Need Help Configuring Power FLARM Portable
Old June 14th 19, 04:17 PM posted to rec.aviation.soaring
Dan Marotta
Default Need Help Configuring Power FLARM Portable
You've read on another thread that, since updating the firmware in my PF
Portable and updating the FlarmNet data file in my ClearNav II, I've not
been receiving Flarm targets on the ClearNav or on my wife's Streak.
Yesterday, full of hope, I downloaded and installed the just released
FlarmNet file (data.fln).Â* No joy!
The next easiest thing to try would be to roll back the PowerFlarm
firmware from 6.67 to 6.60 but I suspect that that won't work.Â* I would
expect a message telling me that I have a newer version installed.
So I figured I'd try to reset the configuration of the Flarm.Â* I went to
Flarm.com and started the Configuration Tool.Â* One of the earliest
questions asked was for the serial number of my unit and, when I entered
that, I got an error stating that the serial number was invalid!Â* True,
I did not have the unit with me at home to check, but I do have the SD
card and it looks to me like the serial number is either 960 or 000960.Â*
I entered both and got errors.Â* My PFP00960.txt file is here
https://www.dropbox.com/s/typrd4dz1a4g69t/PFP00960.TXT?dl=0 to be
looked at for any advice.Â* I'm out of ideas.
Dan, 5J
Old June 14th 19, 04:48 PM posted to rec.aviation.soaring
Dan, since you're sending FLARM data to xcsoar on your Streak, I would use xcsoar to check the data stream that is actually going to the Streak. You can go to Config - Devices - and then select your FLARM device and Monitor the data stream to see if you're getting the $PFLAA sentences to the device. My guess is that the flarmconfig has gotten screwed up and is no longer sending those sentences. As I recall you can configure the RJ45 and db9 ports individually to send (or not) GPS, FLARM targets, or both.
Happy to email you my config file if you just want to give it a try. It's for a core not portable so there may be some parameters that aren't valid for you.
Robert
my PF Portable and updating the FlarmNet data file in my ClearNav
II, I've not been receiving Flarm targets on the ClearNav or on my
wife's Streak.
released FlarmNet file (data.fln).Â* No joy!
would expect a message telling me that I have a newer version
installed.
went to Flarm.com and started the Configuration Tool.Â* One of the
earliest questions asked was for the serial number of my unit and,
when I entered that, I got an error stating that the serial number
was invalid!Â* True, I did not have the unit with me at home to
check, but I do have the SD card and it looks to me like the serial
number is either 960 or 000960.Â* I entered both and got errors.Â* My
PFP00960.txt
file is here to be looked at for any advice.Â* I'm out of
ideas.
Dan, 5J
Old June 14th 19, 05:12 PM posted to rec.aviation.soaring
Dan Marotta
Thanks Robert!
I'm very familiar with data stream monitoring on the Streak as I used it
during my initial system setup.Â* I just didn't think to use it now.
I agree that it's possible that my flarm configuration is messed up and
I was unable to create a new one using the online config tool. I'd be
very happy if you'd email yours to me and I can edit it to my
specifications.
dcmarotta at earthlink dot net
Dan
Robert
wife's Streak.
installed.
PFP00960.txt
ideas.
Dan, 5J
Dan, 5J
Old June 14th 19, 05:41 PM posted to rec.aviation.soaring
email sent.
On Friday, June 14, 2019 at 11:12:24 AM UTC-5, Dan Marotta wrote:
Thanks Robert!
specifications.
Dan
Robert
wife's Streak.
installed.
PFP00960.txt
ideas.
Dan, 5J
Dan, 5J
Old June 17th 19, 12:47 AM posted to rec.aviation.soaring
Dan Marotta
Well, I got the message traffic working BUT...
At takeoff I immediately began getting warnings about my own ship:
Traffic, 12 o'clock!Â* It drove me crazy until I could hand off the ship
to my wife and start playing with the PowerFlarm portable.Â* I was able
to get the traffic warnings to stop, but for the duration of the flight,
I had a warning of my own ship on the PF display and on my ClearNav2
display.
I'm going to try the flarm configuration tool again but would really
appreciate any pointers on making this work correctly.
On 6/14/2019 10:12 AM, Dan Marotta wrote:
Thanks Robert!
it during my initial system setup.Â* I just didn't think to use it now.
and I was unable to create a new one using the online config tool. I'd
be very happy if you'd email yours to me and I can edit it to my
specifications.
Dan
the Streak.Â* You can go to Config - Devices - and then select your
$PFLAA sentences to the device.Â* My guess is that the flarmconfig has
gotten screwed up and is no longer sending those sentences.Â* As I
Happy to email you my config file if you just want to give it a try.Â*
Robert
Â*Â*Â*Â* my PF Portable and updating the FlarmNet data file in my ClearNav
Â*Â*Â*Â* II, I've not been receiving Flarm targets on the ClearNav or on my
Â*Â*Â*Â* wife's Streak.
Â*Â*Â*Â* Yesterday, full of hope, I downloaded and installed the just
Â*Â*Â*Â* released FlarmNet file (data.fln).Â* No joy!
Â*Â*Â*Â* The next easiest thing to try would be to roll back the PowerFlarm
Â*Â*Â*Â* firmware from 6.67 to 6.60 but I suspect that that won't work.Â* I
Â*Â*Â*Â* would expect a message telling me that I have a newer version
Â*Â*Â*Â* installed.
Â*Â*Â*Â* So I figured I'd try to reset the configuration of the Flarm.Â* I
Â*Â*Â*Â* went to Flarm.com and started the Configuration Tool. One of the
Â*Â*Â*Â* earliest questions asked was for the serial number of my unit and,
Â*Â*Â*Â* when I entered that, I got an error stating that the serial number
Â*Â*Â*Â* was invalid!Â* True, I did not have the unit with me at home to
Â*Â*Â*Â* check, but I do have the SD card and it looks to me like the
serial
Â*Â*Â*Â* number is either 960 or 000960.Â* I entered both and got
errors.Â* My
Â*Â*Â*Â* PFP00960.txt
Â*Â*Â*Â*Â*Â* file is here to be looked at for any advice.Â* I'm out of
Â*Â*Â*Â* ideas.
Â*Â*Â*Â* --
Â*Â*Â*Â*Â*Â* Dan, 5J
Dan, 5J
Old June 17th 19, 01:03 AM posted to rec.aviation.soaring
If you have a mode S transponder (or ADS-B out) you need to give FLARM the same ID that is used in the transponder (your ICAO ID), then it won't warn you about it.
Old June 17th 19, 03:31 AM posted to rec.aviation.soaring
When we met up north of Leyba on today's flight, I was getting a dual return from your ship. Apparently, one was Flarm and the other was ADS-B. No problem, though. It was just a bit unusual.
Old June 17th 19, 05:27 AM posted to rec.aviation.soaring
Darryl Ramm
The suspicion then is the PowerFLARM does not have the correct ICAO address of the glider in its configuration file, we know the ADS-B is correct, because it's a certified install that had a performance report pulled.
Old June 17th 19, 04:12 PM posted to rec.aviation.soaring
Dan Marotta
I don't recall getting a return from you, Mark.Â* Are you in the flarmnet
database?Â* I had a "5J" plastered on the center of my screens all day.
Dan, 5J
Old June 14th 19, 05:06 PM posted to rec.aviation.soaring
Tango Eight
Which port is clearnav on? You have port 2 switched off.
You should set the port speed to 57600. Port 1 is set to 19200.
best,
Evan
wife's Streak.
installed.
PFP00960.txt
ideas.
Dan, 5J
FS: Power FLARM Portable Nick Gill Soaring 3 June 11th 17 06:48 AM
power flarm portable is sold [email protected] Soaring 0 February 18th 16 10:00 PM
Power FLARM Portable for sale [email protected] Soaring 0 December 25th 14 03:31 PM
Portable Power Flarm for sale [email protected] Soaring 1 June 2nd 12 01:14 AM
Power FLARM portable reports? Andy[_1_] Soaring 2 December 9th 11 03:58 PM
