Source for db25 shell for locking pins on a Becker 4201?
Old June 28th 19, 03:06 PM posted to rec.aviation.soaring
Sarah Anderson[_2_]
Default Source for db25 shell for locking pins on a Becker 4201?
Becker likes to use slide locks for the db25 connector on the back of the radio.
The ar3201 has a circular pin slide lock - the ar4201 a different locking "hook" hardware set.
Does anyone have a source for such hardware? I've looked in mouser and other online catalogs, but all I find are the standard
screw-in post connectors.
I'd replace the lock hardware on the radio, but suspect I'd have to completely disassemble it to put in new hardware.
Old June 28th 19, 05:16 PM posted to rec.aviation.soaring
Dan Daly[_2_]
This is what I used on my new-to-me AR4201; MHED-DS25S - D Sub Backshell: https://www.newark.com/mh-connectors...14_US%2Fsearch
Newark part number 61W9841 ; cost under $3USD/per. I'm surprised that the normal soaring suppliers don't stock them.
Cheers
Dan
Old June 29th 19, 12:28 AM posted to rec.aviation.soaring
Sarah Anderson[_2_]
Ordered. Thanks!
Sarah
Cheers
Dan
Old June 29th 19, 10:27 AM posted to rec.aviation.soaring
Charlie Quebec
I just removed the factory screws and bracket, then got two of the inside threaded bolts from an old PC and screwed in. Worked great.
Old June 29th 19, 04:03 PM posted to rec.aviation.soaring
John DeRosa OHM Ω http://aviation.derosaweb.net
A couple of comments;
- Both Cumulus and Wings & Wheels have the Becker locking shells in stock. Unsure about the other vendors.
- While I am not in love with the Becker latching system, preferring the LXNav "bail" type instead, they both have one advantage over the common screw-in type. Which is you can connect/latch the Becker/Filser/LXNav connectors blindly in our tight instrument panel confines.
- See http://aviation.derosaweb.net/presentations/#wiring (slide 47) for details.
- John OHM Ω
Old June 30th 19, 12:00 AM posted to rec.aviation.soaring
Sarah Anderson[_2_]
Thanks for the comments & presentation link. I didn't see the shell on W&W and I still can't find it on Paul's site.
But no problem... I have 2 coming in the mail from NJ.
Since you mentioned it (on the slide), know of a source for the "Filser/Dittel" sliding catch post-style shell?
That's the type used on my archaic AR3201. Maybe I should just buy a 4201.
Sarah
- John OHM Ω
Becker 4201 soaringjac Soaring 4 April 25th 19 01:56 PM
Becker AR 4201 John Foster Soaring 15 October 6th 18 05:33 PM
FS: 5 Becker 4201 + 1 Becker 3201 + 1 Dittel FSG5 Handheld Ross[_3_] Soaring 10 April 4th 18 04:36 PM
FS: Becker 4201 Romeozulu Soaring 0 March 7th 14 11:21 AM
FS: Becker AR 4201 Don[_4_] Soaring 0 September 19th 12 05:16 PM
