New 5" VGA screen computer
Old January 12th 05, 10:06 PM
Eric Greenwell
Default New 5" VGA screen computer
Has anyone seen the Oqo computer (www.oqo.com) so they know how good the
screen is in sunlight?
It's spendy at $1800, but it's Windows XP computer with a 5" VGA screen,
just about the ideal size for a glider. Physically, it's only slightly
larger than an Ipaq 38xx. Of course, the key feature is how well the
screen works in a sunlit cockpit, but if that's good, it's very intriguing.
It doesn't have a serial port, but with Bluetooth, wireless, and USB, it
might connect anyway, such as with a USB-serial adapter. With a 1 Ghz
processor and 20 Gb hard drive, it ought to be up to the task of running
glide software!
Eric Greenwell
Washington State
USA
Old January 12th 05, 10:21 PM
Bill Thar
The hardware specs describe the screen as a "...color transflective
display..." which is the same type as the ipaq uses. It does look
interesting, but for soaring, the only advantage I can see is the screen.
Why pay for so much computing power?
intriguing.
glide software!
Eric Greenwell
Washington State
USA
Old January 12th 05, 10:27 PM
Mark Zivley
With all that extra computing power you could hook up a mass flow sensor
to your relief tube and then calculate in real time the amount of energy
lost when you took a leak.
intriguing.
glide software!
Eric Greenwell
Washington State
USA
Old January 12th 05, 11:27 PM
Eric Greenwell
You can't go by the technology used, as even the Ipaqs vary a lot in
their sunlight visibility; e.g., the older 38xx series is more readable
than the newer ones, like the 22xx (I've got both!). You have to see it
to know.
It does look
It's the screen that's most interesting: 5" of VGA (800x600) has got to
be much easier to see and use than 3.8" of 320x240. Even though the
screen is much bigger, the unit is only slightly bigger than a 38xx Ipaq
like I use, so it would still fit easily in my glider and on my mount.
For most of us, the cost would hard to justify for glider use only, but
prices do tend to fall. A bigger problem, I just noticed, is the screen
isn't a touch screen, but requires a "digital pen" for touch use. That's
a show stopper, I think, as all the PDA glide software depends heavily
on the touch screens.
Another choice for a bigger screen might be the NavAero t-pad 800, an 8"
touch screen (www.navaero.com), but it requires a cable connection to a
laptop mounted somewhere. The 8" might be TOO big to really be better,
overall, than a 4" PDA screen.
More choices are appearing, but not quite what we wish for, just yet.
intriguing.
Eric Greenwell
Washington State
USA
Old January 14th 05, 04:00 AM
Paul Remde
Hi Eric,
It does look somewhat interesting. The use of a hard drive makes it less
interesting to me.
I think your statement below comparing the iPAQ 3800 and 2200 is not quite
correct. They are not the same technology. The 3800 was (if I remember
correctly) "reflective" and the 2200 (and all recent iPAQs) are
"transflective". That explains the difference in sunlight visibility (which
I think is less dramatic a difference than many other glider pilots).
Good Soaring,
Paul Remde
"Bill Thar" wrote in message
intriguing.
glide software!
Eric Greenwell
Washington State
USA
Old January 15th 05, 12:04 AM
Eric Greenwell
Paul Remde wrote:
Hi Eric,
interesting to me.
I think you are right about the 2200/3800, (I couldn't find a reference
to "reflective" for the 3800 in brochures I have, but I remember it
being used with older models). But, it is still true that there is quite
a variation between displays of the different units, even if all are
using transflective screens, due to design and manufacturing choices.
Eric Greenwell
Washington State
USA
Old January 13th 05, 12:21 AM
Mike I Green
glide software!
There may be a problem with the 20 GB drive operating at altitude, at
least at the altitudes we fly in the Sierras. I seem to remember that I
didn't buy a 1GB drive for my camera a couple of years ago as the specs
indicated it wouldn't work at higher altitudes.
mg
Old January 13th 05, 12:42 AM
Eric Greenwell
the screen is in sunlight?
snip
Good point. I have no idea what altitude might be a practical limit, as
the specs don't mention altitude at all. I'm not familiar with HD specs,
either. Temperature might be a problem, too, but laptops and PDAs seem
to warm themselves!
Eric Greenwell
Washington State
USA
Old January 16th 05, 08:59 PM
It is not as much a temperature issue as it is an air density issue.
The heads are "flying" just microinches above the surface of the disk.
We all know about the negative effects of high density altitude on
"flying".
Larry Goddard
"01" USA
good
snip
at
that I
specs
as
specs,
seem
to warm themselves!
Eric Greenwell
Washington State
USA
Old January 13th 05, 03:57 AM
I have a digital camera that I use with an IBM 1GB microdrive and it
works at over Truckee. I was also able to record .avi movies on the
drive at altitude.
I
specs
mg
Calling all aviation enthusiasts – this is your chance to see two classic RAF movies on the big screen (Hull - Yorkshire). Phillip Rhodes Military Aviation 0 September 7th 04 01:30 PM
ANN: SoaringPilot 1.9.8 Mark Hawkins Soaring 0 April 21st 04 05:09 PM
Rag and tube construction and computer models? BllFs6 Home Built 24 April 12th 04 12:20 PM
Soaring Flight Computer Comparison - Help needed Paul Remde Soaring 10 January 29th 04 07:35 PM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 09:25 AM
