I'm looking for some info on THEMI: How do they work,
what's the technology used, etc. Can you help? |
http://search.ninemsn.com.au/results...RM=AS5&q=THEMI
= http://www.eglider.org/themi.htm "Mathilde Akar" wrote in message ... I'm looking for some info on THEMI: How do they work, what's the technology used, etc. Can you help? |
Mathilde Akar wrote:
I'm looking for some info on THEMI: How do they work, what's the technology used, etc. Can you help? How about this: http://patft.uspto.gov/netahtml/srchnum.htm Look for patent number 6,089,506 |
In article , Mathilde Akar
writes I'm looking for some info on THEMI: How do they work, what's the technology used, etc. Can you help? How about looking at the IGC-approval document for this recorder. IGC-approval documents for all recorders are available through: www.fai.org/gliding/gnss -- Ian Strachan Chairman IGC GFA Committee |
Hi Mathilde,
The Themi manual explains it to a certain extent. It is available on my web site he http://www.cumulus-soaring.com/themi.htm It uses GPS position and pressure altitude data to estimate where the center of the thermal is. It then uses LED indicators near the top of the instrument panel to guide you to the center. A friend of mine uses a Themi in his DG-1000 and likes it. Good Soaring, Paul E. Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com 1-952-445-9033 3M Tape, Airpath Compasses, Birecki Software, Cambridge Aero Instruments, Walter Dittel Radios, EMTAC GPS, Filser, flyWithCE, Garmin, Garrecht Volkslogger, Glide Navigator II, Goddard, ICOM Radios, ILEC, Intercomp, LX Navigation, Power-Sonic Batteries, RAM, Rikaline GPS, Scheffel Automation Themi, Schumacher Chargers, Schweizer, SeeYou & SeeYou Mobile, StrePla & pocket*StrePla, Tasman Varios, Transplant GPS, United Instruments Altimeters, Vertex Standard Radios, Winter, Xenotronix Chargers "Mathilde Akar" wrote in message ... I'm looking for some info on THEMI: How do they work, what's the technology used, etc. Can you help? |
One of my concerns about some devices is the amount of attention needed from
the pilot. Head-down looking at an instrument time, must be kept to a minimum for safety reasons. Themi uses two bright, LED lights mounted near the top of the instrument panel (typical) so they are in your field of view. The light or lights, only come on if Themi has a suggestion to make, so the light(s) are easy to notice without ever looking at them. Themi is most valuable on blue days, or at low altitudes, when clouds are of little help. Themi really works! Detailed information can be found on our web site www.eglider.org. Tom Knauff Knauff & Grove Soaring Supplies |
![]() Themi uses two bright, LED lights mounted near the top of the instrument panel (typical) so they are in your field of view. The light or lights, only come on if Themi has a suggestion to make, so the light(s) are easy to notice without ever looking at them. Better yet, they ought to develop a STEREO audio vario. Hear the tone in your left ear, turn left, or turn right when you hear it in your right ear. Even better would be quadra-pnonic... The tone would appear to eminate from the center of the lift... left, right, front, or back, you would know where the lift was without ever looking at he panel. Guy Byars |
Themi does exactly that with lights, while you listen to your audio vario
and watch outside for clues of lift and other aircraft. Just for claification, Themi does not find thermals. It only directs you to the center of the best lift it experiences after you have found one. At least one champion of the USA's Nationals uses it. Tom Knauff "Guy Byars" wrote in message ... Themi uses two bright, LED lights mounted near the top of the instrument panel (typical) so they are in your field of view. The light or lights, only come on if Themi has a suggestion to make, so the light(s) are easy to notice without ever looking at them. Better yet, they ought to develop a STEREO audio vario. Hear the tone in your left ear, turn left, or turn right when you hear it in your right ear. Even better would be quadra-pnonic... The tone would appear to eminate from the center of the lift... left, right, front, or back, you would know where the lift was without ever looking at he panel. Guy Byars |
Being forced to fly occasionally in blue conditions and often finding
myself low on course, I found this to be an intriguing concept (ignoring the fact that it's yet another way to increase the cost of competition). But I hadn't heard that any "name" pilots were using it apart from Tom's tests. Does anyone know of any experts who have given it the official stamp of approval (i.e., by actually spending his/her own money to buy one)? Chip Bearden ASW 24 "JB" |
Now, you probably wouldn't call me an 'expert', Chip, but I'll give it
a try anyway: WinPilot Pro has a 'climb maximizer that comes on when you start circling. I didn't spend money on it since it was part of the package. It does pretty much what "Themi" claims (same algorithm?). It gives you an audio tone to fly straight for a little and by doing so guides you to the center of the thermal. There is an elaborate and well made graphic on the IPAQ panel but we keep our eyes outside the cockpit, don't we! Comments: it works well and the prompts come when I would normally initiate moving my circle. When losing the thermal it shows an arrow of varying lenght to guide you back. Look at the WinPilot website for details. Best thing: you can turn it off! Herbert, J7 wrote: Being forced to fly occasionally in blue conditions and often finding myself low on course, I found this to be an intriguing concept (ignoring the fact that it's yet another way to increase the cost of competition). But I hadn't heard that any "name" pilots were using it apart from Tom's tests. Does anyone know of any experts who have given it the official stamp of approval (i.e., by actually spending his/her own money to buy one)? Chip Bearden ASW 24 "JB" |
Using a Pocket PC to download Themi flight logs | Paul Remde | Soaring | 5 | September 14th 04 07:29 AM |
Themi thermal locator | John Jones | Soaring | 5 | April 30th 04 04:16 AM |
Feedback ? | JJ Sinclair | Soaring | 3 | October 20th 03 10:18 PM |
FS: Themi, thermal centering device | Robt Salvo | Soaring | 4 | August 31st 03 01:27 AM |
