The insulation on the firewall of my RV-6 is coming loose. Originally, I
used 3M spray adhesive and aluminum tape to hold the stuff in place, but the insulation has come loose and repair efforts (more tape) have not held up. My guess is that heat simply causes the glue and or tape to release. Any better suggestions for attaching a flexible foam type material to a stainless steel firewall? KB |
"Kyle Boatright" wrote in message ...
The insulation on the firewall of my RV-6 is coming loose. Originally, I used 3M spray adhesive and aluminum tape to hold the stuff in place, but the insulation has come loose and repair efforts (more tape) have not held up. My guess is that heat simply causes the glue and or tape to release. Any better suggestions for attaching a flexible foam type material to a stainless steel firewall? KB How about Pro-Seal or some high temp silicone? ================ Leon McAtee |
Firewall | Flyhighdave | Home Built | 18 | February 20th 04 01:41 PM |
F.S. Fiberfrax Insulation | Jerry Wass | Home Built | 0 | October 6th 03 12:23 AM |
F.S.Fiberfrax Insulation | Jerry Wass | Home Built | 0 | October 2nd 03 06:46 PM |
blue foam, pink foam, yellow foam? | Corrie | Home Built | 26 | September 1st 03 05:01 PM |
