Flarm with External display
Old April 29th 19, 01:33 AM posted to rec.aviation.soaring
Default Flarm with External display
I have a portable FLARM that I may need to install in a loaner glider. Installation will be awkward but could be much better if I use an external display that I have surplus from my brick installs.
Has any one done this and can you advise how it worked out?
Thanks
UH
Old April 29th 19, 07:19 AM posted to rec.aviation.soaring
Ramy[_2_]
Yes you can connect any external display to the portable the same way you would connect to the core.
We just did this in our club ship, connected a portable to LXNAV S8 (which is also a powerflarm display). The portable is acting as both GPS source and Flarm source.
Ramy
Old April 29th 19, 03:31 PM posted to rec.aviation.soaring
Dan Marotta
But where do you stash the portable and how do you access it to turn it
on/off?Â* I assume you can control display range from whatever display
you're using.
When I first got a portable, I fashioned an aluminum plate the size of
the unit with an extension in the back center.Â* I used that extension to
fasten the whole contraption to the top center of the glare shield (the
Stemme has 4 screws holding the glare shield on and one of them is top
center front.Â* Later, when I decided to keep the unit, I drilled two
holes in the glare shield for mounting screws from below.
My ClearNav display provides the best pictorial information but the PF
display is still useful sometimes.
Ramy
Dan, 5J
Old April 29th 19, 06:37 PM posted to rec.aviation.soaring
Ramy[_2_]
Indeed the portable needs to be turned on, which requires pressing the button twice. I wish it would have turned on automatically with external power like core does. I wonder if this could be a firmware fix?
Ramy
Flat external FLARM antenna? Matt Herron Jr. Soaring 22 May 11th 18 09:10 PM
PowerFLARM core external display software update kirk.stant Soaring 5 January 28th 13 08:56 PM
Q: Position of external Flarm RF antenna on tow plane Aviat Husky A1 RuudH Soaring 5 December 20th 12 04:58 PM
Butterfly external display questions Andy[_1_] Soaring 30 October 15th 12 07:20 AM
Best PDA/PNA for FLARM display? Frank Paynter[_2_] Soaring 14 August 28th 11 09:24 AM
