https://en.wikipedia.org/wiki/Tupolev_ANT-20
The Tupolev ANT-20 Maksim Gorki (Russian: ??????? ???-20 "?????? ???????") was a Soviet eight-engine aircraft, the largest of the 1930s. Its wingspan was similar to that of a modern Boeing 747, and was not exceeded until the 64.6 metre wingspan Douglas XB-19 heavy bomber prototype first flew in 1941. The ANT-20 was designed by Andrei Tupolev, using German engineer Hugo Junkers' original all-metal aircraft design techniques from 1918. It was constructed between 4 July 1933 and 3 April 1934, and was one of two aircraft of its kind built by the Soviets. The aircraft was named after Maksim Gorki and dedicated to the 40th anniversary of his literary and public activities. The ANT-20 was the largest known aircraft to have used the Junkers aviation firm's design philosophy of corrugated sheet metal for many of the airframe's key components, especially the corrugated sheet metal skinning of the airframe. It was intended for Stalinist propaganda purposes and was equipped with a powerful radio set called "Voice from the sky" ("????? ? ????", Golos s neba), printing machinery, a library, radiostations, a photographic laboratory and a film projector with sound for showing films in flight. In a first-in-aviation history the aircraft was equipped with a ladder which would fold on itself to become part of the floor. The aircraft was the first to use both direct current and alternating current. The aircraft could be dismantled and transported by rail if needed. The aircraft set several carrying-capacity world records and is also the subject of a 1934 painting by Vasily Kuptsov, which is now in the collection of the Russian Museum at St. Petersburg. Role Propaganda aircraft/Transport National origin Soviet Union Manufacturer Tupolev First flight 19 May 1934 Introduction 1934 Retired 1942 Primary user Soviet Union Number built 2 Developed from Tupolev TB-4 On 18 May 1935, the Maksim Gorky (pilots – I. V. Mikheyev and I. S. Zhurov) and three more aircraft (a Tupolev ANT-14, R-5 and I-5) took off for a demonstration flight over Moscow. The main purpose of the other three aircraft flying so close was to make evident the difference in size. The accompanying I-5 fighter piloted by Nikolai Blagin had performed two loop manoeuvres around the Maksim Gorky. On the third loop, they collided. The Maksim Gorky crashed into a low-rise residential neighbourhood west of present-day Sokol metro station. Forty-five people were killed in the crash, including the fighter pilot as well as both crew members and the 33 passengers on the Maksim Gorky, and an additional nine people on the ground. A replacement aircraft, designated ANT-20bis had begun production the following year and first flew in 1938. It was largely identical in design but with six more-powerful Mikulin AM-34FRNV engines. In December 1940, the aircraft was re-engined with two slightly more powerful Mikulin AM-35 engines in the inner positions (number three and four). This plane, designated PS-124 and registered CCCP-L760, served with Aeroflot on transport routes in Russia and Uzbekistan. On 14 December 1942, it crashed after the pilot allowed a passenger to take his seat momentarily and the passenger apparently disengaged the automatic pilot, sending the airplane into a nosedive from an altitude of 500 m (1,600 ft), killing all 36 on board. Specifications General characteristics Crew: eight Capacity: 72 Length: 32.90 m (107 ft 11¼ in) Wingspan: 63.00 m (206 ft 8¼ in) Height: 10.6 m (34 ft 9¼ in) Wing area: 488 m² (5,251 ft²) Empty weight: 28,500 kg (62,700 lb) Loaded weight: 42,000 kg (92,400 lb) Max. takeoff weight: 53,000 kg (116,600 lb) Powerplant: 8 × Mikulin AM-34FRN V-12 liquid cooled, 671 kW (900 hp) each Performance Maximum speed: 220 km/h (119 kn, 137 mph) at sea level Range: 1,200 km (652 nmi, 750 mi) Service ceiling: 4,500 m (14,764 ft) * |
Tupolev Tu-28/Tu-128 pics [4/7] - Abandoned Soviet Air Force Tupolev TU-28 128UT Fiddler B.jpg (1/1) | Miloch | Aviation Photos | 0 | September 1st 18 03:11 PM |
Tupolev Tu-28/Tu-128 pics [3/7] - Abandoned Soviet Air Force Tupolev TU-28 128UT Fiddler B 4.jpg (1/1) | Miloch | Aviation Photos | 0 | September 1st 18 03:11 PM |
Tupolev Tu-28/Tu-128 pics [2/7] - Abandoned Soviet Air Force Tupolev TU-28 128UT Fiddler B 3.jpg (1/1) | Miloch | Aviation Photos | 0 | September 1st 18 03:11 PM |
Tupolev Tu-28/Tu-128 pics [1/7] - Abandoned Soviet Air Force Tupolev TU-28 128UT Fiddler B 2.jpg (1/1) | Miloch | Aviation Photos | 0 | September 1st 18 03:11 PM |
Tupolev SB pics 3 - Tupolev-SB-2M103-VVS-captured-Latvia-1941-01.jpg ... | Miloch | Aviation Photos | 0 | April 28th 18 02:43 PM |
