Lubricating Control system components
Old April 11th 19, 05:16 PM posted to rec.aviation.soaring
Default Lubricating Control system components
What oil to use for lubricating control system bearings and components.
Dan
Old April 11th 19, 05:52 PM posted to rec.aviation.soaring
Tim Taylor
Have used LPS-2 for many years. 1 is too light, you might find 3 works as well.
Old April 11th 19, 06:37 PM posted to rec.aviation.soaring
Tango Whisky
Le jeudi 11 avril 2019 18:16:39 UTC+2, a écritÂ*:
Dan
Fundamentals:
Oil is meant for fast moving parts.
Grease is meant for slowly moving parts.
Bert TW
Old April 11th 19, 09:05 PM posted to rec.aviation.soaring
Dan
Fundamentals:
Bert TW
Speak for yourselves, Bert. Me and my glider move really fast. The other thing: getting oil into those little Nadellager is tough enough. No way can I get grease in there. I use Superlube oil which comes with a needle applicator.
https://www.homedepot.com/p/Super-Lu...-202932717-_-N
Old April 11th 19, 09:16 PM posted to rec.aviation.soaring
JS[_5_]
Dan
Fundamentals:
Bert TW
Whatever happened to Marvel Mystery Oil?
Old April 11th 19, 09:52 PM posted to rec.aviation.soaring
Dan
Fundamentals:
Bert TW
I use 50/50 light machine oil and Marvel Mystery oil applied with a hypo needle. This works well to get below the felt washers used on many bearings.
UH
Old May 7th 19, 10:32 PM posted to rec.aviation.soaring
K m
That's a mystery...……..
Old May 7th 19, 10:37 PM posted to rec.aviation.soaring
JS[_5_]
It took nearly 4 weeks, but K m wins!
Old April 12th 19, 12:05 AM posted to rec.aviation.soaring
BobW
components. Dan
Fundamentals: Oil is meant for fast moving parts. Grease is meant for
Bert TW
applicator.
Free advice...worth every cent paid for it (sometimes!)...
(My excuse? It blizzarded yesterday so, "I plead 'Snowbound, y'r-'onor!")
I just *happened* to be reading a JS3 maintenance manual (342 pages!) before
taking a break and finding this particular thread, and - more to the point of
the OP's question - happened to take my break just *after* reading the
'lubrication section,' in which owners are advised:
1 - ...to avoid using "Any oils and greases containing silicon". (So, OK, it
IS a 'DRAFT' copy, but I, too, am a big fan of avoiding lube that contains
silicon!)
2 - "The following should not be used on the sailplane:
ï‚· "Thin spray penetrating oils, as these evaporate off fairly quickly.
ï‚· "Any oils and greases containing silicon. (repeated multiple places)
ï‚· "Oils and greases containing Molybdenum Disulphide MoS2 are unsuitable on
copper and brass bearings."
3 - "These bearings should be lubricated as follows:
 "Deep groove sealed bearings – No lubrication required.
 "Sealed rod ends in the control circuit – No lubrication required.
ï‚· "14C6 Open self-aligning bearings - Factory sealed, no lubrication required.
ï‚· "Taper roller bearings for the main wheel - Bearing grease every 5 years.
ï‚· "Metal to Metal bushes- Grease whenever the bush is opened or every 5 years.
 "Linear bearings – No lubrication required."
4 - (referring here to 'long term storage'...defined as 30 days)
"Pins, Bushes and Control Systems
"All bare metal surfaces that are not protected with paint must be protected
with a thin film of grease."
5 - "Longitudinal Push Rod Bearings
"Linear bearings are being used throughout the wing control system for the
airbrakes and flaperon, and elevator control systems. These bearings must
never be greased or oiled. The oil and grease will pick up dust and foreign
matter that will destroy the soft surface of the plastic balls."
So...the Joe Engineer in me's generic reply to the OP's generic question would
be something along the line of: the devil's in the details (ref: JS3
cut-n-pastes above); always good to understand (get? ha ha!) your bearings;
don't willy-nilly lubricate anything unless you *know* it needs lubricating.
And at the risk of triggering every FUD-merchant in RAS-land, as a general,
vaguely-lubricationally-related, observation, sailplanes lead about the
simplest life possible when it comes to the 'generic need for mechanical
stuff' to need lubrication...even in the USA's dusty, deserty, SW.
Of course, YMMV!
Bob W.
P.S. Over the years, I've (intentionally) used the (only) two automobiles I've
owned in my adult life as (if you will) 'lubrication test mules.' My '72 Ford
recommended repacking the front (non-driving) wheel bearings every 24k miles;
my '90 Honda recommended for its non-driving wheel bearings (I seem to
remember), every 30K miles. I initially did the Ford at 24K (grease looked
brand new), then again after a *delta* of 48K (grease still looked brand new);
then never touched em until I sold the vehicle after 37 years of ownership,
doing nothing more than 'keeping an eye on the dust caps' by way of verifying
the grease seals weren't dying. Ditto the Honda (presently coming back from
the moon): still on its original bearings/grease/seals/caps (and alternator
belt and a whole host of other items other than engine oil/filter [both
changed roughly every 5k miles] and timing belt [changed, per recommendation,
every 90k miles]).
P.P.S. No snark intended, and recognizing that a car isn't a sailplane, but -
still speaking generally - 'stuff' that needs lubricating (and here I'm
talking about 'low-relative-motion-speed 'stuff'', which is to say every
moving part in a sailplane unrelated to whatever supplemental engine it may
have) generally sends 'some sort of analog signal' L - O - N - G before
failure that it might be beneficial to continued long life of the widget that
'supplemental lubrication desirable, please.' Paying attention for those
signals while you're researching the types of bearings and bushings your
sailplane may use *before* getting all eager to go 'preventively-lubricating'
would - IMO - be a worthy use of one's spare time and mental energy. In the
meantime, if it ain't broke don't fix it? The risk of it 'breaking' while
you're researching is (arguably) much lower than the risk of performing some
sort of preventable-work-related foot shot by way 'curing' some future
low-lube-related issue. (Yeah, I know - as a 'Murican myself - that it's
un-American for guys to NOT want to mess with mechanical crud, but I suggest
'practicing' on something less life-critical than your sailplane's fight
control system.)
P.P.P.S. I'm off to go research personal flame-protection suits! :-)
This email has been checked for viruses by AVG.
https://www.avg.com
Old April 12th 19, 02:17 AM posted to rec.aviation.soaring
Charlie Quebec
Aeroshel 33 grease.
Grob gliders, new TM about control system pulleys Robert M Soaring 5 February 14th 14 04:47 PM
latest control system! Jordz Piloting 0 July 23rd 07 02:48 PM
sim cockpit control system El Baron Rojo Simulators 0 July 28th 05 09:32 PM
A New Air Traffic Control System On The Horizon Larry Dighera Piloting 0 June 17th 05 03:03 PM
Tactical Artillery Command and Control Information System (TACCIS) Roberth Andersson Military Aviation 0 May 25th 04 11:33 AM
