my instructor told me not to worry about what "qnh" actually
means......... can someone here enlighten me please? i know it has something to do with the barometric pressure and setting alt meter, but what does QNH stand for...... as always thanks for your patience guys and gals.....Im new here |
Marlbra wrote:
my instructor told me not to worry about what "qnh" actually means......... can someone here enlighten me please? i know it has something to do with the barometric pressure and setting alt meter, but what does QNH stand for...... as always thanks for your patience guys and gals.....Im new here QNH is the pressure that the air would be at sea level, if it wasn't for the land all being above sea level. If you were to bore a hole down to sea level, and lower a barometer down the hole to the bottom, then QNH is what pressure the barometer would read. Theoretically. If you set your altimeter to QNH, then it will accurately show you altitude above sea level, so you can avoid busting into someone's controlled airspace. It will also show the airfield elevation when you're on the ground at the airfield. Frank |
On Tue, 22 Feb 2005 21:44:01 +1300, Frank van der Hulst
wrote: thanks for that frank, instructor basically told me WHAT QNH actually was, I was just curious as to what the letters stand for Cheers Marlbra wrote: my instructor told me not to worry about what "qnh" actually means......... can someone here enlighten me please? i know it has something to do with the barometric pressure and setting alt meter, but what does QNH stand for...... as always thanks for your patience guys and gals.....Im new here QNH is the pressure that the air would be at sea level, if it wasn't for the land all being above sea level. If you were to bore a hole down to sea level, and lower a barometer down the hole to the bottom, then QNH is what pressure the barometer would read. Theoretically. If you set your altimeter to QNH, then it will accurately show you altitude above sea level, so you can avoid busting into someone's controlled airspace. It will also show the airfield elevation when you're on the ground at the airfield. Frank |
Marlbra wrote: my instructor told me not to worry about what "qnh" actually means......... can someone here enlighten me please? i know it has something to do with the barometric pressure and setting alt meter, but what does QNH stand for...... as always thanks for your patience guys and gals.....Im new here It means do it "Quietly, No Hu-hu". Well, you *asked* grin Seriously, it is just a "code". an *arbitrary* symbol to which a particular meaning has been assigned. "Q" codes date from the days of Morse-code communications, where there was a definite performance advantage to be gained by having "short-cut' symbols for many "common" messages/phrases. example: it is *much* faster to send the 3 Morse-symbols for "QRU" than it is to transmit "I have no traffic for your station". |
QNH, QFE, QFF, QNE
When an airport measures the local air pressure, then this pressure is called QFE. An airplane which has set the altimeter to the QFE value will read zero feet on the altimeter when it is on the ground at this airport. The QFE can be transformed into QNH by calculations and/or tables or diagrams. In fact what happens is that the measured QFE is being corrected for non-standard temperature, non-standard-humidity etc. The resulting value is called QFF. This QFF value is then corrected for field elevation, that means that it is transformed into a pressure as it would have been at mean sea level (MSL) under standard conditions QNE (29.92 inches or 1013.2 mb of mercury at 59 degrees fahrenheit or 15 degrees centigrade). The resulting value is a local pressure value which we call QNH. An airplane which has set the altitude to QNH value will read the field elevation on the altimeter when it is standing at this airport! Samm I fly because it releases my mind from the tyranny of petty things . . . - Antoine de St-Exupéry "Marlbra" wrote in message ... my instructor told me not to worry about what "qnh" actually means......... can someone here enlighten me please? i know it has something to do with the barometric pressure and setting alt meter, but what does QNH stand for...... as always thanks for your patience guys and gals.....Im new here |
Back when I worked at Boeing one of the test pilots told me that QFE and QNE
stood for Queen's Field Elevation (altimeter reference to the field so it read zero on the runway) and Queen's Normal Elevation (altimeter referenced to sea level). I don't know if this was just a memory aid, or if QFE and QNE are actually acronyms for Queen's Field Elevation and Queen's Normal Elevation.... anyone know? Dean |
Dean Wilkinson wrote: Back when I worked at Boeing one of the test pilots told me that QFE and QNE stood for Queen's Field Elevation (altimeter reference to the field so it read zero on the runway) and Queen's Normal Elevation (altimeter referenced to sea level). I don't know if this was just a memory aid, or if QFE and QNE are actually acronyms for Queen's Field Elevation and Queen's Normal Elevation.... anyone know? Yup. *NOT* true. 'Q codes' are just that _codes_. Not Acronyms. Furthermore, "logic" shoots down both your 'memory aid' interpretations. an "elevation" is a _distance_ measurement above a reference point, not a 'pressure' reference. One can trust the "Queen's English" to use words properly. grin |
On top of that... manned flight was invented HERE in the US... not in that
dental-challenged, pompus, take credit for everything, dung-hole! "Robert Bonomi" wrote in message ... In article , Dean Wilkinson wrote: Back when I worked at Boeing one of the test pilots told me that QFE and QNE stood for Queen's Field Elevation (altimeter reference to the field so it read zero on the runway) and Queen's Normal Elevation (altimeter referenced to sea level). I don't know if this was just a memory aid, or if QFE and QNE are actually acronyms for Queen's Field Elevation and Queen's Normal Elevation.... anyone know? Yup. *NOT* true. 'Q codes' are just that _codes_. Not Acronyms. Furthermore, "logic" shoots down both your 'memory aid' interpretations. an "elevation" is a _distance_ measurement above a reference point, not a 'pressure' reference. One can trust the "Queen's English" to use words properly. grin |
Jughugs wrote:
On top of that... manned flight was invented HERE in the US... not in that dental-challenged, pompus, take credit for everything, dung-hole! Actually controlled heavier than air flight was, not manned flight. The Montgolfier of brothers of France were making manned flights in hot air balloons in the 1700s. Dan, U.S. Air Force, retired |
