New Video - Oudie Weather & SeeYou Maps
Old June 15th 19, 12:26 PM posted to rec.aviation.soaring
Paul Remde
Default New Video - Oudie Weather & SeeYou Maps
Hi,
NEW VIDEO - Oudie Weather & SeeYou Maps
Details: http://cumulus-soaring.com/training.htm#Naviter
Owners of Naviter Oudies now have free access to detailed "SeeYou Maps" (high resolution terrain maps) and weather forecast maps for display on their Oudies in flight. The Naviter Updater makes it easy to load the maps into Oudie before flight. This video shows how to setup your SeeYou.Cloud account using a web browser, how to use the Naviter Updater program to transfer the maps, and how to access the maps on the Oudie.
A current SeeYou-Upgrade subscription is required to access these features. Please order yours through Cumulus Soaring, Inc. he
http://www.cumulus-soaring.com/seeyo...SeeYou-Upgrade
To use the weather maps a SkySight subscription is required. Please order yours using the link he
http://www.cumulus-soaring.com/skysight.htm
You can rent the video for $3 for one month, or buy it forever for $10, or rent the entire 90+ videos in the Soaring Product Training video series for a year for $60.
Best Regards,
Paul Remde
Old June 15th 19, 08:31 PM posted to rec.aviation.soaring
Dan Daly[_2_]
On Saturday, June 15, 2019 at 7:26:24 AM UTC-4, Paul Remde wrote:
Hi,
Best Regards,
Paul Remde
I assume this is SeeYou Mobile Oudie not Oudie Lite with XC Soar?
Old June 16th 19, 12:45 PM posted to rec.aviation.soaring
Paul Remde
Hi,
Yes. The SkySight support for Oudie works only with SeeYou Mobile on an Oudie in with XCSoar. It also does not work with SeeYou Mobile on a non-Oudie product.
Best Regards,
Paul Remde
Hi,
Best Regards,
Paul Remde
Old June 17th 19, 12:24 PM posted to rec.aviation.soaring
waremark
Does use of Skysight on an Oudie use up one of the three devices my Skysight sub entities me to use it on? (I want it on phone tablet and pc.)
What happens if you try to add more devices?
Old June 17th 19, 12:51 PM posted to rec.aviation.soaring
Tango Eight
You seem interested in this. So let me ask: what's the value here? I honestly don't understand why anyone wants hours old forecasts in the cockpit.
T8
Old June 17th 19, 02:14 PM posted to rec.aviation.soaring
Old June 18th 19, 05:11 AM posted to rec.aviation.soaring
Ramy[_2_]
Mathew I just started using skysight with LXNAV connect recently and so far find it helpful. They are few issues though, some of them I suspect or on the LXNAV side (the convergence data and the satellite data don’t seem to remain cached through the flight unless I reconnect with a cel signal mid flight, I suspect this is an LXNAV issue) but one thing I noticed in my last flight is a discrepancy between the parameter I choose to what was displayed. I choose the cloud base parameter which suppose to show where the clouds are predicted, but what I was seeing during the flight was either top of thermals or cloud base regardless of cu potential, in other words there was color everywhere vs what the web browser was showing.
Ramy
Old June 18th 19, 07:50 AM posted to rec.aviation.soaring
Yeah you'll need to contact LXNAV for device issues - I only have visibility up until the forecast data leaves our servers. They have been updating it with new functionality and fixes quite rapidly.
Old June 22nd 19, 04:11 PM posted to rec.aviation.soaring
Tango Eight
T8
Just to clarify - the forecast data is 'old', but it still cycles through hour-by-hour in the cockpit so you are looking at the prediction for the hour when/where you are. If you have an LX9000, you can benefit from any later updates though.
I'm biased because I wrote it, but;
For wave flying, the wave forecasts are so useful you'll wonder how you did it without it. Don't believe me - ask Dennis Tito or Morgan Sandercock, an OLC comment from on one of their 2000km flights, using SkySight in the cockpit:
“The SkySight forecast is so precise that we did not need to look at clouds to find lift. When the clouds went one way and SkySight went another way we found it was better to follow the SkySight prediction. We literally do not need to look out the window to find lift.
I have flown blue wave personally multiple times with SkySight and it really opened possibilities that were not there before. Predicting wave is quite easy because mountains don't move very fast and mid-to-upper level winds change slowly. The same applies to orographic convergences (i.e. wind splitting and joining behind an obstacle) or along the edge of plateaus/ridges. Overlay some wave flights on the forecast with the IGC Upload to see for yourself.
In highly dynamic or unstable wave conditions (fronts passing through etc) though your mileage may vary as to the placement of the wave hour by hour..
Our experience (VT, NH, ME in USA) with smaller scale terrain is that all of the forecast models do roughly as well as an experienced human looking at a single forecast SkewT as far as predicting the likelihood of useful wave (it's not hard).
All of the map based tools seem to be equally bad at forecasting the location (aside from the really obvious, known reliable places, e.g. Mt Washington), strength and vertical extent of wave.
One of my club mates has made something of a hobby of comparing SkySight wave forecasts to his experience of the day, and it's a very different experience than you relate above. His observation is the same as mine: in flight we have to look out the window, we have to go with our experience, we have to go with our knowledge of terrain. All of our forecasting tools taken together are reliable only for forecasting likelihood of wave, clouds, winds aloft. I don't recall we've ever had a day where one could follow forecast wave lift contours on a map and get a positive result.
We speculate that the current state of the art is predictive for the largest terrain (e.g. NZ, Sierras), but is not adequate for the smaller scale stuff we have.
Perhaps you'd like to plan an extended vacation & study trip in New England? We're all in for better in region forecasting :-).
best regards,
Evan Ludeman
Old June 22nd 19, 04:22 PM posted to rec.aviation.soaring
The bigger the influence of terrain the easier it is to model.
Undoubtedly an competent user reading a SkewT can predict wave for a given location, but the maps allow you to do this over a large area, quickly and if in cockpit, hands free.
You are welcome to send feedback via the usual means, especially with traces, we may not always have time for a thorough investigation but we always read and note them.
After we upgrade the Western US model next week, the other US models will follow shortly after.
FlarmNet Files on Oudie (SeeYou Mobile) Tim Taylor Soaring 1 May 16th 16 10:09 PM
New SeeYou 6.1 - New vector maps and satellite image maps - very cool! Paul Remde Soaring 9 June 6th 14 04:58 AM
SeeYou 3.x raster maps for Moriarty and Hobbs? [email protected] Soaring 9 May 30th 13 04:22 AM
New Oudie with SeeYou Mobile who's me? Soaring 5 March 24th 13 04:25 PM
SeeYou v4.01 Maps jcarlyle Soaring 5 April 30th 11 04:13 PM
