Due to a senior moment, my cobra trailer became unhooked as I was
pulling it out of my back yard. The emergency trailer brake activated and broke the safety chain I had installed as well as the trailer wiring, fortunately all this happened at a very slow speed before I got on the road and it was no big deal to repair. I had not realized that if you are going to use a safety chain it should be shorter than the cable which activates the emergency trailer brake. Probably everyone knows this but I thought I would pass this along. The other bit of knowledge I wish I would have known before my first towing trip is to remove or somehow secure the front wheel as it can loosen and drop down to the road surface. |
![]() "Eric Greenwell" wrote in message Since the chain broke so easily, I suggest you install a much stronger one. A trailer that comes off the towing vehicle will whip around and apply much more force to the chain(s) than even fully applied brakes will. I have done the same thing, Eric (installed strong chains), and I guess it is good advice. Note, however, that glider trailers are set up from the European factories to not use safety chains at all. It appears that the idea in Europe is that it is safer, if the trailer somehow releases from the tow vehicle, for the brake to self apply via the cable. The loose trailer (and the other traffic on the road!) can fend for themselves. That concept is not legal here in the U.S. and I don't necessarily recommend it, either. If you do agree with the European idea then it might be smart to use the weakest chain that is legal where you are based... -Bob Korves |
Bob Korves wrote:
"Eric Greenwell" wrote in message Since the chain broke so easily, I suggest you install a much stronger one. A trailer that comes off the towing vehicle will whip around and apply much more force to the chain(s) than even fully applied brakes will. I have done the same thing, Eric (installed strong chains), and I guess it is good advice. Note, however, that glider trailers are set up from the European factories to not use safety chains at all. It appears that the idea in Europe is that it is safer, if the trailer somehow releases from the tow vehicle, for the brake to self apply via the cable. The loose trailer (and the other traffic on the road!) can fend for themselves. That concept is not legal here in the U.S. and I don't necessarily recommend it, either. If you do agree with the European idea then it might be smart to use the weakest chain that is legal where you are based... -Bob Korves I suspect the reason is the generally smaller vehicles that they use for towing, compared to ours in the US. It might be safer for the trailer to break loose than send the trailer AND the car flying into the oncoming traffic. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
![]() The use of a single chain is also a dangerous thing to do and can lead to an uncontrollable trailer swinging wildly behind your vehicle, or worse tracking off in another direction throwing your vehicle out of control . Trailers should all have TWO chains for this purpose, and they should cross under the tongue in an X fashion . In the event that the trailer should seperate from the vehicle the tongue will fall onto the crossed chains and not the roadway , this keeps the trailer tracking straight behind the tow vehicle . It prevents the tongue from digging into the ground and last but not least it keeps the tongue of the trailer from going up too far under your vehicle . A number of safety chains sold on the market only have a single hook on the end of the chain . This hook can fall out of place on rough roads so a hook with a "gate" on it , or a different style of clasping mechanism is prefered. Make sure that your chains can not contact the road , this is especially inportant on gravel roads because the chains can cause stones to fly up onto your trailer. If in doubt contact a RV Dealer or a Hitch Shop . -- keithw ------------------------------------------------------------------------ Posted via OziPilots Online [ http://www.OziPilotsOnline.com.au ] - A website for Australian Pilots regardless of when, why, or what they fly - |
![]() wrote: The jack wheel will not come down do long as you crank it fully up - visually check that it is not askew with the diagonal cut in the jack casing. That said, if you plan to leave the gliderport for a retrieve or long trip, you should keep a plastic bag in the car or trailer. Removing the jack is simple, but it leaves grease on anything it touches. wrote: Due to a senior moment, my cobra trailer became unhooked as I was pulling it out of my back yard. The emergency trailer brake activated and broke the safety chain I had installed as well as the trailer wiring, fortunately all this happened at a very slow speed before I got on the road and it was no big deal to repair. I had not realized that if you are going to use a safety chain it should be shorter than the cable which activates the emergency trailer brake. Probably everyone knows this but I thought I would pass this along. The other bit of knowledge I wish I would have known before my first towing trip is to remove or somehow secure the front wheel as it can loosen and drop down to the road surface. |
I think removing, carrying and reinstalling the jack is too much
hassle. I thread a chain through the jack's wheel housing and attach both ends via a climber's snap clamp to the trailer's tow bar. Takes about 20 seconds. Bela |
I thought the same thing until I wore big flat spots
in 2 tires. It happens as you enter or leave gas stations. Tow vehicle rear wheels drop into the low drainage area at the curb, trailer wheel contacts pavement, can't swivel because we pulled it all the way up and locked it. BTW, I'm convinced this is the scenario that over-stresses your trailer tongue and leads to failure. JJ At 20:00 11 January 2005, wrote: I think removing, carrying and reinstalling the jack is too much hassle. I thread a chain through the jack's wheel housing and attach both ends via a climber's snap clamp to the trailer's tow bar. Takes about 20 seconds. Bela |
COBRA Skin Trailer Protector - Commercial | John Seaborn | Soaring | 0 | July 20th 04 04:38 PM |
Cobra Trailer Axel Replacement | Carter | Soaring | 7 | July 7th 04 02:06 PM |
Cobra Trailer Question | Deputy Dog | Soaring | 7 | January 3rd 04 03:11 PM |
Cobra Trailer | Soaring | 1 | September 28th 03 01:14 PM | |
Cobra trailer fittings for different glider makes & models | John W | Soaring | 4 | September 24th 03 03:21 PM |
