Escaping glider on the ground with stuck canopy?
Old May 10th 19, 09:30 PM posted to rec.aviation.soaring
Steve Koerner
Default Escaping glider on the ground with stuck canopy?
I'm hypothesising about a certain risk scenario that could happen: landing somewhere or crashing somewhere and canopy won't open. If it's hot especially, one might not last long enough for help to arrive if summoned by phone or radio.
My question is how to get through a canopy that's stuck or has a broken latch mechanism. Maybe someone has had relevant experience with this issue?
An obvious possibility might be to grab the window and try to tear the plexiglass apart (after donning kevlar gloves perhaps). I don't have a good intuition as to whether that is possible or not. Has anyone ever done that or does anyone maybe have access to a junk canopy to try it on? Another possibility is to carry a small saw or some other tool. Are there any specific tools that you know will work effectively on canopy plexiglass yet are compact enough to stash in a tight cockpit (there's no room to carry a hammer)?
Old May 10th 19, 09:55 PM posted to rec.aviation.soaring
john firth
How about a hacksaw blade and gloves. Start at the window.
Old May 10th 19, 10:13 PM posted to rec.aviation.soaring
ripacheco1967
Don't they design those things to break so that the pilot is never trapped?
https://i.pinimg.com/originals/11/86...24ce3384d9.jpg
Old May 10th 19, 10:29 PM posted to rec.aviation.soaring
Nick Kennedy[_3_]
In Soaring several years ago, a guy wrote a story about this happening to him, flying I believe was a SZD 55. He was on a Safari starting in Minden to Ely. He screwed up and landed in the mountains east of the Monitor Valley. Long story short he got a aero town out of there. While launching he hit his head very hard on the canopy. After he landed in Ely he couldn't open the canopy due to the rear pins being bent from his head hitting the canopy. Could not raise anyone on the radio and no one was around on the ground to help. He started to panic and remembered the emergency release. Luckily it worked and he got out before he over heated.
I wonder if trapped and the emergency release didn't work it you could put your hat over your fist and break the canopy bit by bit by hitting it near the vent window. A younger fellow might, a older gent maybe not.
Old May 10th 19, 10:56 PM posted to rec.aviation.soaring
RR
I always fly with a leatherman on my belt. Either the pliers or the saw would have me out in a jiffy...
Old May 11th 19, 12:15 AM posted to rec.aviation.soaring
bumper[_4_]
I do the same. Most gliders have a gap on the inside of the canopy frame to fuselage join. If the canopy jettison is of no help, then insert any pry tool in the gap (crack) opposite the canopy hinge. Pry away. A pry end with sharp edges (like a flat blade screwdriver) should get good purchase. Unlike other methods, if this works, any damage should be minimal.
Old May 10th 19, 11:10 PM posted to rec.aviation.soaring
Dan Marotta
I had one of THESE
https://www.dropbox.com/s/210gcqm9kek38oj/Canopy%20Breaker.jpg?dl=0
mounted in the jets I flew in the USAF.Â* The Type Certificate Data Sheet
for the Stemme requires a canopy breaker tool and my ship did not come
with one.Â* They make much smaller, lighter, and less expensive tools for
cars.
Dan, 5J
Old May 11th 19, 12:58 AM posted to rec.aviation.soaring
Steve Koerner
I should have done a better job of Googling. I just found a youtube of a pretty small escape hammer (as Dan suggests) that does a fine job on an RV7 canopy:
https://youtu.be/fRvQxGl4kt4
Old May 11th 19, 04:08 PM posted to rec.aviation.soaring
Dan Marotta
Yeah, and I'll bet that tool was a LOT cheaper than the military canopy
breaker, too!Â* And don't forget, the glider could be upside down and
attempting to pry the canopy open wouldn't help.
Dan, 5J
Old May 11th 19, 06:37 PM posted to rec.aviation.soaring
The tool is cheap, the required documentation is humongous. Part of the "$200 hammer" or a "$300 toilet seat".
I know some of this from UL vs. non-UL registered/approved wire. The product is basically the same.....the testing, documentation and data retention/traceability is where the price goes up.
Anyone Ground-Launched a Russia Glider? [email protected] Soaring 15 September 2nd 17 12:06 AM
Where to get a glider canopy in the US Bob Kuykendall Soaring 0 September 4th 08 01:16 AM
Stuck Canopy David Hartung Aviation Photos 2 June 21st 07 05:08 AM
Glider Ground School - Eastern PA RL Soaring 0 December 29th 06 02:19 AM
Glider ground school syllabus [email protected] Soaring 8 November 17th 06 01:50 PM
