Hi,
I've just updated my Vario Comparison web page with data on the new LX16 Audio Vario with Averager and flight time display. We don't have a lot of data on the new vario yet, but they will be arriving very soon. http://www.cumulus-soaring.com/varios.htm I also added Borgelt products to the comparison. Please let me know if you can help me fill in any of the missing data in the table. Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com |
Paul,
Thanks for this very useful tool. Suggestion: you cite the thermal height band graphic as a feature of the SN-10. In fact, I think most of us suppress this page. A better feature is the custom page that allows you to set up the information you think is most important in a format that works best for you. I don't know if this feature is unique, but coupled with the quality of the instrument, it makes the SN-10 a "best value" in my book. I'm looking forward to browsing your site when I have a little time. I suspect you'll get an order or two from me as a result. Cheers, OC |
A very interesting chart Paul. Thanks for your work on this.
Just a small thing - your comments on the Borgelt B50 would be more accurate if you added 'Pro' to make it 'WinPilot Pro'. According to the WinPilot web site, WinPilot Pro **requires** one of the following electronic varios: a.. Cambridge 302 vario/flight recorder, b.. LX 5000, LX 160, LX7000, LX1600 c.. Westerboer VW921/922 d.. or a Borgelt B50 (and a gps-unit) Appropriate comments could be added to all of these on your chart. These electronic varios enable several desirable features that are only available in the 'Pro' version of WinPilot, and hence (sadly) are only available to the WinPilot owner when one of these expensive varios is fitted to the glider. EG: * See the traced history of lift and sink behind the glider - climb/sink values are depicted using coloured circles - using filtered data from the vario. The stronger the lift or sink, the larger the circular 'blobs'. * The Climb Maximizer shows where to move the glider to maximize climb rate & provides an audible signal when the glider approaches the direction of the desired move. * Wind strength and direction is calculated whilst cruising (as well as in thermal flight). * 'Speed To Fly' at different MacCready settings calculated and displayed with a 'push/pull' indicator. * A diagram of average climb strength in the current thermal appears when thermalling (changes back to the map view in straight flight). * The average lift in the current thermal can be displayed with greater accuracy. Also the average lift in all thermals (can be reset at any time). This may be important info to those folks about to invest in a vario. Cheers, Jim Kelly Ref: http://www.winpilot.com/gps.asp http://www.winpilot.com/Beta.asp "Paul Remde" wrote in message news:52oDd.28165$3m6.589@attbi_s51... Hi, I've just updated my Vario Comparison web page with data on the new LX16 Audio Vario with Averager and flight time display. We don't have a lot of data on the new vario yet, but they will be arriving very soon. http://www.cumulus-soaring.com/varios.htm I also added Borgelt products to the comparison. Please let me know if you can help me fill in any of the missing data in the table. Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com |
LX 5000 why? Please explain
Hi Jim,
Good point. I'll try to clarify that on the comparison page somehow. Thanks, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Jim Kelly" wrote in message u... A very interesting chart Paul. Thanks for your work on this. Just a small thing - your comments on the Borgelt B50 would be more accurate if you added 'Pro' to make it 'WinPilot Pro'. According to the WinPilot web site, WinPilot Pro **requires** one of the following electronic varios: a.. Cambridge 302 vario/flight recorder, b.. LX 5000, LX 160, LX7000, LX1600 c.. Westerboer VW921/922 d.. or a Borgelt B50 (and a gps-unit) Appropriate comments could be added to all of these on your chart. These electronic varios enable several desirable features that are only available in the 'Pro' version of WinPilot, and hence (sadly) are only available to the WinPilot owner when one of these expensive varios is fitted to the glider. EG: * See the traced history of lift and sink behind the glider - climb/sink values are depicted using coloured circles - using filtered data from the vario. The stronger the lift or sink, the larger the circular 'blobs'. * The Climb Maximizer shows where to move the glider to maximize climb rate & provides an audible signal when the glider approaches the direction of the desired move. * Wind strength and direction is calculated whilst cruising (as well as in thermal flight). * 'Speed To Fly' at different MacCready settings calculated and displayed with a 'push/pull' indicator. * A diagram of average climb strength in the current thermal appears when thermalling (changes back to the map view in straight flight). * The average lift in the current thermal can be displayed with greater accuracy. Also the average lift in all thermals (can be reset at any time). This may be important info to those folks about to invest in a vario. Cheers, Jim Kelly Ref: http://www.winpilot.com/gps.asp http://www.winpilot.com/Beta.asp "Paul Remde" wrote in message news:52oDd.28165$3m6.589@attbi_s51... Hi, I've just updated my Vario Comparison web page with data on the new LX16 Audio Vario with Averager and flight time display. We don't have a lot of data on the new vario yet, but they will be arriving very soon. http://www.cumulus-soaring.com/varios.htm I also added Borgelt products to the comparison. Please let me know if you can help me fill in any of the missing data in the table. Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com |
8th Anniversary : Kiwi Aircraft Images Update | Phillip Treweek | Military Aviation | 0 | August 13th 04 01:45 AM |
Vario time constants | Bill Daniels | Soaring | 3 | January 20th 04 03:18 PM |
Anyone know how to update an old Loran database? | Tom Jackson | Owning | 12 | December 5th 03 06:03 PM |
Anyone know how to update an old Loran database? | Tom Jackson | Home Built | 8 | December 3rd 03 02:15 AM |
Anyone know how to update an old Loran database? | Tom Jackson | Piloting | 6 | December 3rd 03 02:15 AM |
