White LS sleeves
Old April 22nd 19, 05:24 AM posted to rec.aviation.soaring
soaringjac
Default White LS sleeves
Been searching around and can't fine these things anywhere. Any current sources to purchase some from?
Old April 22nd 19, 04:47 PM posted to rec.aviation.soaring
Robert Holliday
current
These UPF 50+ sleeves are available for shipping now (in stock).
White only.
$30 USD and up. Contact Ruth at Bicycle Pedaler 10AM-6PM CDT.
316-685-454five.
Old April 22nd 19, 05:08 PM posted to rec.aviation.soaring
JS[_5_]
current
White only.
316-685-454five.
Will the UPF 50+ work as well as the usual LS sleeves to lock the L'Hotellier connections?
Old April 22nd 19, 05:11 PM posted to rec.aviation.soaring
Jonathan St. Cloud
current
White only.
316-685-454five.
I think the UPS 50 white will not work well on L'Hotelliers, nor is white a great color to block sun, darker colors work better, even a neutral grey.
Old April 24th 19, 12:41 AM posted to rec.aviation.soaring
son_of_flubber
What are 'White LS sleeves'?
Old April 24th 19, 03:45 AM posted to rec.aviation.soaring
Scott Williams
I think "white ls sleeves" are white colored plastic clips which are one method of preventing L'hotelier connections from accidentally coming loose. Wedekind sleeves , clips, or safety wire and correctly drilled holes are other methods.
http://aviation.derosaweb.net/wedekind/
Nice writeup with pictures,
Old April 24th 19, 09:40 AM posted to rec.aviation.soaring
Per Carlin
Initially was the sleeve for securing the Hotellier from LS in red plastic, those was withdrawn and replaced by sleeves with a new design and material(white) according to the TN56 above. This was long time ago and there should not be any red sleevs in use today.
Old April 23rd 19, 02:53 AM posted to rec.aviation.soaring
rj
I purchased mine from DG in Germany. You may also try the Shemp-Hirth or Schliecher dealers in the US. Many of the early fiberglass gliders used L'Hotelier connectors and the dealers should still be supporting these old gliders. The LS safety sleeve needs to be replaced every 2 years.
Old April 23rd 19, 03:36 AM posted to rec.aviation.soaring
soaringjac
Thank you!
Old April 23rd 19, 07:00 PM posted to rec.aviation.soaring
Referring to the TN/AD which introduced the white sleeves, they do not need to be replaced every 2 years. But they have to be checked anually for presence and retaining force. Check https://www.dg-flugzeugbau.de/downlo.../TM56/TM56.pdf for more info. This TN also contains information about the material used for these sleeves.
White LS Sleeves VS Wedekind for ASW 19? Nicholas L Soaring 10 May 19th 14 06:44 PM
Hotelier safety sleeves [email protected] Soaring 6 August 31st 07 04:41 PM
Wedekind Safety Sleeves ContestID67 Soaring 3 March 5th 07 01:04 PM
Uerling Safety Sleeves BDS Soaring 0 September 20th 05 09:02 PM
Wedekind Safety Sleeves Huds Soaring 5 May 8th 05 04:07 AM
