https://en.wikipedia.org/wiki/Northrop_X-4_Bantam
The Northrop X-4 Bantam was a prototype small twinjet aircraft manufactured by Northrop Corporation in 1948. It had no horizontal tail surfaces, depending instead on combined elevator and aileron control surfaces (called elevons) for control in pitch and roll attitudes, almost exactly in the manner of the similar-format, rocket-powered Messerschmitt Me 163 of Nazi Germany's Luftwaffe. Some aerodynamicists had proposed that eliminating the horizontal tail would also do away with stability problems at fast speeds (called shock stall) resulting from the interaction of supersonic shock waves from the wings and the horizontal stabilizers. The idea had merit, but the flight control systems of that time prevented the X-4 from any success. Two X-4s were built by the Northrop Corporation, but the first was found to be mechanically unsound and after ten flights it was grounded and used to provide parts for the second. While being tested from 1950 to 1953 at the NACA High-Speed Flight Research Station (now Edwards Air Force Base), the X-4's semi-tailless configuration exhibited inherent longitudinal stability problems (porpoising) as it approached the speed of sound. It was concluded that (with the control technology available at the time) tailless craft were not suited for transonic flight. It was believed in the 1940s that a design without horizontal stabilizers would avoid the interaction of shock waves between the wing and stabilizers. These were believed to be the source of the stability problems at transonic speeds up to Mach 0.9. Two aircraft had already been built using a semi-tailless design—the rocket-powered Me 163 Komet flown by Germany in World War II, and the British de Havilland DH.108 Swallow built after the war. The United States Army Air Forces signed a contract with the Northrop Aircraft Company on 11 June 1946, to build two X-4s. Northrop was selected because of its experience with flying wing designs, such as the N-9M, XB-35 and YB-49 aircraft. The resulting aircraft was very compact, only large enough to hold two Westinghouse J30 jet engines, a pilot, instrumentation, and a 45-minute fuel supply. Nearly all maintenance work on the aircraft could be done without using a ladder or footstool. A person standing on the ground could easily look into the cockpit. The aircraft also had split flaps, which doubled as speed brakes. Role Tailless aircraft prototype Manufacturer Northrop First flight 15 December 1948 Status Preserved Number built Two The first X-4 (serial number 46-676) was delivered to Muroc Air Force Base, California, in November 1948. It underwent taxi tests and made its first flight on December 15, 1948, with Northrop test pilot Charles Tucker at the controls. Winter rains flooded Rogers Dry Lake soon after, preventing additional X-4 flights until April 1949. The first X-4 proved mechanically unreliable, and made only ten flights. Walt Williams, the head of the NACA Muroc Flight Test Unit (now Dryden Flight Research Center) called the aircraft a "lemon". The second X-4 (serial number 46-677) was delivered during the halt of flights, and soon proved far more reliable. It made a total of 20 contractor flights. Despite this, the contractor flight program dragged on until February 1950, before both aircraft were turned over to the Air Force and the NACA. The first X-4 never flew again, used as spare parts for the second aircraft. The NACA instrumented the second X-4 to conduct a short series of flights with Air Force pilots. These included Chuck Yeager, Frank Kendall Everest, Jr., Al Boyd, Richard Johnson, Fred Ascani, Arthur Murray and Jack Ridley. The flights were made in August and September 1950. The first flight by an NACA pilot was made by John H. Griffith on September 28, 1950. The initial NACA X-4 flights, which continued from late 1950 through May of 1951, focused on the aircraft's sensitivity to pitch. NACA pilots Griffith and Scott Crossfield noted that as the X-4's speed approached Mach 0.88, it began a pitch oscillation of increasing severity, which was likened to driving on a washboard road. Increasing speeds also caused a tucking phenomenon, in which the nose pitched down, a phenomenon also experienced by the Me 163A Anton prototypes in 1941. More seriously, the aircraft also showed a tendency to "hunt" about all three axes. This combined yaw, pitch and roll, which grew more severe as the speed increased, was a precursor to the inertial coupling which would become a major challenge in the years to come. The X-4's primary importance involved proving a negative, in that a swept-wing semi-tailless design was not suitable for speeds near Mach 1, although the F7U Cutlass proved to be something of a counterexample—the developed version was the first aircraft to demonstrate stores separation above Mach 1. Aircraft designers were thus able to avoid this dead end. It was not until the development of computer fly-by-wire systems that such designs could be practical. Semi-tailless designs appeared on the X-36, Have Blue, F-117, and Bird of Prey, although these aircraft all differed significantly in shape from the X-4. The trend during its test program was already towards delta and modified delta aircraft such as the Douglas F4D, the Convair F-102A derived from the XF-92A, and the Avro Vulcan. Specifications (X-4) General characteristics Crew: one Length: 22 ft 3 in (7.09 m) Wingspan: 26 ft 10 in (8.18 m) Height: 14 ft 10 in (4.52 m) Wing area: 200 sq ft (18.6 m2) Aspect ratio: 3.6:1 Empty weight: 5,507 lb (2,500 kg) Max. takeoff weight: 7,820 lb (3,550 kg) Powerplant: 2 × Westinghouse J30-WE-7/9 turbojet, 1,600 lbf (7.1 kN) each Performance Maximum speed: 625 mph (543 knots, 1,006 km/h) Range: 420 mi (365 nmi, 676 km) Service ceiling: 42,300 ft (12,900 m) Rate of climb: 7,700 ft/min (39.1 m/s) * |
![]() I read about this newfangled invention called a "thermos"... On 23 Oct 2018 07:10:25 -0700, Miloch wrote: https://en.wikipedia.org/wiki/Northrop_X-4_Bantam The Northrop X-4 Bantam was a prototype small twinjet aircraft manufactured by Northrop Corporation in 1948. It had no horizontal tail surfaces, depending instead on combined elevator and aileron control surfaces (called elevons) for control in pitch and roll attitudes, almost exactly in the manner of the similar-format, rocket-powered Messerschmitt Me 163 of Nazi Germany's Luftwaffe. Some aerodynamicists had proposed that eliminating the horizontal tail would also do away with stability problems at fast speeds (called shock stall) resulting from the interaction of supersonic shock waves from the wings and the horizontal stabilizers. The idea had merit, but the flight control systems of that time prevented the X-4 from any success. Two X-4s were built by the Northrop Corporation, but the first was found to be mechanically unsound and after ten flights it was grounded and used to provide parts for the second. While being tested from 1950 to 1953 at the NACA High-Speed Flight Research Station (now Edwards Air Force Base), the X-4's semi-tailless configuration exhibited inherent longitudinal stability problems (porpoising) as it approached the speed of sound. It was concluded that (with the control technology available at the time) tailless craft were not suited for transonic flight. It was believed in the 1940s that a design without horizontal stabilizers would avoid the interaction of shock waves between the wing and stabilizers. These were believed to be the source of the stability problems at transonic speeds up to Mach 0.9. Two aircraft had already been built using a semi-tailless design—the rocket-powered Me 163 Komet flown by Germany in World War II, and the British de Havilland DH.108 Swallow built after the war. The United States Army Air Forces signed a contract with the Northrop Aircraft Company on 11 June 1946, to build two X-4s. Northrop was selected because of its experience with flying wing designs, such as the N-9M, XB-35 and YB-49 aircraft. The resulting aircraft was very compact, only large enough to hold two Westinghouse J30 jet engines, a pilot, instrumentation, and a 45-minute fuel supply. Nearly all maintenance work on the aircraft could be done without using a ladder or footstool. A person standing on the ground could easily look into the cockpit. The aircraft also had split flaps, which doubled as speed brakes. Role Tailless aircraft prototype Manufacturer Northrop First flight 15 December 1948 Status Preserved Number built Two The first X-4 (serial number 46-676) was delivered to Muroc Air Force Base, California, in November 1948. It underwent taxi tests and made its first flight on December 15, 1948, with Northrop test pilot Charles Tucker at the controls. Winter rains flooded Rogers Dry Lake soon after, preventing additional X-4 flights until April 1949. The first X-4 proved mechanically unreliable, and made only ten flights. Walt Williams, the head of the NACA Muroc Flight Test Unit (now Dryden Flight Research Center) called the aircraft a "lemon". The second X-4 (serial number 46-677) was delivered during the halt of flights, and soon proved far more reliable. It made a total of 20 contractor flights. Despite this, the contractor flight program dragged on until February 1950, before both aircraft were turned over to the Air Force and the NACA. The first X-4 never flew again, used as spare parts for the second aircraft. The NACA instrumented the second X-4 to conduct a short series of flights with Air Force pilots. These included Chuck Yeager, Frank Kendall Everest, Jr., Al Boyd, Richard Johnson, Fred Ascani, Arthur Murray and Jack Ridley. The flights were made in August and September 1950. The first flight by an NACA pilot was made by John H. Griffith on September 28, 1950. The initial NACA X-4 flights, which continued from late 1950 through May of 1951, focused on the aircraft's sensitivity to pitch. NACA pilots Griffith and Scott Crossfield noted that as the X-4's speed approached Mach 0.88, it began a pitch oscillation of increasing severity, which was likened to driving on a washboard road. Increasing speeds also caused a tucking phenomenon, in which the nose pitched down, a phenomenon also experienced by the Me 163A Anton prototypes in 1941. More seriously, the aircraft also showed a tendency to "hunt" about all three axes. This combined yaw, pitch and roll, which grew more severe as the speed increased, was a precursor to the inertial coupling which would become a major challenge in the years to come. The X-4's primary importance involved proving a negative, in that a swept-wing semi-tailless design was not suitable for speeds near Mach 1, although the F7U Cutlass proved to be something of a counterexample—the developed version was the first aircraft to demonstrate stores separation above Mach 1. Aircraft designers were thus able to avoid this dead end. It was not until the development of computer fly-by-wire systems that such designs could be practical. Semi-tailless designs appeared on the X-36, Have Blue, F-117, and Bird of Prey, although these aircraft all differed significantly in shape from the X-4. The trend during its test program was already towards delta and modified delta aircraft such as the Douglas F4D, the Convair F-102A derived from the XF-92A, and the Avro Vulcan. Specifications (X-4) General characteristics Crew: one Length: 22 ft 3 in (7.09 m) Wingspan: 26 ft 10 in (8.18 m) Height: 14 ft 10 in (4.52 m) Wing area: 200 sq ft (18.6 m2) Aspect ratio: 3.6:1 Empty weight: 5,507 lb (2,500 kg) Max. takeoff weight: 7,820 lb (3,550 kg) Powerplant: 2 × Westinghouse J30-WE-7/9 turbojet, 1,600 lbf (7.1 kN) each Performance Maximum speed: 625 mph (543 knots, 1,006 km/h) Range: 420 mi (365 nmi, 676 km) Service ceiling: 42,300 ft (12,900 m) Rate of climb: 7,700 ft/min (39.1 m/s) * |
Northrop N-1M pics 2 [7/8] - northrop-n-1m-a-flying-wing-in-1941-with-designer-jack-northrop-standing-by.jpg (1/1) | Miloch | Aviation Photos | 0 | May 12th 18 09:51 AM |
Northrop YB-49 pics 1 [07/11] - Northrop’s YB-49 circa the late 1940s and present day’s Northrop Grumman’s B-2A Spirit.jpg (1/1) | Miloch | Aviation Photos | 0 | September 27th 17 02:46 PM |
Northrop YB-35 pics 2 [3/8] - us-yb-35-northrop-1946-flying-wing-bomber-cockpit.jpg (1/1) | Miloch | Aviation Photos | 0 | September 26th 17 12:50 PM |
Northrop YB-35 pics 2 [2/8] - US YB-35 Northrop 1946 flying wing bomber- towed b.jpg (1/1) | Miloch | Aviation Photos | 0 | September 26th 17 12:49 PM |
Wings for a Warwick Bantam | Ron Wanttaja | Home Built | 5 | July 2nd 06 05:31 PM |
