SPOT bread crumb interference with GPS position
Old May 9th 19, 02:14 PM posted to rec.aviation.soaring
son_of_flubber
Default SPOT bread crumb interference with GPS position
https://www.faa.gov/other_visit/avia.../InFO19006.pdf
Old May 9th 19, 03:47 PM posted to rec.aviation.soaring
Dan Marotta
My Spot has been in a drawer for a couple of years, and there it will stay.
Dan, 5J
Old May 9th 19, 03:59 PM posted to rec.aviation.soaring
kinsell
Cell phones can be noisy little devices too. Wouldn't it be funny if
your backup navigation device was causing interference with your primary?
Old May 9th 19, 07:09 PM posted to rec.aviation.soaring
Dan Marotta
Very interesting point!Â* I'll try turning my phone off before flight or,
as a minimum, set it to airplane mode.
On 5/9/2019 8:59 AM, kinsell wrote:
Cell phones can be noisy little devices too.Â* Wouldn't it be funny if
stay.
Dan, 5J
Old May 9th 19, 05:46 PM posted to rec.aviation.soaring
That PDF is short on details, but seems to imply that the transmissions from the SPOT device cause a nearby GPS receiver to have problems. Since the SPOT only transmits once in several minutes, do the observed GPS position losses only occur at those times and briefly? I wonder what the power and frequency of SPOT's transmissions are. We use many other devices in our cockpits that transmit periodically in VHF or UHF, e.g., transponders (high power!), FLARM (low power), cellphones (medium power), Bluetooth (low power), VHF radio (medium power), goTenna (medium power), switching power supplies (low power in any given frequency). Do any of these interfere with GPS reception? Actually I am amazed how well GPS receivers do in listening to very faint signals from the satellites, in the face of all the electric noise, and often poor "view of the sky" (e.g. the pilot's body nearby).
Old May 9th 19, 07:57 PM posted to rec.aviation.soaring
Darryl Ramm
The Globalstar uplink (what SPOT uses) is L-Band. 1,610-1,618.725 MHz (had to Google the exact frequencies) so in the ballpark of bunch of GNSS signal frequencies (see https://gssc.esa.int/navipedia/index.php/GNSS_signal). The Globalstar STX transmitter chips used are putting out something in the ballpark of 100mW when they transmit. BTW lots of details on Globalstar STX inside these devices are in FCC device approvals. So very significant compared to the received power of a GNSS signal. And as mentioned, your transpoder is putting out hundreds of watts at 1090 MHz as well, and in busy airspace doing that hundreds or more times per second.
Electronics at these frequencies can be pretty magic in how precise their signals are, and how much they can reject close by signals. (I used to work on very exotic signal sources that ran at ~10,000 MHz and had an incredibly precise ~1 Hz signal bandwidth :-)). More details of the issues would be interesting to hear.
I expect Garmin to do a good job engineering stuff, and betcha they are double checking InReach with nearby GPS receivers now :-)
Old May 9th 19, 09:47 PM posted to rec.aviation.soaring
son_of_flubber
On Thursday, May 9, 2019 at 12:46:32 PM UTC-4, wrote:
... seems to imply that the transmissions from the SPOT device cause a nearby GPS receiver to have problems.
The FAA doc says that what matters is the proximity of the SPOT to the antenna of the GPS device (not the GPS device itself).
Old May 10th 19, 12:24 AM posted to rec.aviation.soaring
[email protected][_2_]
It also does not mention what model of Spot, there are several different models.
Chris
Even the Devil doesn't cheat you in a game fair and square, he knows which side his bread is buttered Points of Fact: Naval Aviation 3 February 20th 16 07:49 PM
Spot deal, today only, buy service get a free Spot Tim Taylor Soaring 3 December 1st 08 10:30 PM
GPS Software for Garmin Handheld - (Crumb Trail Download) Robert Easton Piloting 3 June 5th 06 05:40 PM
So...here's the recipe for banana bread... 925/ 207-9350 ZBOXMAN ROGER THE BOX MAN FREE PC RE Simulators 4 February 3rd 04 09:09 PM
Banana Bread w/Anchovies ZBOXMAN Simulators 0 February 3rd 04 03:50 PM
