I have an ASW-17 and the aircraft is registered under
an experimental certificate and has special operating limitations. They read, in part, 'All flights shall be conducted within the geographic area described as follows: Within 300 mile radius of a sanctioned glider meet or contest. Profficiency flights may be conducted in the vicinity of fly-ins or airshows.' Is this common for Experimental Certificates for our sailplanes? Thanks, Noel |
![]() Gentlemen & Ladies who fly gliders, in USA: You think you got a bad Operating Limitations limit? Think again. I bought a 1983 Schleicher ASW-20C, a year ago. Nice glider! There was no Ops Limits in file. I wrote the Charlotte FSDO where glider was handled for 'Special Airworthiness Certificate - Exhibition' |
Jim,
You are entitled (that's what the Order says - entitled) to Operations Limitations as shownn in the FAA Order 8130.2F. If you go to the FSDO with a copy of the pertinent section of that Order (posted earlier) that's what you'll get. Actually, you'll get the entire Ops Limitaitons, but that section of the boilerplate dealing with gliders is the important part. They like it if you bring the current revision of th eorder, so don't show up with a section from the 8130.2D or .2E. You guys that want to get rid of the program letter please note that you can change the rule. You just need to get a lobbyist to insert appropriate legislation in the appropriations bill next year and voila, it's done. Good luck. Personally, I'd like to see a lobbyist spend your resources to change some other rules. I don't have to send in a program letter for my Experimental - Exhibition and Racing glider because its certificate is pre-1993. For more details, you can read it in the Order. Jim "Jim Culp" wrote in message ... Gentlemen & Ladies who fly gliders, in USA: You think you got a bad Operating Limitations limit? Think again. I bought a 1983 Schleicher ASW-20C, a year ago. Nice glider! There was no Ops Limits in file. I wrote the Charlotte FSDO where glider was handled for 'Special Airworthiness Certificate - Exhibition' . To seek this, I gave FAA FSDO date of issuance of SpecAirworthinessCertificate, who signed it for FAA, and asked FSDO to send me the file copy of Operating Limitations on N929M, Asw-20C. They did. Got it in the mail. Good service. They keep things in files. Yup. Know ye, that this glider has been flown all over the country in the years since 1983 in many contests and many long long flights here and there. Sho nuff. Fine glider. Yes, indeed, it is a Schleicher Segelflugzeugbau Factory German built ASW-20C, with german LBA Type Certificate. That showed on its German LBA Export Certificate of Airworthiness. Well, got the Operating Limitations from FAA FSDO Charlotte, dated when US Certificate of Airworhiness was issued. No updates had been done. No modifications. Brothers and Sisters, I tell you. My jaw fell slack. My eyes glased over. My heart stopped. N929M is limited to flight within twenty (20) nautical mile radius of Chester Municipal Airport, S.C. You got it. That is it. This was not temporary. This requirement was not designed nor specified to be flown off, as a temporary measure, as is often the drill for experimental amateur built aircraft. As specified by FAA, this 20 NM Flight Radius from Chester Municipal Airport is for real, and permanent. Who says we don't get more Government than we pay for? Those FAA staff were Workin' Overtime To Regulate this Glider. Uh. Gee. Well, since I live in Florida, I must deal with Orlando FSDO and shall seek a permissive revision. Will do. No clue what I shall get. Now, I am seeking and gathering copies of highly permissive ASW-20 Operating Limitations to use as evidences to support my Letter Seeking Operating Limitations Change; in that I shall request modification to the FAA. I am further seeking from any of you operating under Special Airworthiness Certificate -Experimental, Exhibition and or Racing, permissive Operating Limitations specifications. Also, I am seeking copies of Operating Limitations that are highly permissive of other gliders Special Airworthiness Certificated that are Experimental - Ex/and or Racing For those of you who say Operating Limitations are not enforced, consider: The only time any enforcement of the paperwork or other things comes is when there has been an accident, incident, or other cause in their minds for FAA to say, 'Lets start with the paperwork....' Pilot certificate, Aircraft Registration, Airworthiness Certificate...ad infinitum,,,and then if they dont like ya they have the violation fall back of undefined Careless and Wreckless Operation of Aircraft. It is not a juried event, and no court procedures must be followed. Dancing on clouds, Keep it up! Jim Culp USA GatorCity Fla Asw-20C 17459 Nw 175 Ave Alachua, Fla 32615 |
Jim,
When you moved didn't you have to get a new airworthiness certificate from the local FSDO. Every experimental glider I've had has required a reissue of the airworthiness. Kevin |
No,
My certificate was issued pre-1993. The order grandfathers all certificates pre-1993 to their originally issued Ops Limitations letter. My letter does not state I have to get a new one when I move or sell the glider. Later Ops Limitations state that. It's important not to lose your pre-1993 certificate or Ops Limitations, a replacement will probably, most likely, be in accordance with the newer Order. Jim "Kevin Christner" wrote in message oups.com... Jim, When you moved didn't you have to get a new airworthiness certificate from the local FSDO. Every experimental glider I've had has required a reissue of the airworthiness. Kevin |
In the airshow business, I have to deal with this issue
every weekend. My operating limitations are 250 mile radius from my home field. It is a simple matter to include other sites in your annual program letter. My program letter is a simple one-pager. I just update it in the spring as my show schedule firms up. You may also fax a change to FSDO if you decide on a last-minute trip to another site. I'm guessing most of us forget all about the program letter. I'm also guessing that if everyone sent one annually, with weekly updates, the FAA might get tired of dealing with it and reduce the requirements. This requirement came about as a result of the large number of Russian jets that flooded the market about 20 years ago. They were being registered as experimental-exhibiti on, but were being flown (at high altitude and high airspeed) like certified aircraft. There was even a temporary moratorium on ALL Exp-Exh aircraft (including gliders) for a few weeks while FAA decided what to do about the problem. I don't recall for sure, but I'm guessing this was all the result of an accident somewhere that made the news. What, if anything, is SSA doing on this front??? Bob C. At 04:00 10 January 2005, Jim Phoenix wrote: No, My certificate was issued pre-1993. The order grandfathers all certificates pre-1993 to their originally issued Ops Limitations letter. My letter does not state I have to get a new one when I move or sell the glider. Later Ops Limitations state that. It's important not to lose your pre-1993 certificate or Ops Limitations, a replacement will probably, most likely, be in accordance with the newer Order. Jim 'Kevin Christner' wrote in message roups.com... Jim, When you moved didn't you have to get a new airworthiness certificate from the local FSDO. Every experimental glider I've had has required a reissue of the airworthiness. Kevin |
correction: FSDO of my asw-20c glider, N929M,
Special Airworthiness Certificate - Experimental, Exhibition Purposes, was Columbia, South Carolina; Not Charlotte. |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Weird Experimental Certificate wording - Normal? | Noel Luneau | Soaring | 12 | January 11th 05 06:11 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
PA-32 on Experimental Certificate | Mike Granby | Owning | 3 | July 21st 04 03:04 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
