Intercoolers of the same config. were used on early model P-38's. They ducted
pressurized air along the insides of the leading edges, then into the carb. They all had problems with cooling efficency and leaks. Several famous Thompson Trophy (sea/float planes) winners used surface radiators to some degree. Most notably the Supermarines. Don't know what kind of problems they had, but its worth a look, and a grain of salt. Harry |
I'm not sure who was saying that it had been tried and it didn't work
as several people of given examples of successful racing aircraft using surface radiators. Several famous Thompson Trophy (sea/float planes) winners used surface radiators to some degree. Most notably the Supermarines. Don't know what kind of problems they had, but its worth a look, and a grain of salt. The guy that was saying an airplane waiting in line is the same as a car idling in traffic is off base because even with zero airspeed that prop is blowing turbulent air across the cowl. The wing radiators aren't going to be as efficient per unit area as the cowl or other parts of the aircraft in turbulent flow. I was under the impression that Voyager used fuel efficient versions of the traditional aircooled engines commonly used today, so I'd like to hear more about the pickup truck stories. And just because something has been tried before and failed, doesn't mean the concept should be abandoned. Haven't you ever seen anyone flub an attempt or do an experiment with an agenda? Why should their oversight stop others from doing better. And those old times were lacking many of the tools available today, mainly the cheap availability of computing power. You have part time hacks doing analysis orders of magnitude more accurate than they were doing back the 20-30's. |
(Jay) wrote: And just because something has been tried before and failed, doesn't mean the concept should be abandoned. Haven't you ever seen anyone flub an attempt or do an experiment with an agenda? Why should their oversight stop others from doing better. And those old times were lacking many of the tools available today, mainly the cheap availability of computing power. You have part time hacks doing analysis orders of magnitude more accurate than they were doing back the 20-30's. ++++++++++++++++++++++++++++++++++ Yeah, yeah, yeah. Commentary like yours won't buy a cup of coffee. If you're so smart, lead the way or be pegged as.... a typical newbie making silly little motor boat noises in a very large sea of knowledge. Barnyard BOb - 50 years of flight |
"Barnyard BOb --" wrote in message ... (Jay) wrote: analysis orders of magnitude more accurate than they were doing back the 20-30's. ++++++++++++++++++++++++++++++++++ Yeah, yeah, yeah. Commentary like yours won't buy a cup of coffee. If you're so smart, lead the way or be pegged as.... a typical newbie making silly little motor boat noises in a very large sea of knowledge. Priceless putdown. Lol -- .. -- Cheers, Jonathan Lowe modelflyer at antispam dot net Antispam trap in place Barnyard BOb - 50 years of flight |
Jay wrote:
I was under the impression that Voyager used fuel efficient versions of the traditional aircooled engines commonly used today, so I'd like to hear more about the pickup truck stories. Do your homework. 60 seconds of Google and you would have learned that Voyager used a pair of Teledyne Continental IOL-200 engines. In case you don't know it, that "L" in the engine type means "liquid cooled". Russell Kent |
Russell Kent wrote: Jay wrote: I was under the impression that Voyager used fuel efficient versions of the traditional aircooled engines commonly used today, so I'd like to hear more about the pickup truck stories. Do your homework. 60 seconds of Google and you would have learned that Voyager used a pair of Teledyne Continental IOL-200 engines. In case you don't know it, that "L" in the engine type means "liquid cooled". Russell Kent ++++++++++++++++++++++++ Tsk, tsk.... Teledyne Continental 0-240 piston engine (forward) http://www.nasm.si.edu/galleries/gal108/gal108.html http://www.aerospaceweb.org/aircraft/research/voyager/ http://www.va-works.com/projects/voyager.html Barnyard BOb -- |
Barnyard BOb -- wrote:
Russell Kent wrote: Jay wrote: I was under the impression that Voyager used fuel efficient versions of the traditional aircooled engines commonly used today, so I'd like to hear more about the pickup truck stories. Do your homework. 60 seconds of Google and you would have learned that Voyager used a pair of Teledyne Continental IOL-200 engines. In case you don't know it, that "L" in the engine type means "liquid cooled". Russell Kent ++++++++++++++++++++++++ Tsk, tsk.... Teledyne Continental 0-240 piston engine (forward) http://www.nasm.si.edu/galleries/gal108/gal108.html http://www.aerospaceweb.org/aircraft/research/voyager/ http://www.va-works.com/projects/voyager.html Arrggg.. Hoisted by my own petard. In my rush to prove how quickly the information was available ("60 seconds of Google") I failed to read the article for content. http://www.nasm.si.edu/nasm/aero/aircraft/rutanvoy.htm I'll take my crow grilled with a little bit of Mesquite spices please. Russell Kent |
In article , Russell Kent writes:
Arrggg.. Hoisted by my own petard. In my rush to prove how quickly the information was available ("60 seconds of Google") I failed to read the article for content. http://www.nasm.si.edu/nasm/aero/aircraft/rutanvoy.htm I'll take my crow grilled with a little bit of Mesquite spices please. Russell Kent Russell, you are a class act. Bob Reed www.kisbuild.r-a-reed-assoc.com (KIS Builders Site) KIS Cruiser in progress...Slow but steady progress.... "Ladies and Gentlemen, take my advice, pull down your pants and Slide on the Ice!" (M.A.S.H. Sidney Freedman) |
There is an engine in the U.S. patent offices (so nobody can use it)
developed by 'Smokey' who wrote a self help column in Popular Science magazine for years, that doesn't use a radiator. It takes the heat from the engine and uses it to preheat the fuel to pre detonation temperature and thus allows 55% of fuel energy to be used rather than the 12% now used in conventional engines. You should look into this. I became aware of it a few months ago. It can be found in the 1980 or 1984 issues. Jay wrote: I'd like to see some discussion on surface radiators instead of how to build plenums directing air through auto radiators. Seems like you could braze aluminum tubing onto the inner surface of the lower cowl, add a sheet of insulation on top of that on the inside and you'd have a particularly low drag radiator. The cowling is going to get blasted with turbulant air anyway, might as well heat that air up a little as it swirls by the surface. The holes in the front of the cowling make some sense for an air cooled engine where the temperature differential is high and you can direct some air (with lots of drag) directly onto the heads. But if you have a water cooled engine, you can do things differently and it would seem with lower drag. Drag is the primary predictor of top speed, beyond horsepower even. |
Wooduuuward praised: There is an engine in the U.S. patent offices (so nobody can use it) developed by 'Smokey' who wrote a self help column in Popular Science magazine for years, that doesn't use a radiator. It takes the heat from the engine and uses it to preheat the fuel to pre detonation temperature and thus allows 55% of fuel energy to be used rather than the 12% now used in conventional engines. You should look into this. I became aware of it a few months ago. It can be found in the 1980 or 1984 issues. ++++++++++++++++++++++++++++++++++++++++++++++ The fellow of which you speak is Henry "Smokey" Yunick. He was my hero back in the 50's, when I was the average impressionable teeny bopper subject to spouting stuff like you. FWIW.... Imply what you will, but there is NOTHING to look into application-wise, where surface radiators are concerned or anything else that a backyard builder can readily put to use. http://www.bankspower.com/tech_coolair.cfm Barnyard BOb -- 50 years of flight |
