&sr=8-3 |
Pretty much the same stuff by "Gunk" is available at your local autoparts store.
![]() If you would rather use the "goop" you can get Duraseam Trim Cement from Airtex Interiors. |
3M 1300L
On Wednesday, April 10, 2019 at 8:51:13 AM UTC-7, Charles Longley wrote:
3M 1300L Weldwood contact cement, Home Depot Richard www.craggyaero.com |
On Tuesday, April 9, 2019 at 2:17:00 PM UTC-7, MNLou wrote:
To the RAS knowledge base - I had to strip some fabric liner from my cockpit (LAK17AT) to do some wiring. The original adhesive looks like a spray or brush product. It is no longer "sticky". I put the fabric back in place with double sided tape. That has failed. (Possibly due to our colder temps.) What is the best product to use for holding the fabric in place? Thanks in advance - Lou Chances are they originally used brushed or sprayed on contact cement, which you can just simply re-apply. If not familiar with it's application you should read up on it first. Note; there are mainly "green" labeled contact cements available in hardware stores and my experience with them is negative at best. The old fashioned stuff nowadays comes in small containers only, and one needs to look for it. |
Fabric Removal Question | glider.rescue | Soaring | 3 | April 6th 07 10:22 PM |
Adhesive | [email protected] | Restoration | 3 | August 25th 06 03:41 AM |
adhesive | [email protected] | Piloting | 2 | August 20th 06 12:30 PM |
Wood/Fabric durability question | Rich S. | Home Built | 2 | August 10th 04 01:06 PM |
Structural adhesive question | BD5ER | Home Built | 1 | August 3rd 03 06:03 AM |
