https://en.wikipedia.org/wiki/Petlyakov_Pe-8
The Petlyakov Pe-8 was a Soviet heavy bomber designed before World War II, and the only four-engine bomber the USSR built during the war. Produced in limited numbers, it was used to bomb Berlin in August 1941. It was also used for so-called "morale raids" designed to raise the spirit of the Soviet people by exposing Axis vulnerabilities. Its primary mission, however, was to attack German airfields, rail yards and other rear-area facilities at night, although one was used to fly the People's Commissar of Foreign Affairs (Foreign Minister) Vyacheslav Molotov from Moscow to the United States in 1942. Originally designated the TB-7, the aircraft was renamed the Pe-8 after its primary designer, Vladimir Petlyakov, died in a plane crash in 1942. Supply problems complicated the aircraft's production and the Pe-8s also had engine problems. As Soviet morale boosters, they were also high-value targets for the Luftwaffe's fighter pilots. The loss rate of these aircraft, whether from mechanical failure, friendly fire, or combat, doubled between 1942 and 1944. By the end of the war, most of the surviving aircraft had been withdrawn from combat units. After the war, some were modified as transports for important officials, and a few others were used in various Soviet testing programs. Some supported the Soviet Arctic operations until the late 1950s. The bomber was built mainly of duralumin, with two steel spars in the wings, although the ailerons were fabric-covered. The pear-shaped monocoque fuselage required the pilots to sit in tandem, offset to the left. In the prototype, space for a fifth engine, an auxiliary Klimov M-100, was reserved inside the fuselage, in a fairing above the wing spars and behind the pilots. It was intended to drive a supercharger that supplied pressurized air to the Mikulin AM-34FRN engines, with the installation designated ATsN-2 (Russian: Agregat tsentral'novo nadduva—Central Supercharging Unit). Subsequent models omitted the internal engine, and provided seating for a flight engineer and radio operator, behind and below the pilots. The bombardier sat in the nose and manned a turret armed with a 20-millimeter (0.79 in) ShVAK cannon that covered a 120° cone ahead. A prominent chin gondola, nicknamed the 'beard', protruded beneath the nose. The dorsal gunner sat at the rear of the ATsN fairing with a sliding hood covering a 7.62-millimeter (0.30 in) ShKAS machine gun and another ShKAS mounted in a ventral hatch. The tail gunner had a powered turret with a ShVAK and, most unusually, there were manually operated ShVAK cannon mounted at the rear of each inner engine nacelle. Crewmen had access to these positions through the wing or by a trapdoor in the upper wing surface. The large internal bomb bay racks held up to 4,000 kg (8,800 lb) of bombs; external racks held a single 500-kilogram (1,100 lb) FAB-500 (Fugasnaya AviaBomba - high explosive bomb) bomb under each wing. The arrests of both Tupolev and Petlyakov in October 1937, during the Great Purge, disrupted the program and the second prototype did not make its first flight until 26 July 1938. Although this prototype served as the basis for the series aircraft, further modifications were made to the armament. New weaponry included a retractable ShVAK in the MV-6 dorsal turret, another ShVAK in a KEB tail turret and a 12.7-millimeter (0.50 in) Berezin UBT machine gun in each ShU barbette in each inner engine nacelle, on the underside of the wing covering he lower rear arc of fire to left and right, respectively. Another fuel tank further increased the range, and the 'beard' was removed entirely, replaced by a more streamlined nose. Authorization for production was slow for several reasons, including the Great Purge, but also due to the scarcity of resources, and a shortage of workers. Although production facilities in the Kazan Factory No. 124 were ready as early as 1937, the order to begin was not given until 1939. Role Heavy bomber National origin Soviet Union Manufacturer Factory No. 124 Designer Vladimir Petlyakov First flight 27 December 1936 Introduction 1940 Status Retired Primary user Soviet Air Forces Produced 1936–1944 Number built 93 When Operation Barbarossa began on 22 June 1941, only the 2nd Squadron of the 14th Heavy Bomber Regiment (Tyazholy Bombardirovochnyy Avia Polk—TBAP), based at Boryspil was equipped with Pe-8s, but was not ready for combat. Two of its nine Pe-8s were destroyed by German air strikes shortly after the war began, before the Pe-8s were withdrawn out of reach of German bombers to Kazan. Stalin ordered that the squadron be reformed into a regiment, and that it strike targets deep inside German territory. Theoretically, this tactic would boost Soviet morale by demonstrating the vulnerability of the enemy. The squadron was re-designated on 29 June as the 412th TBAP and began training for long-range missions. On or about 27 July it was again renamed, this time as the 432nd TBAP. On the evening of 10 August, eight M-40-engined Pe-8s of the 432nd TBAP, accompanied by Yermolaev Yer-2s of the 420th Long-Range Bomber Aviation Regiment (DBAP), attempted to bomb Berlin from Pushkino Airfield near Leningrad. One heavily loaded Pe-8 crashed immediately upon take off, after it lost an engine. Only four managed to reach Berlin, or its outskirts, and of those, only two returned to their base. The others landed elsewhere or crash-landed in Finland and Estonia. The aircraft of the commander of the 81st Long-Range Bomber Division, Combrig Mikhail Vodopianov, to which both regiments belonged, was attacked mistakenly by Polikarpov I-16s from Soviet Naval Aviation over the Baltic Sea and lost an engine; later, before he could reach Berlin, German flak punctured a fuel tank. He crash-landed his aircraft in southern Estonia. Five more Pe-8s were lost during the operation, largely due to the unreliability of the M-40s. Seven Pe-8s were lost during the month of August alone, rendering the regiment ineffective. During this period, the surviving aircraft were re-equipped with AM-35As, which gave them a shorter range, but a more reliable engine. Removal from combat The loss of Pe-8s to all causes—mechanical, combat, friendly fire—had steadily increased from one aircraft per 103 flights in 1942 to one per 46 sorties in 1944. Despite the losses, production kept pace with need. The number of aircraft belonging to the 45th DBAD continued to rise; 20 were on hand on 1 January 1944 and 30 on 1 June. The Pe-8s flew 276 sorties in 1944 against such targets as Helsinki, Tallinn and Pskov. Aviation historian Yefim Gordon maintains that the Pe-8 flew its last mission on the night of 1–2 August 1944, but the Statistical Digest of the VVS contradicts this claim, showing 31 Pe-8s assigned to 45th DBAD on 1 January 1945 and 32 on hand on 10 May 1945. However, during this period the 45th DBAD only had three regiments, none of which used the Pe-8 as their primary aircraft, so while the 45th DBAD may have had Pe-8s, these may not have been in use as the primary combat aircraft. The 890th began to fly Lend-Lease B-25 Mitchells in the spring of 1944 and was itself re-designated as the 890th Bomber Aviation Regiment on 26 December 1944. The 362nd APDD was formed in early 1944 with four Pe-8s received from the other two regiments, but these were returned in the spring of 1944, when the regiment began to convert to the Lend-Lease Mitchells. Specifications (Pe-8/AM-35A) General characteristics Crew: Eleven Length: 23.2 m (76 ft ¼ in) Wingspan: 39.13 m (128 ft 4 in) Height: 6.20 m (20 ft 4 in) Wing area: 188.66 m² (2,030.7 ft²) Empty weight: 18,571 kg (40,941 lb) Loaded weight: 27,000 kg (59,400 lb) Max. takeoff weight: 35,000 kg (77,000 lb) Powerplant: 4 × Mikulin AM-35A liquid-cooled V12 engine, 999 kW (1,340 hp) each Performance Maximum speed: 443 km/h (275.2 mph) Range: 3,700 km (2,299 mi) Service ceiling: 9,300 m (30,504 ft) Rate of climb: 5.9 m/s (1,154 ft/min) Wing loading: 143 kg/m² (29 lb/ft²) Power/mass: 140 W/kg (0.2 hp/lb) Armament Guns: 2 x 20-millimeter (0.79 in) ShVAK cannons (dorsal and tail turrets) 2 x 12.7-millimeter (0.50 in) UBT machine guns (engine nacelles) 2 x 7.62-millimeter (0.30 in) ShKAS machine guns (nose turret) Bombs: Up to 5,000 kg (11,000 lb), including the FAB 5000 5000kg bomb * -- Miloch go Raiders/9ners |
Winter Flying 12 - Petlyakov Pe 8 Polar Circuit.jpg (1/1) | Mitchell Holman[_8_] | Aviation Photos | 0 | February 12th 15 01:32 PM |
