I am buying an aircraft that has had its canopy partly painted over as a sun
shield. Does any one know of a good method of removing the paint from the acrylic canopy without causing damage to the perspex? thanks in advance Jim |
Chemicals will probably damage the plexi. You can try alcohol, but
what I needed to do was to lightly sand the paint off then repolish the plexi, staring with 600 paper up to 2000 paper then polishing compound on a machine. Good luck. On Sun, 20 Feb 2005 08:10:29 GMT, "Jim" wrote: I am buying an aircraft that has had its canopy partly painted over as a sun shield. Does any one know of a good method of removing the paint from the acrylic canopy without causing damage to the perspex? thanks in advance Jim |
Try Naptha, I remove overspray with it from blown bubbles
and never had a problem. "Jon A." wrote in message ... Chemicals will probably damage the plexi. You can try alcohol, but what I needed to do was to lightly sand the paint off then repolish the plexi, staring with 600 paper up to 2000 paper then polishing compound on a machine. Good luck. On Sun, 20 Feb 2005 08:10:29 GMT, "Jim" wrote: I am buying an aircraft that has had its canopy partly painted over as a sun shield. Does any one know of a good method of removing the paint from the acrylic canopy without causing damage to the perspex? thanks in advance Jim |
Trailer paint removal | Chris Davison | Soaring | 13 | September 3rd 04 10:42 PM |
MSDOS FS 5.1 runnable under Windows 2000/XP? | Bill Wolff | Simulators | 12 | January 13th 04 08:05 PM |
Choice of Paint for use over Copper foil Antennas | Charlie Precourt | Home Built | 1 | December 2nd 03 02:51 AM |
Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 09:25 AM |
Notebook PC Configuration for MSFS2004 | Paul H. | Simulators | 0 | July 18th 03 11:21 PM |
