Many of the small 2-stroke engines appear to have the recoil
starter positioned so that as one faced the engine the starter is on the right and the prop on the left. With this configuration when right-handed person uses their right hand to start the engine the rest of their body is between the starter and the prop. This seems to be sub-optimal for safety. Would it not be better to have the recoil handle on the other side of the engine so that when pulling the cord the right arm is the part of the body closest to the prop with the rest of the body farther away? Is it possible in general to reposition (rotate) recoil starters during installation so as to have a choice in the matter? Also, many volksplanes are routine hand-propped. Is there any reason why the small 2-cycle engines could not be hand propped? |
Just install the engine inverted and you have your proper position.
Challengers are like that. Just an opinion J.P. wrote in message ups.com... Many of the small 2-stroke engines appear to have the recoil starter positioned so that as one faced the engine the starter is on the right and the prop on the left. With this configuration when right-handed person uses their right hand to start the engine the rest of their body is between the starter and the prop. This seems to be sub-optimal for safety. Would it not be better to have the recoil handle on the other side of the engine so that when pulling the cord the right arm is the part of the body closest to the prop with the rest of the body farther away? Is it possible in general to reposition (rotate) recoil starters during installation so as to have a choice in the matter? Also, many volksplanes are routine hand-propped. Is there any reason why the small 2-cycle engines could not be hand propped? |
On Wed, 23 Feb 2005 19:34:48 -0500, "Jean-Paul Roy"
wrote: Just install the engine inverted and you have your proper position. Challengers are like that. Just an opinion J.P. wrote in message oups.com... Many of the small 2-stroke engines appear to have the recoil starter positioned so that as one faced the engine the starter is on the right and the prop on the left. With this configuration when right-handed person uses their right hand to start the engine the rest of their body is between the starter and the prop. This seems to be sub-optimal for safety. Would it not be better to have the recoil handle on the other side of the engine so that when pulling the cord the right arm is the part of the body closest to the prop with the rest of the body farther away? Is it possible in general to reposition (rotate) recoil starters during installation so as to have a choice in the matter? Many small 2 stroke engine starters can be rotated. The other solution is a cable guide or pulley, and a longer rip-cord. Also, many volksplanes are routine hand-propped. Is there any reason why the small 2-cycle engines could not be hand propped? |
Body armor?
denny |
Mark Smith wrote:
snip Hand proping is also done but as a last resort when the battery is dead. They do start easily when hand propped, but it takes a healthy pull on a blade, then staying out of the way. Through a Rotax gear reduction? |
Darrel Toepfer wrote:
Mark Smith wrote: snip Hand proping is also done but as a last resort when the battery is dead. They do start easily when hand propped, but it takes a healthy pull on a blade, then staying out of the way. Through a Rotax gear reduction? Yes, a B box with 2.58 gears on several MXL II styled planes and also my GT 500 with the C box and 3.47 gears You might be thinking of the E box with the roller clutch and electric starter built in -- Mark Smith Tri-State Kite Sales 1121 N Locust St Mt Vernon, IN 47620 1-812-838-6351 http://www.trikite.com |
Mark Smith wrote:
You might be thinking of the E box with the roller clutch and electric starter built in Must be, thanks... When I was flying this, the owner mentioned against ever handpropping it: http://bbs.whodat.net/n6663k/engine.jpg |
Mark Smith wrote: You might be thinking of the E box with the roller clutch and electric starter built in Must be, thanks... When I was flying this, the owner mentioned against ever handpropping it: http://bbs.whodat.net/n6663k/engine.jpg That pic s of the C box, not the E so the starter is on the front end of the engine, not visible in the picture, I hand proped this exact combo many times,,,,,,,,,,,,,some for showing how to do it, a couple because the battery was dead. -- Mark Smith Tri-State Kite Sales 1121 N Locust St Mt Vernon, IN 47620 1-812-838-6351 http://www.trikite.com |
Mark Smith wrote: ... Hand proping is also done but as a last resort when the battery is dead. They do start easily when hand propped, but it takes a healthy pull on a blade, then staying out of the way. Some pushers with tails make getting away from the prop a physical excercise too. Thanks, and thnaks to the rest who responded as well. Supposedly with the adoption of the Light Sport Aircraft regs the FAA will soon begin stricter enforcement of the FAR 103 weight limits. 'Fat' ultralights will have to get an airworthiness certificate as Experimental Light Sport Aircraft, or be converted to lawn ornaments. So I was thinking about how to get as large an engine as possible, like maybe a Zenoah G-50 on something like a Sadler Vampire while keeping it under 254 lbs. A 'sneaky' way to get a few more lbs might be to install the lightest BRS possible and then take the maximum weight allowance for a BRS. Of course since I don't HAVE a Sadler Vampire, the question is purely academic. In the case of tractor mounted engines there is also the issue of keeping the CG from being too far forward. -- FF |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 03:31 PM |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 06:15 AM |
| BSFC vs gas mileage, 2 stroke vs 4 stroke | Jay | Home Built | 10 | August 24th 04 03:26 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 10:02 PM |
| Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 05:50 PM |
