The new canopy retention bungee may have slipped through the eye hook or the knot failed. Fortunately the canopy was not broken, but the hinges had to be replaced.
Then we found a longitudinal crack. As a long time woodworker, my inclination is to inject Weldbond and clamp. Weldbond seems to do well keeping tail skids attached to fiberglass gliders. Perhaps not acceptable for spars, but much less loading on a canopy rail which is secured at four points. |
On Tuesday, April 9, 2019 at 8:13:26 PM UTC-4, George Haeh wrote:
The new canopy retention bungee may have slipped through the eye hook or the knot failed. Fortunately the canopy was not broken, but the hinges had to be replaced. Then we found a longitudinal crack. As a long time woodworker, my inclination is to inject Weldbond and clamp. Weldbond seems to do well keeping tail skids attached to fiberglass gliders. Perhaps not acceptable for spars, but much less loading on a canopy rail which is secured at four points. Not familiar with Weldbond. I expect what I would do us use epoxy. Spread crack a bit if possible. Warm the work and epoxy to reduce viscosity and help to maximize wicking and penetration. Then clamp and keep a bit warm while it cures. UH |
Crack canopy at the sliding glass screw hole. | Tim Murphy[_2_] | Soaring | 14 | October 15th 13 05:21 PM |
[USA] FAA approved canopy crack repairs | Jim Britton | Soaring | 5 | October 18th 10 02:33 PM |
Canopy crack :( | lanebush | Soaring | 6 | June 8th 10 06:44 AM |
Do you need a canopy vent rail? | qfly | Soaring | 0 | December 27th 05 04:23 AM |
Canopy crack repair | Pete Brown | Soaring | 0 | May 18th 04 03:09 AM |
