https://en.wikipedia.org/wiki/Heinkel_He_59
The Heinkel He 59 was a twin-engined German biplane designed in 1930, resulting from a requirement for a torpedo bomber and reconnaissance aircraft able to operate on wheeled landing gear or twin-floats. In 1930, Ernst Heinkel began developing an aircraft for the Reichsmarine. To conceal the true military intentions, the aircraft was officially a civil aircraft. The He 59B landplane prototype was the first to fly, an event that took place in September 1931, but it was the He 59A floatplane prototype that paved the way for the He 59B initial production model, of which 142 were delivered in three variants. The Heinkel He 59 was a pleasant aircraft to fly; deficiencies noted were the weak engine, the limited range, the small load capability and insufficient armament. The aircraft was of a mixed-material construction. The wings were made of a two-beam wooden frame, where the front was covered with plywood and the rest of the wing was covered with fabric. The box-shaped fuselage had a fabric-covered steel frame. The tail section was covered with lightweight metal sheets. The keels of the floats were used as fuel tanks - each one holding 900 L (238 US gal) of fuel. Together with the internal fuel tank, the aircraft could hold a total of 2,700 L (713 US gal) of fuel. Two fuel tanks could also be placed in the bomb bay, bringing the total fuel capacity up to 3,200 L (845 US gal). The propeller was fixed-pitch with four blades. Role Trainer, transport, air ambulance, torpedo bomber Manufacturer Heinkel First flight 1931 Introduction 1935 Retired 1944 Primary users Luftwaffe Finnish Air Force Number built 142 During the first months of World War II, the He 59 was used as a torpedo- and minelaying aircraft. Between 1940 and 1941 the aircraft was used as a reconnaissance aircraft, and in 1941-42 as a transport, air-sea rescue, and training aircraft. The trainer models survived slightly longer in service than operational models, but all had been retired or destroyed by 1944. Some aircraft were operated by the Condor Legion in Spain during the Spanish Civil War in 1936 as coastal reconnaissance and torpedo floatplanes. The British claimed, as the air-sea rescue aircraft, despite carrying Red Cross markings, were being used for reconnaissance, they were legitimate targets. Even before then some had been forced down by British aircraft. One justification the British used resulted from the fact that in July 1940 they had shot down a white HE 59 near Deal, Kent that was clearly marked with red crosses simply because it was in the same air space as German fighters. Some have explained this violation by stating that the British were fearful that saboteurs might be landed using these aircraft, another claim was that a convoy passing through the heavily trafficked English channel had spotted a red cross marked HE 59 and was then attacked by bombers later in its voyage. When the crew of the HE 59 downed off Deal was captured the British noted that the pilot supposedly noted the position and direction of a British convoy in his log book. Using that pretext the British Air Ministry issued Bulletin 1254 indicating that all enemy air-sea rescue aircraft were to be destroyed wherever they were encountered. Later, Winston Churchill later cast doubt on his own government's claims and motives when he wrote: "We did not recognize this means of rescuing enemy pilots who had been shot down in action, in order that they might come and bomb our civil population again." Germany protested the British attacks as rescue aircraft were part of the Geneva Convention agreement stipulating that belligerents must respect all "mobile sanitary formations" such as field ambulances and hospital ships. Churchill claimed that rescue aircraft were not anticipated by the treaty, and were therefore not covered. Because British attacks on He 59s continued the German Seenotdienst ordered the rescue aircraft armed and camouflaged. The use of civil registration and red cross markings was abandoned. A Seenotdienst gunner later shot down an attacking No. 43 Squadron RAF Hurricane fighter on July 20 Rescue flights were ordered to be protected by fighter aircraft whenever possible. Specifications (He 59B-2) General characteristics Crew: 4 Length: 17.40 m (57 ft 1 in) Wingspan: 23.70 m (77 ft 9 in) Height: 7.10 m (23 ft 3½ in) Wing area: 153.2 m² (1,649 ft²) Empty weight: 5,010 kg (11,023 lb) Loaded weight: 9,119 kg (20,062 lb) Powerplant: 2 × BMW VI 6.0 ZU water-cooled V12 engines, 492 kW (660 hp) each Performance Maximum speed: 221 km/h (119 knots, 137 mph) at sea level Cruise speed: 185 km/h (100 knots, 115 mph) Range: 942 km (509 nmi, 585 mi) Ferry range: 1,530 km (826 nmi, 950 mi) with auxiliary tanks Service ceiling: 3,500 m (11,480 ft) Climb to 1,000 m (3,300 ft): 4.7 min Climb to 2,000 m (6,600 ft): 11.2 min Armament Guns: 3 × 7.92 mm (.312 in) MG 15 machine guns in nose, dorsal and ventral positions Bombs: 2× 500 kg (1,100 lb) or 4 × 250 kg (551 lb) or 20× 50 kg (110 lb) bombs or 1 × 800 kg (1,764 lb) torpedo * |
Heinkel He 111 pics [8/8] - Artwork-line-drawing-or-blue-print-of-a-Heinkel-He-111Z-scale-1-72-Arkusz-02.jpg (1/1) | Miloch | Aviation Photos | 0 | January 12th 19 03:31 PM |
Heinkel He 100 pics 2 [6/7] - Heinkel He 100D Luftwaffe propaganda photo He_100D_colour.jpg (1/1) | Miloch | Aviation Photos | 0 | October 29th 18 02:11 PM |
Heinkel He 219 pics 3 [2/3] - Heinkel-He-219A-TK-captured-Westerland-Sylt-Denmark-01.jpg (1/1) | Miloch | Aviation Photos | 0 | September 26th 18 03:38 PM |
Heinkel He 219 pics 2 [2/6] - Heinkel He 219 A-2 fuselage preserved at the Steven F. Udvar-Hazy Center.jpg (1/1) | Miloch | Aviation Photos | 0 | September 26th 18 03:37 PM |
Heinkel He 51 pics 2 [4/7] - Heinkel He 51s as flown by Adolf Galland in the Spanish Civil War.jpg (1/1) | Miloch | Aviation Photos | 0 | December 8th 17 03:49 PM |
