Wet Vacuum Pumps
Old August 18th 04, 11:07 PM
DBlumel
Default Wet Vacuum Pumps
Is anyone besides me using a wet vacuum pump out there. If so how are you
dealing with the oil output? Do you have an air/oil separator just for it? I
tried tying it into my Christen inverted oil system separator but that does not
work because of the large air volume, (high pressure) from the vacuum pump
compared to the engine breather (very low pressure and low volume). I am
loosing about a quart every 4 hours durring non aerobatic flight. I am running
with about 6 quarts on an IO-360-C1D6 angle valve engine. I don't want to throw
oil away ($$) plus its a mess on the belly. $360.00 from M-20 for a vacuum pump
separator seems alot for what it is.
Old August 19th 04, 03:05 AM
Morgans
Make your own. I know I have seen plans, but can't remember where. Someone
else out there, point him in the right direction?
Jim in NC
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.737 / Virus Database: 491 - Release Date: 8/11/2004
Old August 19th 04, 03:41 AM
jls
"Morgans" wrote in message
you
Someone
Jim in NC
The late great Tony Bingelis has plans for an air-oil separator in _Firewall
Forward._
Old August 19th 04, 08:27 AM
Kai Glaesner
DBlumel,
I
does not
running
throw
pump
Have a look at the "M20 Air/Oil separator" thread currently running in
rec.aviation.owning. It's run by people who have actually tried it.
Regards
Kai
Newbie Question - Vacuum vs Electric Bill Denton Aerobatics 1 April 15th 04 11:30 PM
Remove oil seal from vacuum pump adapter on Lycoming IO320 HOW????? Ron Home Built 2 February 24th 04 04:34 PM
Resin INfusion: Better than Vacuum Bagging Steve G Home Built 0 February 2nd 04 11:11 PM
Tiny vacuum pump Jim Weir Home Built 41 January 24th 04 05:42 AM
Fiberglass Vacuum Bagging Technique...Resin Infusion Steve Home Built 5 August 8th 03 06:10 PM
