more at
http://www.thedrive.com/the-war-zone...icago-air-show The F-35 Heritage Flight team has been zipping around the U.S. as air show season continues. On August 18th, the team gave the masses arrayed along Chicago's picturesque waterfront one hell of a show. And considering it was a remote show over water, and that the air off Lake Michigan was nice and moist, full vape cones and capes were in effect. The Joint Strike Fighter in particular has proven to be quite adept at manifesting such atmospheric effects, a fact that was captured wonderfully by Airman 1st Class Alexander Cook. --- Oftentimes laymen confuse shock collars, vapor cones, 'vape capes,' and other forms of vapor as a sign that the aircraft has broken the sound barrier. This is not accurate at all. Although these effects can be greatly intensified as an aircraft reaches transonic speeds (approaching the speed of sound), they can also manifest themselves in various ways at far lower speeds. The phenomenon is caused by low pressure areas created on the aircraft's skin and wings as it moves through moist air. As the pressure drops so does the temperature, and if the temperature reaches the saturation point, water vapor is created. Such conditions are highly sought-after by aviation photographers. I have chased these conditions for years in order to execute certain photos. They are also a reason why it's worth getting excited about an air show that may not feature perfectly blue skies or even dry conditions. Some aircraft create vapor in more exotic ways than other due to their shape and their performance envelope. The F-22 is notorious for its uncanny ability to create crazy vapor effects even at slow speed and in relatively dry conditions. The F-15 is known for its streamers and its thick vape-capes that propagate along the top of the aircraft's lifting-body fuselage. Hornets and Super Hornets make great shock cones, and so on and so forth. * |
Minimum amount of Maximum pilot weight | Nyal Williams[_2_] | Soaring | 1 | May 22nd 11 10:34 AM |
F-22 Vapor | Canuck[_8_] | Aviation Photos | 0 | October 10th 09 03:17 AM |
ugly sky low show Blue Angel practice a little vapor | Beachcomber | Aviation Photos | 0 | March 31st 09 05:33 PM |
ugly sky low show Blue Angel practice afterburner and vapor | Beachcomber | Aviation Photos | 0 | March 31st 09 05:32 PM |
F-22 Vapor | Jim Morris[_2_] | Aviation Photos | 4 | May 1st 07 07:56 PM |
