![]() https://en.wikipedia.org/wiki/Convair_F-106_Delta_Dart The Convair F-106 Delta Dart was the primary all-weather interceptor aircraft of the United States Air Force from the 1960s through the 1980s. Designed as the so-called "Ultimate Interceptor", it proved to be the last dedicated interceptor in U.S. Air Force service to date. It was gradually retired during the 1980s, with the QF-106 drone conversions of the aircraft being used until 1998 under the Pacer Six Program. The F-106 was the ultimate development of the USAF's 1954 interceptor program of the early 1950s. The initial winner of this competition had been the F-102 Delta Dagger, but early versions of this aircraft had demonstrated extremely poor performance, limited to subsonic speeds and relatively low altitudes. During the testing program the F-102 underwent numerous changes to improve its performance, notably the application of the area rule to the fuselage shaping and a change of engine, and the dropping of the advanced MX-1179 fire control system and its replacement with a slightly upgraded version of the MX-1 already in use on subsonic designs. The resulting aircraft became the F-102A, and in spite of being considered barely suitable for its mission, the Air Force sent out a production contract in March 1954, with the first deliveries expected in the following year. Similar to the F-102, the F-106 was designed without a gun, or provision for carrying bombs, but it carried its missiles in an internal weapons bay for clean supersonic flight. It was armed with four Hughes AIM-4 Falcon air-to-air missiles, along with a single GAR-11/AIM-26A Falcon nuclear-tipped semi-active radar homing (SARH) missile (which detected reflected radar signals), or a 1.5 kiloton-warhead AIR-2 (MB-2) Genie air-to-air rocket intended to be fired into enemy bomber formations. Like its predecessor, the F-102 Delta Dagger, it could carry a drop tank under each wing. Later fighters such as the McDonnell Douglas F-4 Phantom II and McDonnell Douglas F-15 Eagle carried missiles recessed in the fuselage or externally, but stealth aircraft would re-adopt the idea of carrying missiles or bombs internally for reduced radar signature. Role Fighter interceptor Manufacturer Convair First flight 26 December 1956 Introduction June 1959 Retired August 1988 (ANG); 1998 (NASA) Primary users United States Air Force Air National Guard Number built 342 (2 prototypes, 277 F-106A, 63 F-106B) Unit cost US$4.7 million (1973) $25.1 million (2014) Developed from Convair F-102 Delta Dagger The F-106 served in the contiguous US, Alaska, and Iceland, as well as for brief periods in Germany and South Korea. The F-106 was the second highest sequentially numbered P/F- aircraft to enter service under the old number sequence (the F-111 was highest), before the system was reset under the 1962 United States Tri-Service aircraft designation system. In service, the F-106's official name, "Delta Dart," was rarely used, and the aircraft was universally known simply as "The Six." Although contemplated for use in the Vietnam War the F-106 never saw combat, nor was it exported to foreign users. Following the resolution of initial teething problems – in particular an ejection seat that killed the first 12 pilots to eject from the aircraft – its exceptional performance made it very popular with its pilots. After the cancellation of their own Avro Arrow, the Canadian government briefly considered purchasing the F-106C/D. Air-to-air combat testing suggested "The Six" was a reasonable match for the McDonnell Douglas F-4 Phantom II in a dogfight, with superior high-altitude turn performance and overall maneuverability (aided by the aircraft's lower wing loading). However, the Phantom had better radar – operated by an additional crewman – and could carry a load of up to four radar-guided AIM-7 Sparrow and four infrared AIM-9 Sidewinder missiles, while the AIM-4 Falcon missiles carried by the F-106 proved a disappointment for dogfighting over Vietnam. The F-4 had a higher thrust/weight ratio with superior climb, better high speed/low-altitude maneuverability, and could be used as a fighter-bomber. Air combat experience over Vietnam showed the need for increased pilot visibility and the utility of a built-in gun, which had been added to the "E" variant of USAF Phantoms. In 1972, some F-106As were upgraded in Project Six Shooter that involved fitting the F-106 with a new canopy without metal bracing which greatly improved pilot visibility. Also added was an optical gunsight, and provision for a single M61 Vulcan 20 mm cannon. The M61 Vulcan had 650 rounds of ammunition in the center weapons bay and it replaced the AIM-26 Super Falcon or Genie. The F-15A started replacing the F-106 in 1981, with "The Sixes" typically passed on to Air National Guard units. The F-106 remained in service in various USAF and ANG units until 1988. Specifications (F-106A) General characteristics Crew: 1 Length: 70.7 ft (21.55 m) Wingspan: 38.25 ft (11.67 m) Height: 20.28 ft (6.18 m) Wing area: 661.5 sq ft/61.52 m² (Original Wing) or 695 sq ft/64.57m² (Conically-Cambered Wing) () Airfoil: NACA 0004-65 mod root and tip Empty weight: 24,420 lb (11,077 kg) Loaded weight: 34,510 lb (15,670 kg) * Zero-lift drag coefficient: 0.0083 Drag area: 5.8 sq ft (0.54 m²) Aspect ratio: 2.10 Powerplant: 1 × Pratt & Whitney J75-17 afterburning turbojet, 24,500 lbf (109 kN) Performance Maximum speed: Mach 2.3 (1,525 mph, 2,455 km/h at 12,200 m (40,000 ft)) Combat radius: 926 km (500 nmi/575 mi) with internal fuel () Combat range: 2,900 km (1,600 nmi) () Ferry range: 4347 km (2346 nmi/2700 mi)with external tanks at 982 km/h (530 kn/610 mph) at 12,500 m (41,000 ft) () Service ceiling: 57,000 ft (17,380 m) Rate of climb: 29,000 ft/min (150 m/s) Wing loading: 52 lb/(sq ft) (255 kg/m²) Thrust/weight: 0.71 Lift-to-drag ratio: 12.1 (Subsonic, est.) Time to altitude: 6.9 min to 52,700 ft (16,065 m) Armament Guns: 1 20 mm caliber M61A1 Vulcan 6-barreled rotary cannon (After 1972 refit) Missiles: 2 AIM-4F Falcon 2 AIM-4G Falcon 1 AIR-2A Genie nuclear rocket or AIM-26 Super Falcon missile (Prior to 1972 refit) * |
Convair F-106 Delta Dart pics [13/21] - Convair-F-106-Delta-Dart-098_preview.jpg (1/1) | Miloch | Aviation Photos | 0 | July 19th 16 06:11 AM |
Convair F-106 Delta Dart pics [12/21] - Convair-F-106-Delta-Dart-081_preview.jpg (1/1) | Miloch | Aviation Photos | 0 | July 19th 16 06:11 AM |
Convair F-106 Delta Dart pics [11/21] - Convair-F-106-Delta-Dart-080_preview.jpg (1/1) | Miloch | Aviation Photos | 0 | July 19th 16 06:11 AM |
Convair F-106 Delta Dart pics [10/21] - Convair-F-106-B-Delta-Dart.jpg (1/1) | Miloch | Aviation Photos | 0 | July 19th 16 06:11 AM |
Convair F-106 Delta Dart pics [05/21] - convair-f106a-delta-dart-4.jpg (1/1) | Miloch | Aviation Photos | 0 | July 19th 16 06:11 AM |
